Question about Canon imageRunner C3100 Copier
Let me know how can I connect canon c3100 to my PC so that I can use it as a printer.
    Sergeant:
  • 372 Answers
U can connect through a network or even as standalone printer through usb port.In network connect the machine to the network through rj 45 cable and then load the driver in the server and access it from there .
Through usb simply run the driver when it asks to connect the machine connect the usb lead and rest it will take care of.
Posted on May 23, 2011
3 Suggested Answers
n25an
  • 622 Answers
SOURCE: canon image runner c3100 switched to dynamic ip
ok... turn dhcp on on the cannon... then turn it off and on... the cannon should pull the right settings... then turn dhcp off... and change the ip to the one you selected... all should be well after that... if it isn't... then you need to find the IP range of your router and get an IP address below it or above it.... say your IP address range is from 192.168.1.100 to 192.168.1.255 then you want an IP address below 192.168.1.100
Posted on Dec 16, 2009
  • 59 Answers
SOURCE: wanting to connect pc to a Canon ImageRunner
hi first u have to vearfy that yours irc3100 have a network card if yes then you have to
1.download latest driver for irc3100 from canon ofical website.
2. you shud have a network cross cable to connect directly from your pc if you dont want conect directly you want to conect throug yours local network in that condation you can use normal network cable,
3. you have set IP address on yours irc3100.
4. just connect networ cable and install driver on pc.
thats it enjoy
thanks
Posted on May 13, 2010
Reset pasword canon IR C2550
Clear Admin Password Get Full Access
You need to get access to service mode settings which a printer technician should know then follow below instructions
>COPIER>FUNCTION>CLEAR>PWD-CLR
Headlight PWD-CLR and hit OK
Sep 25, 2013 | Canon imageRunner C3100 Copier
Canon Imagerunner C3100 shows error code E00012-0001
Drum motor error
Check the connector and replace the motor
Jan 17, 2013 | Canon imageRunner C3100 Copier
Canon Ir C3100 Error 000070-0002
A E000070-0002 deals with the transfer belt. I believe it deals with the two tension arms, one may be broken...... It is not easy to get the unit out of the copier.... Good Luck
Jun 26, 2011 | Canon imageRunner C3100 Copier
I want softwere of ir2020
Click here to visit Official drivers and support for Canon IR-2020 Select the Operating System you have on your PC, select language and click 'submit' to download the required drivers
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 18, 2010 | Canon imageRunner C3100 Copier
Canon iR 3100CN Error code E000732-0001
E732 Reader communication error
0001 DDI-S communication error Check on connection between the reader controller PCB and the main controller PCB, Check on the
reader power supply
Hope that helped!
Jul 25, 2010 | Canon iRC3100 Printer
Wanting to connect pc to a Canon ImageRunner C3100. Anyone have any ideas on doing this?
thats it enjoy
thanks
May 13, 2010 | Canon imageRUNNER C3200 Copier
Canon image runner c3100 switched to dynamic ip addressing on new router but now ir c3100 does not work , i gave the printer an ip address and i can ping it from my computer and when i send print packets...
Dec 16, 2009 | Canon imageRunner C3100 Copier
I need to know whether the below canon's can scan and what the range of the DPI is that they can scan at; IRC3100 IR3320i IRC2570 Cheers
iR C3100 600 dpi if equipped with network print/scan kit.
iR3320i 200 dpi, 300 dpi, 400 dpi, 600dpi yes, can scan
iR C2570 600dpi yes, can scan
Nov 06, 2009 | Canon PC-920 Black and White Copier
How to configure imagerunner c3100 as a printer on a network
what do you need to know?
you need to put a static IP address or set it to DHCP and load the canon print driver.
you need to create a tcp/ip port on the ip address of the copier
Aug 22, 2009 | Canon imageRunner C3100 Copier
128 people viewed this question
old marine
old marine
