Question about Canon ZR85 Mini DV Digital Camcorder
I have a canon digital video camcorder NTSC ZR85. I am unable to charge the battery. I have changed the battery but still there is no charge for the battery. I am unable to see the charging light. What are the reasons for this?
    Genius:
  • 1,812 Answers
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Posted on May 25, 2011
SOURCE: Canon ZR85 camcorder won't turn on
Steps for removing the tape from a totally dead ZR85:
1. Turn camera upside down.
2. Move "Open/Eject" button to full right position (toward lens).
3. Manually push tape door open.
4. On the metal surface that sits between you and the tape, there is a very small screw. There is probably a yellow sticker next to the screw that says "Do not press on this part". With a small jewelry phillips screwdriver, remove that screw.
5. Push the metal plate (with tape) in the direction ofr the door and lift slightly. The metal assembly holding the tape comes loose, exposing the top of the tape.
6. Pull the tape upwards (out of the camera). At this point, the tape will still be engaged in the play heads. With the cartridge out far enough to see the heads, reach in with your jewelry screw driver and carefully lift the tape over the heads, and free from the camera.
7. Use the eraser on the end of a pencil to wind your tape back into the cartridge.
8. When re-assembling the mechanism in the camera, there are two curved slots on both sides of the piece you took loose. You'll need to thread these onto two posts inside before you place the top back in position and put the screw back in.
Posted on Sep 02, 2008
  • 5 Answers
SOURCE: How do I transfer a recorded tape to my computer
You need IEEE (Firewire) or "DV" cable to transfer video from the camcorder to your computer. The connection is "DV" and is located on the front of the camera next to the "S" port. The marketing for this camera was deceiving...most customers thought they could hook up the USB to their computer and upload video...well you can't
Posted on Feb 10, 2009
SOURCE: ZR85
Hi! If you go to the Canon, they have a trouble shooting section. I copied and pasted some information below. Good luck!
Details Print Friendly Version Issue: How do I transfer video tape recordings to a computer via Firewire?
Solution: Transferring video recordings to a computer ZR80, ZR85, and ZR90
Transferring Video Recordings to a Computer You can transfer recordings to a computer using the IEEE1394 (DV) terminal. With the ZR85 and ZR90 transferring video recordings via USB is not possible.
Before starting the video transferring, make sure to prepare the following:
  • A computer equipped with a IEEE1394 (DV) terminal or a IEEE1394 (DV) capturing board (the IEEE1394 protocol is frequently also called "Firewire" or "iLink").
  • A DV cable (sold separately)
  • Video Editing Software
You can use (1) the video editing software that came bundled with your computer or video capturing board, (2) the video editing software included with your operating system ("Windows Movie Maker" with Windows Vista Home Premium, Windows Vista Ultimate, Windows XP and Windows ME, "iMovie" with Mac OS 9 and later), or (3) video editing software purchased separately, with features ranging from very basic to very sophisticated.
  • The appropriate driver
A driver is included with Windows operating systems later than Windows 98 Second Edition and Mac operating systems later than Mac OS 9. The driver is installed automatically when you connect the camcorder to the computer. No additional driver is necessary or available.
  1. Start your computer.
    (If this is the first time you are connecting the camcorder to your Windows based computer your computer will display the "New Hardware Found" message while the driver is installed automatically.)
  2. Set the camcorder to playbackicon.gif mode.
  3. Connect the camcorder to the computer with the DV cable as shown below. Once the camcorder and computer are connected together the camcorder will display "DV IN" on the LCD/viewfinder. This message confirms that the camcorder is ready to receive or transfer video.
  4. Refer to the instructions for your video editing software to download your video from the camcorder.
    Note: Because procedures for digital editing software applications vary greatly, Canon cannot offer any additional support or suggestions regarding downloading and editing your video. Please refer to the software publisher or your computer manufacturer (if the software came with your computer) for assistance in using the software.
  • Operation may not work correctly depending on the software and the specifications/settings of your computer.
  • If the computer freezes while you have connected the camcorder, disconnect and reconnect the DV cable. If the problem persists, disconnect the interface cable, turn off camcorder and computer, turn camcorder and computer back on and reconnect them.
  • Before connecting the camcorder to the computer using a DV cable, make sure that camcorder and computer are not connected with a USB cable, and that no other 1394 device is connected to the computer.
  • We recommend powering the camcorder from a household power source while it is connected to the computer.
  • Refer also to the instruction manual of the computer.
  • The programs ZoomBrowser EX and Image Browser included with the supplied CD-ROM are intended for use only with images recorded on the memory card.
  • Video recordings on the tape cannot be transferred to the computer using the software included with the supplied CD-ROM.
Posted on Feb 13, 2009
SOURCE: won't power with AC or Battery...no charging light...how can I get tape out.
ZR85 WILL NOT TURN ON WIT OR WITHOUT BATTERY?
Posted on Mar 08, 2009
  • 8 Answers
SOURCE: Cannon NTSC ZR85 is unable to record video but can
canon has released a service advisory for this condition, its a bad ccd connection, and is offering to fix at no charge. contact canon in your country for details
Posted on Oct 28, 2009
Canon zr85, battery won't charge
It sounds as if your battery is shot. If it does it with any battery then that's not the case, of course, but a Batteries Plus store can test it for you or you can just order a replacement from Amazon. I've had good luck with Wasabi Power replacement batteries from Amazon.com.
Apr 21, 2014 | Canon ZR85 Mini DV Digital Camcorder
How do you transfer video from a canon ntsc zr85 to a computer?
Go to this link. In the search window in the center of the screen, type "upload video to computer" and click on the Search button. There are several options to choose from regarding pointers and instructions. Note that video can only be transferred by Firewire, so you need a Firewire cable, a computer that is Firewire compatible, and software on your computer that can edit video. (The USB cable and the software that came with your camera can only handle still images you take with your camera, stored on the MMC/SD card.)
Mar 29, 2010 | Canon ZR85 Mini DV Digital Camcorder
My canon ZR85 Digital Video Camcorder will not record and you can not view anything through the viewfinder or on the screen. Both are black. I can play tapes but can not record anything.
I had the same problem and canon fixed it no charge,there was a recall on this check out the link and follow the instructions
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=227&modelid=9739&keycode=2112&id=48266
Feb 06, 2010 | Canon ZR85 Mini DV Digital Camcorder
Cannon NTSC ZR85 is unable to record video but can view tape on the mini screen. The camera works fine but the screen is blank/black and mic still picks up sound. Would you know a solution
Oct 07, 2009 | Canon ZR85 Mini DV Digital Camcorder
When I turn on My camcorder, it only shows colored stripes
canon has released a service advisory on these camcorders and is currently repairing them free of charge if the problem is related to the ccd. contact canon in your country to request a repair
My Canon ZR85 has no light in the view finder for recording images. It will play back tapes, but no images when you want to record. Battery is fully charged.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Jan 12, 2009 | Canon ZR85 Mini DV Digital Camcorder
NTSC ZR65 MC
can this camcorder (canon ntsc zr65 mc ) can the video be downloaded to my mac laptop?
Jan 28, 2008 | Canon ZR65MC Mini DV Digital Camcorder
Not able to record the image
I had a similar thing happen to me...the video would not come one when I turned it on, but the audio would work, and it would play back tape fine. I happened upon the following solution (though I don't know how long it will last). I charged the camera, and then noticed it worked fine when the charger was plugged in. As soon as I unplugged it, the video would go black. So...I plugged it in, turned it to record, and unplugged it, and it worked! Almost like something got reset. I have no idea how long this will last, or if it means the battery is going...but, give it a try!
May 06, 2007 | Canon ZR85 Mini DV Digital Camcorder
Canon ZR85 Mini DV Digital Camcorder Logo
124 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
