Computers & Internet Logo
Posted on May 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Pny GeForce GTX 550Ti PCI express graphics card that is not being recognized by a ecs GeForce6100PM-M2 V:3.0 motherboard. Only fan runs.Bios date is 06/14/2010. Found this faq on ECS web site, " Question When you are trying to use a PCI-Express ATI graphic card and boot up to display from this device and then found no display output at Windows XP mode. Answer Please update BIOS to version 09/09/08 which can fix no display output from external PCI-Express ATI graphic card at Windows XP mode ,please visit the following website for downloading it." Can't find referenced Bios.
Azrael SRL
Level 3:
  • Master 11,800 Answers
  • Posted on May 23, 2011
Azrael SRL
Master
Level 3:
Answers
11800
Questions
0
Helped
2566775
Points
35672
Your video card is an NVidia, the BIOS error is not related to your problem.
First of all make sure the card is good - have it tested by the shop that sold it to you - they just put it in another pc and see if the pc boots with it. If it is then either the card has been improperly seated in the socket or the power source is incapable of delivering the 300 watts needed by this card - assuming that you have plugged in the power connector in the card.
Reseat the card and if this doesn't fixes it replace the power source wit one delivering at least 550 watts real.
1helpful
GTX 550ti No Video or response
then cross test YOUR card in other computer because it might be dead...
lucky that your motherboard is fine...
all those devices are so sensitive... sometimes they die you don't even know why...
Is not Reading My Geforce GTX 260 Card
What do you mean connect wire to graphics card?
A) Computer is to be OFF when connecting a monitor cable.
B) Computer is to be OFF, and unplugged from power; when plugging the power cable from Power Supply, into it.
You are also supposed to be Following Anti-Static Precautions.
What Power Supply are you using?
Manufacturer name, and model number. Post back in a Comment.
Motherboard requires about 150 Watts by itself.
That isn't including what the Processor (CPU) needs, Ram Memory needs, optical drive/s need, computer case fans need; AND what the Nvidia GeForce GTX 260 graphics card needs.
It needs 225 Watts by itself.
(Manufacturers usually state around 500 Watts MINIMUM.
This is in reality based on a COMPLETE computer system, and NOT just the graphics card itself)
What do I base that the GTX 260 needs 225 Watts?
(I see that as the -> Maximum, though )
A PCI Express x16 expansion slot on a motherboard, is only capable of 75 Watts of power.
That is why the additional power cables were brought out.
The 6-pin PCI Express power cable that plugs into the GTX 260, is capable of an additional 75 Watts of power.
The Nvidia GeForce GTX 260 requires using TWO 6-pin PCI Express power cables
That means 150 Watts of additional power.
75 Watts + 150 Watts = 225 Watts
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-260/specifications
"Supplementary Power Connectors -> 6-pin x2"
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
If you are using just one 6-pin PCI Express power cable, '
this = NO.
NOT enough power for the graphics card.
What will happen?
A) The PCI Express x16 slot connector oins, will burn
B) The gold plated contact pins on the bottom of the graphics card, will burn.
C) The connector on the graphics card, that the 6-pin PCI Express power cable plugs into, will burn.
D) The connector on the 6-pin PCI Express power cable will burn.
The graphics card will burn up.
Too little power.
IF, your Power Supply has enough power, and IF there are two 4-pin Peripheral power cables that aren't being used; you can use a 6-pin PCI Express power adapter cable.
Example of 4-pin Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Example of 6-pin PCI Express power adapter cable, was shown in the Playtool link,
http://www.directron.com/pci03.html
(Connectors are white, and hard to see against white backdrop. You can enlarge all 3 views)
For additional questions please post in a Comment
Regards,
joecoolvette
Is p4c800 deluxe compatible with an nvidia geforce gtx 550 ti (1 Gb)?
The Asus P4C800 Deluxe motherboard uses an AGP expansion slot, for a graphics card, Jorgito.
http://www.asus.com/Motherboards/Intel_Socket_478/P4C800_Deluxe/#specifications
The Nvidia GeForce GTX 550ti graphics card is a PCI Express graphics card. Uses a PCI Express x16 expansion slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=356682&CatId=3669
No sir, is the answer.
A) http://en.wikipedia.org/wiki/AGP
B) http://en.wikipedia.org/wiki/PCI_Express
You need an AGP 8X graphics card.
Here is but one example,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161337
You also need to look at what your Power Supply maximum rated Wattage is. Then look at the system requirements for the graphics card, and see what the -> MINIMUM power supply requirement is.
For the above graphics card it is 400 Watts, OR greater.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007709%20600007850&IsNodeId=1&name=AGP%204X%2f8X
For additional questions please post in a Comment.
Regards,
joecoolvette
[ Just for edification;
http://computer.howstuffworks.com/motherboard.htm
http://computer.howstuffworks.com/graphics-card.htm
http://computer.howstuffworks.com/3dgraphics.htm
1helpful
Does the MSI K8n NEO4 Platinum SLI motherboard support the Geforce GTX 550 Video Card?
The MSI K8N NEO 4 Platinum Edition mobo, has an AGP graphics expansion slot. (Accelerated Graphics Port)
It uses AGP graphics cards that are either 4X, or 8X. (Supports 1.5 Volt AGP graphics cards, hence 8X)
http://www.msi.com/product/mb/K8N-Neo-Platinum.html#/?div=Detail
Click on the Specification tab. Look under the bold - Slots - subheading.
(Overview, { Which is the tab it automatically opens to}, Specification, Download, Support, News and Awards, Where to Buy )
This is Evga's version of the Nvidia GeForce GTX 550,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625
Click on the Details tab. (Overview, Details, Feedback)
Under the bold - Interface - heading, and to the right of the subheading - Interface, we see the interface is - PCI-Express 2.0 x16.
Tells you a lot right off the bat, if you know what you are looking at.
1) The graphics expansion slot you need on your motherboard, is a PCI-Express x16 slot.
You have an AGP graphics expansion slot. (That uses either 4X, or 8X AGP graphics cards)
2) The PCI-Express technology used is PCI-Express 2.0
Therefore the answer is No, Stephen.
[ More info on AGP graphics technology, and PCI-Express technology,
1) AGP:
2) PCI-Express:
Now if someone asks you, why the GeForce GTX 550 graphics card will not work on your motherboard, you can explain why in detail, instead of just saying some dude/dudette on FixYa, said it will not work.
Are you sure some 'Mom and Pop' computer store will not trade out, a decent AGP graphics card, for the Nvidia GeForce GTX 550 you have?
Always worth a shot. Just MHO.
Regards,
joecoolvette
[ For additional questions please post in a Comment ]
Will GeForce GTX 550 Ti fit with Gigabyte GA-MA74GM-S2 mobo
This GeForce graphics card connects to a PCI-Eexpress 2.0 x16
and this Gigabyte has a PCI-Express 16 expansion slot which is compatible with the GeForce graphics card.
You may need to disable the on-board graphics card in the BIOS.
Nvidia asus gtx 570
is your power supply giving the card enough juice?
5helpful
2answers
I have a P5VD2-MX motherboard, currently I have a Geforce 7900GS.
Hi!
Since there is 1 PCI Express x16 slot you can use any PCI Express GPU, like Asus GeForce GTX 260 896MB PhysX CUDA, EVGA GeForce 9800GT 512MB PhysX CUDA, Gainward GeForce 9800GT 512MB PhysX CUDA or whatever you want as long as it is a PCI EPRESS card.
Good luck
Nic
1helpful
GeForce 8800 GT graphics card no display
what motherboard do you have it maybe your motherboard is only up to PCI-E 8 and the card is PCI-E 16 if it is it will not work
Top PNY Computers & Internet Experts
Larry Ng
Larry Ng
rosefresh
rosefresh
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
