Question about Refrigerators
Amana ARB2214CW: Too cold at the lowest setting
This bottom freezer Amana worked fine for 5 years. Couple days ago it decided it would set itself at TOO COLD, even though we have it on the warmest setting (1).  This is happening at both the fridge and the freezer area.  Is it the regulator/thermostat unit? If so, is it too hard to be replaced by a handy guy (poor husband!)?
5 Suggested Answers
SOURCE: Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Posted on Dec 10, 2007
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
  • 2468 Answers
SOURCE: Amana ARB2214CW Bottom Freezer Refrigerator
the ptc overload relay on the compressor is bad and needs replacing unplug it off the compressor body and get an exact replacement for your model
Posted on May 29, 2011
ARB2214CW freezer not cold Set At coldest over night no change to temp.
It could be to cold , sometimes the Freon coils will freeze and that will make it not be as cold so turn the freezer down all the way or un plug for a day or so to let those coils defrost then turn it up again.
Dec 17, 2011 | Amana ARB2217CSR Bottom Freezer...
I have an Amana Refrigerator. It is a double door on top and a pull out freezer on the bottom. The freezer is working fine. The refrigerator light comes on but it is not cold and my fresh food is fading...
either the evaporator fan in the damper vent door isnt running to push cold air from the freezer up into the refrige compartment or the damper vent door between the freezer and refrige section is frozen shut and cannot open to allow cold air flow,you need to access the evaporartor coil in the freezer rear wall and check both the fan and door movement
Mar 22, 2011 | Amana Refrigerators
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
Aug 26, 2009 | Amana AFB2534DE Bottom Freezer French Door...
Amana ABD2533DEB Bottom Freezer - Fridge not working
Sounds like the circulating fan is either gone or is going bad. This problem is hard to diagnose because sometimes the fan will run but not fast enough to circulate the air through the freezer and refrigerator. I would have your repairman look at this or if you have the know how then you can order the fan and replace it yourself.
Aug 22, 2009 | Amana ABB1927DE Bottom Freezer...
Amana DRB2201CW refrigerator does not get cold
You may have an obstruction in the air vent from the freezer compartment to the frig .there should be an airflow adjustment next to the thermostat. Middle setting is recommended. Since you say the freezer is working properly, I cannot see any other possibility. hope this helps.
Jul 28, 2009 | Amana ARB2257CSL Bottom Freezer...
Freezer works fine, fridge don't
your inside fan has stopped working.  Could be stuck or frozen or simply bad.
Mar 13, 2009 | Amana BC21V1W Bottom Freezer Refrigerator
FREEZER KEEPS ICING UP
lol.. welcome to my world... I have my fridge set at the lowest without turning it off...IT FREEZES a gallon of tea in 5 days!! My freezer ices some.. its set at 3..(1-6).. BUT I like keeping frozen foods FROZEN.. I deal with the ice...
I have asked several repairmen.. they just guess...I am NOT going to spend money for something that is a GREAT Frig/Freezer.. better than TOO HOT and ruining food!!
Sep 24, 2017 | Amana ARB8057CSL Bottom Freezer...
Amana bottom freezer working fine but refrigerator not/ warm since 24hrs.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Apr 28, 2008 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
