Dont dark sector game menu on my computer - Computers & Internet
If when run my game 'dark sector' it says that the application cannot open(0xc000007b). Why it says like that and tell me a solution to run my game and play it. please post a better solution...
The best solution is to do as the game tells you. It knows the exact spec of your computer, but, you haven't told us the make or model number of your computer, so we can't help!
Aug 10, 2013 | Computers & Internet
No boot sector on internal hard drive. No bootable
A boot sector is a sector of a hard disk that contains booting programs stored in the other part of the hard disk. You boot sector might have been deleted or corrupted and you can't logon until you repair or recover the boot sector. To do this you must have your OS cd. Boot from OS cd the follow below steps...
Windows Vista
1. Insert the installation disc.
2. Restart your computer
3. If prompted, press any key to start Windows from the installation disc.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7.
On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Boot from you hard disk then you're done!
Regards,
Jeep Brainy
Jul 29, 2009 | Dell Inspiron 6000 Notebook
Missing mss32.dll from computer in alone in the dark the new nightmare
Hey,
you can download this dll file from the following link
http://www.dll-files.com/mss32.zip?0WEkSBULeV
you can put this DLL file in the directory where you installed the game. and also in System32 directory C:\Windows\System32
Hope this helps
Cheers!
Feb 05, 2012 | Infogrames Alone In The Dark 4: The...
My transcend storejet has bad sectors.. what should i do to prevent it from getting worst?.
These sectors can be fixed.
  1. For Windows
    • 1 Double-click on My Computer to open the My Computer window.
    • 2 Select the disk that you want to diagnose and repair.
    • 3 Choose Properties from the File menu. You should see the Properties window for the drive that you selected.
    • 4 Choose the Tools tab.
    • 5 Click the Check Now button under Error Checking Status.
    • 6 Depending on your version of Windows, choose either "Thorough" or "Scan for and Attempt Recovery of Bad Sectors."
    • 7 Click on Start.
Read more: How to Fix Bad Sectors on a Hard Disk ' eHow.com http://www.ehow.com/how_113636_fix-sectors-hardfix-sectors-hard.html#ixzz1PeS42ET5
Jun 18, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Menu keeps jumping
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
dont forget to vote
hope this helps
Feb 02, 2011 | Gigabyte GA-EP45-UD3P - Motherboard - ATX...
I cant play warhammmer 40k dow dark crusade!!! plz help
is your graphic card up to date with the requirements for the date, not sure if it will solve your problem, just a suggestion at something to look at.
Aug 24, 2009 | THQ Warhammer 40,000: Dawn of War - Dark...
DarknessEngulfs Xbox360 g@m3r t@g
you can not change the area code on your xbox 360
Jan 28, 2009 | Microsoft Xbox 360 Console
Logik 17 monitor
The monitor came with 1 dead pixel in the bottom right hand sector but this is within the spec for most TFT's.
Dec 17, 2008 | Star Logic 17" LCD Monitor
Window boot manager
hi Some laptops (actually most to all ) have a partition on the master drive called a restore sector. What you can try to do is restore from this sector. To do this all you have to do is boot from that drive :) (dont worry it aint complicated) When you turn on the laptop it ask you to press a certin key to enter boot menu menu usually F9 F10 or F11 press it and then select the second part of the Local Disk it sould look like Drive 0-1 or 0-2 well you will see it the first will be the normal boot the second the Restore sector. If that dont work or it aint there simply borrow a windows disc from a friend. Dont worry it aint going to do a full install. it will detect the disc and then repair it self and boot normally. Then you may remove the disc and return it.
If you need further help please contact me.
Nov 13, 2008 | Compaq Presario 700 470024-192 Notebook
Nintendo DS lite power light comes on but both screens stay dark?
When you boot the Nintendo DS you can change the illumination settings in the main menu.
One the main menu, you will find a sunny symbol in the lower left corner of the screen. Click on that and you should be able to change the level of illumination. If you are also wondering if you can change the brightness during game play, you can't. Games such as Mario 64 DS come with support for brightness change but otherwise you have to do it before game play.
Sep 20, 2008 | Nintendo DS Lite Console
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
