Question about Dolphin Maytronics Advantage
A slightly oily film is noted coming from the top of the dolphin while cycling in pool.
XPoolGuy
  • 34 Answers
SOURCE: dolphin pool cleaner won't go up to top of the
Most times when a cleaner won't reach the water level in a pool it is usually due to the internal floats being removed or they are no longer in good condition.
Turn the machine upside down, and remove the bag assembly. Should be foam in the plastic housing, underneath, if not replace.
Posted on Jul 03, 2009
john224
  • 1378 Answers
SOURCE: Dolphin pool cleaner cleaning cycle
The motor pack is failing and will need to be serviced which is not a do-it-yourself sort of project. Of course that may not stop you from trying but you will find that parts are not available inside the motor pack and that replacing it, if necessary, is best done in a service center to maintain new motor warranty. For price estimates on a replacement or to browse a FAQ on dolphins check out our site at www.arrowpools.net or you can contact the manufactrure's US rep at www.maytronicsus.com.
Posted on Jun 14, 2010
jharwell668
  • 640 Answers
SOURCE: My Maytronics Dolphin pool cleaner does not entire pool
Check to make sure that your power supply is in a position that it can reach all sides of the pool. It may be as simple as repositioning your power supply to make it more effective. Also, with these automatic pool cleaners, you need to make sure that the filter is off, because it being on can affect where the cleaner is able to go. Finally, make sure the handle is locked in a diagonal position.
Posted on Jul 22, 2010
jharwell668
  • 640 Answers
SOURCE: My dolphin begins to work, then stops. What could
There are several problems that could make these automatic pool cleaners fail to climb the walls. The cleaner could be too heavy. Empty and wash the filter bag and add floats if necessary. Make sure there is no water in the handle and that the brushes arent worn. If the cleaner is too light, add weights. If there are excessive amounts of algae on the wall, you will need to brush the walls first. The algae can prevent the cleaner from climbing. Make sure that the temp is at least 65 degrees in the pool. Make sure there is nothing caught in the impeller.
Posted on Aug 05, 2010
john224
  • 1378 Answers
SOURCE: Aquabot Dolphin pool cleaner... stalls in pool
Thank you for posting your question here on Fixya.com.
For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up. If that is not enough, try our sites FAQ section on Dolphins at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin.
If none of this helps your problem could be in the power supply, cable or motor unit. The motor unit is the most likely problem.
It is not recommended you open the cord end that connects to the motor unit as you are breaking the seal for the submersible electronics. For information about sending your unit in for repair use the dolphin form link on the bottom of our site
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Sep 21, 2010
Goes to wall and turns itself over. It is clean.
Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ...
? 3:44
www.youtube.com/watch?v=-x8hwghv8BE
Apr 4, 2012 - Uploaded by Swimming Pool Tips, Reviews & How To -MrDgvb1 Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ... Solar Breeze: The Robotic Solar-Powered Pool Cleaner Review: http://youtu.be/jzWfClbOnIc ... Pentair Kreepy Krauly Legend Review, Troubleshooting & Tips:
Aug 08, 2015 | Dolphin Maytronics Diagnostic Robot...
Tip
Your Dolphin pool cleaner wont start up...
A common problem, especially with 'newer' Maytronics Dolphin brand pool cleaners is that you put the unit in the pool, or even try to turn it on after a cleaning cycle while it is still in the pool, and to that point it has worked fine. You turn the power supply on and nothing happens. You turn it off and back on and still nothing. You leave it, even over night, same thing. What do you do?
While I cannot tell you why it does this (we have a theory but can not confirm it) what usually works is to follow these steps...
1) Unplug everything. Unplug the power supply from the outlet and the Dolphin from the power supply.
2) Let the whole thing sit a couple of minutes (we want to allow any capacitors to discharge).
3) Be sure the Dolphin is out of the water and sitting upside-down on a level surface (Tracks pointing skyward).
4) Reconnect the Dolphin to the power supply and the power supply to the outlet.
5) With the Dolphin still out of the water, perform a self-test. Simply turn on the Dolphin. Within about 15 seconds it should begin to move. The tracks will spin in both directions with and without the impeller motor running at the same time. It is not unusual for the tracks to rotate at different speeds during this test. The test will last for 30 - 45 seconds or so. If it goes on indefinitely, turn it off and contact us for further direction.
6) Assuming the unit has now worked to this point, you should be able to put it back in the water and it will return to normal operation from this point on.
If it still won't run; it runs a few moments and quits the self-test; or runs continuously, contact us thru the Dolphin service form along the bottom of our home page at www.arrowpools.net.
on Dec 16, 2009 | Dolphin Maytronics Diagnostic Robot...
2001 Dodge Ram 1500 truck smoke coming from vents
SEE IF YOU HAVE A SLIGHT OILY FILM ON THE INSIDE OF THE WINDSHEILD. IF SO THE HEATER CORE IS LEAKING
Dec 19, 2014 | 2001 Dodge Ram 1500 Truck 2WD
My robo kleen is oily
that is pool water mixing with some kind of lube
take off the metal plate and drain plug
let water drain out
Sep 05, 2013 | Smartpool Dolphin Robo - Kleen Above...
Aquabot Dolphin pool cleaner... stalls in pool ..have to shut off electriicity for a few minutes and it will start again...does this many times during cleaning cycle.
John
Sep 21, 2010 | Smart Pool Inc Dolphin Diagnostic...
Dolphin pool cleaner stops working after a 15 to 30 minutes. Even though the cycle time is set to 8 hours. How can I fix ?
It sounds like you might have a problem with the impeller or drive shaft, which are both common problems with these pool cleaners. Clean around your impeller and your wheels, axles, etc. If these do not cure your problem, it is probably an issue with your electrical system.
Jul 30, 2010 | Dolphin Maytronics Advantage
Jun 14, 2010 | Dolphin Maytronics Advantage
Dolphin pool cleaner won't go up to top of the pool , only half way up the wall
Jul 03, 2009 | Dolphin Maytronics Diagnostic Robot...
Dolphin Commander goes forward 2' then back 2' then stops.
The impeller motor is likely worn out. New motor units are expensive but less so than a whole new unit. You can send it to us in Michigan at www.arrowmotor.net or find a closer service center using www.maytronicsus.com Good luck.
Jun 14, 2009 | Smart Pool Inc Dolphin Diagnostic...
Irregular idle
More info please, I do not know where to start, when it comes to diagnosing this situation.
Aug 09, 2008 | 1992 Toyota Corolla
Dolphin Maytronics  Advantage Logo
144 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
