Question about Dell 948 All-In-One InkJet Printer
Auto play on Windows XP stopped working. - Dell 948 All-In-One InkJet Printer
  • 218 Answers
Follow these steps:
Control Panel/Administrative Tools/Services/Shell Hardware Detection/Return this service to Automatic.
Start/Run/Gpedit.msc/Computer Configuration/Administrative Templates/System. Check your settings in the right pane for Turn Off AutoPlay (and modify).
Start/Run/Regedit
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet\Services\Cdrom. AutoRun = 1
Posted on May 23, 2011
My seagate freeagent goflex 1tb hdd appearing as local disk in my computer... the autoplay dialog window doesn't come up when the drive is connected..
AUTO PLAY DIALOGUE IS OFF IN YOUR OPERATING SYSTEM
ENABLE AUTO PLAY
WHAT OS YOU ARE USING
OR CHECK BELOW LINKS
Windows 7, Windows Server 2008, Windows Vista, Windows Server 2003,or Windows XP
Fix it for meTo disable or enable Autorun automatically, click the appropriate Fix this problem link. Then, click Run in the File Downloaddialog box and follow the steps in this wizard.
Disable AutorunEnable Autorun
Fix this problem
Fix this problem
Oct 29, 2013 | Seagate FreeAgent GoFlex Desk - 1 TB...
How to install windows xp in toshiba qosmio f30-112
If the Notebook cannot find the device driver it is looking for then use this restore disk for an easy solution.
WINDOWS IS NOT ON THIS RESTORE DISK
This restore disk will only work for use with Toshiba Qosmio F30-112. This restore disk contains every driver for the Toshiba Qosmio F30-112.
http://restore-disk.com/shop/CartAdd.asp?ID=149816
Toshiba Qosmio F30-112 XP ... windows XP restore disk is a one stop solution. The Qosmio F30-112 drivers in ... Toshiba Qosmio F30-112 XP Notebook plug and play will install ...
TOTAL: $15.92
hope this helps
Sep 12, 2012 | Toshiba Qosmio F30-112 Laptop DC Car...
Microsoft Windows XP...
All disk drives are auto play & some other problems............
Aug 24, 2010 | Microsoft Windows XP Professional
I can not setup windows xp in my dell latitude e6400 laptop.I set BIOS (F12), select "System Configuration", "SATA Operation" and i change it from "IRRT" to "ATA. But no work.When i start windows xp setup...
Try this hints:
1.Press F2 to enter BIOS on start up
2. Expand Drive section
3. Go to SATA Operation
4. Check and change from Raid Auto/ AHCI to Raid Auto/ATA
Good Luck
Apr 11, 2010 | Dell Latitude E6400 Laptop
I am looking for a monitor driver for Windows Vista for LT1919
Windows XP and Vista should "auto-detect" the capabilities of this LCD screen.
If not, access http://WindowsUpdate.Microsoft.com
and scan for updates.
When the scan is done, look for "optional hardware" updates.
If Microsoft has a driver, it will be offered for download.
Nov 20, 2009 | Mag Innovision Computers & Internet
Hard drive failure required rebuild of XP Home on Dell computer. XP Home updated to SP3. Canon Multiplass F80 printer will not now work. I downloaded latest XP drivers from Canon web site, but installation...
I found that some Windows Plug and Play services were note running and were set to start 'manually'. I started those services which seemed related to Plug and Play, and the installation went without further errors.
May 11, 2009 | Canon MultiPASS F80 All-In-One InkJet...
My 7vRx can not start Windows...!?
Did the computer work normally after getting it back from the repair technician? Although there are other causes, the symptom that you state (stops at stage of starting Windows setup) may indicate a memory problem. Download memtest86 and run it from boot.
Also. you may have conflicts betwen the cpu and memory. If you set the system switch on the motherboard to 133MHz, you should check your BIOS (under Hardware Monitor and misc.setup) to see if the CPU Host Clock is set to 133MHz. Also, set the CK_RATIO dip on the motherboard to "auto".
Another thing to check in BIOS is the interupt mode...set it to APIC. The PIC setting will hang on XP. Don't forget to save changes on exit.
Your BIOS may be corrupted. When in BIOS, check to see if you are running main or backup. If it's running backup, use the AUTO RECOVERY feature to restore the main BIOS.
Your problem might be solved by just re-setting the BIOS by selecting "LOAD optimized defaults" on the main page.
There may be other solutions, but try these first. Please don't rate this post until we explore other possiblities.
Feb 07, 2009 | Gigabyte GA-7VRX Motherboard
Non-compatable software
Right Click Driver Installation, (open cd rom, not auto play) and click properties. on the tab click run in compatibility for and select xp. it should work. This works for multiple products.
Jan 07, 2009 | Nikon Coolpix 2000 Digital Camera
Dvd drives on my windows xp computer stopped working
You could try to reinstall the drivers for the DVD Rom Drive, If that dosent help you will need to replace it My favorite site as far as prices go is tigerdirect.com
Nov 25, 2008 | Computers & Internet
Dell 948 All-In-One InkJet Printer Logo
44 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
