Question about Fujitsu LIFEBOOK P1510D Tablet PC
Numbers typed with letters
I have a Lifebook 1510d. Recently began adding a number each time I type the letters i and e . Any suggestions appreciated
    Problem Solver:
  • 11 Answers
What Operating system have you got?
Try resetting your regional settings in Control Panel.
Have you dropped it accidently?
Posted on Aug 15, 2008
6ya staff
SOURCE:
My nook will'not change to numbers.stays on letters.any suggestions?
I assume you mean the Nook keyboard doesn't allow switching between numbers and letters. The built in Nook keyboard isn't the smartest or only keyboard app out there. Now that it's totally free strongly recommend you go into the Google Play Store and install SwiftKey. One hour using it and you'll wonder why you ever put up with Barnes and Nobles chunky idea of a keyboard. Even Google itself has their own keyboard app. You can have multiple keyboard apps installed at the same time. Just use the Switch Keyboard option to toggle between then.
As far as SwiftKey is concerned one of the main features that first sold me on it is it can be resized. I always hated the Nook keyboard just took up so much of your available screen space leaving so little for the input area. Did you know SwiftKey can be setup to show a numbers row at the top just like a regular PC keyboard? Also it can learn your typing patterns over time and predict the most likely word you will use next. Just click the word in the predictions bar.
Jan 22, 2015 | Barnes & Noble Nook Tablet
How do i use recovery cd's if i have no cd rom drive? i have an external cd/dvd drive plugged into usb port but the fujitsu 1510d lifebook does not recognise it? thanks dave
When you boot your computer, start up your BIOS, then under the boot menu, make sure USB is listed as the 1st option.
To log into your BIOS, press the "Boot Option" key. It might be F1, F2 or Delete
Feb 28, 2011 | Fujitsu LIFEBOOK P1510D Tablet PC
My Fujitsu Siemens Lifebook t4220 is working fine overall. However my pen which was working fine will not function at all. Please advise on what I should do to ge it working again. Padraic.
Sounds like the pen packed up, they do that but normally become intermittent first. Without a source of another pen to determine the nature of the fault, may I suggest a modest solution.
A pen that will function and also be an acceptable fit in the slot is available on eBay, - See - # 140504970431. A good price, and an exceptional supplier. At least it will confirm a pen or a screen problem.
Should you have an original (or copy), of the System Restore disk, I would appreciate you getting in contact, mine got trashed. Paul W.
Jan 05, 2011 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
I need a factory service manual for the T3010D...Anyone know where one can be found?
I have this site to start with, I did not have your serial number but you will need it to type in the text box.
http://support.ts.fujitsu.com/com/support/manuals.html
Jan 12, 2010 | Fujitsu LifeBook T3010D Tablet PC
Fujistsu T4215 no POST, numlock blinks
You need to send it to Memphis, Tn for a factory reset, call the Fujitsu 800 number on there web site and have your serial number handy.
Don't disassemble a Fujitsu!! Ever!
They automatically lockup as a security precaution, aren't you glad you saved some money?
Oct 07, 2009 | Fujitsu LifeBook T4215 Tablet PC
Keyboard not recognized
could be stuck in number function mode, or the keyboard has just got bad all together,
might need replacing.
plug in an external keyboard, to be sure, the cpu/motherboard could be bad.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 10, 2008 | Tablets & eReaders
Notbook is crashing
Hi.
This could be as simple as a loose or poor connection somewhere. There are a couple of things that I would look at. Firstly, try another ac mains adaptor incase the power lead is intermittent. Next you could look at the power socket on the back of the laptop. These can play up and sometimes are responsible for poor connections. The above will be made worse if you have removed the battery or if the battery is old or poor. Put a decent battery in and keep it charged even if you are using a power adaptor. If there are breaks in power the battery will act as a reservoir and prevent dropouts.
You say that it crashes when you move it, is it ok when you leave on a table and operate it?
The only other thing I can think of is that there could be a loose connection inside the unit. I would check out the connection ribbons before pulling out chipsets or motherboards. Good luck..
Dec 30, 2007 | Fujitsu LIFEBOOK P1510D Tablet PC
Fujitsu LIFEBOOK P1510D Tablet PC Logo
178 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
Rachid Mekrob
Rachid Mekrob
Level 1 Expert
Tony Raia
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
