Question about Cameras
All pictures seems like to be over exposed - Cameras
    Problem Solver:
  • 5 Answers
If this is showing up after printing the photos you need to change the exposure settings on your camera. You may have inadvertently changed the default setting so try restoring them first. If, however, it is the appearance of your phoros on the camera lcd screen that looks overexposed reduce the brightness of your display. Some cameras have a control on the bottom for doing this while others need you to go through the menu.
Posted on May 23, 2011
White screen
This is a problem with shutter not fast enough opening to take a picture indoor shows the horizontal lines. In sun light it is too slow and over expose the picture. Not worth the trouble to fix, buy another camera?
Jun 26, 2012 | Olympus Cameras
Camera exilim ex-s600 will not take pictures outside,pictures turning out white,yet will take pictures inside ok.is this a worthwhile repair
This seems to be a software problem with your camera. Your camera should, if on AUTO mode, automatically expose your photo accurately. Try half pressing the shutter button (used to take pictures) while outside to adjust focus and exposure, then press the button fully to take picture. If your camera cannot adjust to take a properly exposed picture (not bright white), then it is possible that the shutter speed is stuck on a too high speed, outside daytime shutter speed should be fast (1/1000 sec). Or if your shutter speed adjust accurately, it could be the aperture if the aperture is not small enough for daylight shooting. This is likely a software problem. Try adjusting your settings manually and see if the picture turns out!
Sep 10, 2011 | Casio EXILIM Card EX-S770 Digital Camera
My pictures are all coming out white! It looks like they're incredibly over exposed. Help.
Possible that the CCD has failed on the camera. You can remove battery and keep aside and check few hours later. if the display shows as well as the downloaded images seems hazy and of poor quality it is possible that the optical sensor has failed.
If you had exposed the camera to direct sunlight this is a possibility.
Get estimate.
Jul 14, 2011 | Samsung Cameras
Whenever I'll take a picture specially in outdoor enviroment, when I download the to my computer it seems the picture has so much light appearance. It's seems picture is over expose for the light...
It may be that you have inadvertently set your camera to shoot 'bracketing up' - ie over exposing for every shot. You need to look at the exposure ruler which looks something like this: l---l---l---l---l The centre bar is the correct exposure. But there is a little block that sits where you have got your +/- setting at. +/- is the sign for BRACKETING - where you tell the camera to over expose (+) or under expose (-). With Canon if the little block is to the right of the centre bar then you are telling the camera to over expose. Where is your little block? If it is to the right of the centre press your +/- button and turn the dial to the centre bar. NOTE: As digital cameras are WEAK in capturing highlights it is often better to shoot slightly under exposed - with your block set on the first or second horizontal line to the left of the centre bar. This means you are shooting 1/3 or 2/3 of an f/stop under exposed. Hope this helps.
Dec 31, 2010 | Canon PowerShot A470 Digital Camera
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Apr 12, 2009 | Pentax PZ-70 QD 35mm SLR Camera
Pictures washed out
Washed out I would guess looks like it's all white or a lot of white instead of the colors on the pictures. My guess is that your camera is over-exposing the pictures. Usually keeping it in automatic should solve your problem. But if it still doesn't, then it might be that you have an offsetting function that I think is called EV, which is either a plus or a minus function. Plus for over-exposing and minus or under-exposing. Read the manual and look for this function. Usually keeping it on auto is enough. Let me know if this helps.
Jul 15, 2008 | Casio Exilim EX-S500 Digital Camera
Light Meter
Check your metering settings. Are you using centerweighted, matrix, or spot metering? Try setting camera to matrix metering, use program mode 'P' and adjust exposure to default.
Sep 05, 2007 | Nikon D50 Digital Camera
Images seem over-exposed
Time for a new one I guess- too old to consider remedial work.
May 17, 2007 | Casio QV-R40 Digital Camera
Cameras Logo
20 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
