Question about Speed Queen Washing Machines
TOP LOADING SPEED QUEEN HAS BEEN WASHING FOR THREE HOURS AND WON'T STOP OR GO TO SPIN
  • relax338 May 23, 2011
    HOW DO I FIND A SERVICE AGENT IN MY AREA OBERON N.S.W.TO SUPPLY AND FIT THE NEW TIMER TO MY SPEED QUEEN WASHER MODEL NO EA2111WT3050
  • 4,399 Answers
Thanks for choosing FixYa and welcome. It sounds like your timer switch is not working to me. As you probably already know, this is what allows it to go to the next setting. The switch may be bad or it is possible that it is not getting power due to a loose connection or bad wire. Your control board may not be picking up the signal. It could be either one. I would suggest the timer switch first though. You probably need a new one.
Posted on May 23, 2011
I have a speed queen top loader washing machine it start with the washing sickle and the timer stop when it must start to spin or rinse and i replace the timer with a new one
There is sometimes a pause between wash and spin. This allows a little time to pump the water out before starting to spin. Do you hear the pump running between wash and spin?
Feb 01, 2017 | Speed Queen Washing Machines
My washing machine dont spin or drain water can you please tell me what to do and where about are the filter in then machine/
Either your drain pump is bad or something is stuck in it. It won't spin until it drains so fix the drain pump, and it will spin. You should be able to get at the drain pump by taking off the bottom panel, or back panel.
Jan 13, 2012 | Speed Queen AWS52NW Top Load Washer
After the spin cycle the clothes are still pretty wet
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 09, 2011 | Speed Queen AWS48NW Top Load Washer
Commercial speed queen won't speen fast enough clothes are still dripping wet I think its too sensitive is there an adjustment for that?
Try putting on a new drive belt. It may be that the belts are slipping and it won't spin fast enough.
Jun 27, 2011 | Washing Machines
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Will not start washing process
Is the belt broke?
If not, will it spin it you put it in spin mode?
If it spins, but not agitates, the transmission is locked up in agitation and needs replaced. This is a major undertaking.
Dec 12, 2009 | Speed Queen AWS51NW Top Load Washer
At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Mar 21, 2009 | Speed Queen AWS52NW Top Load Washer
Kelvinator or (Speed Queen Top Load washing machine)
You probably have the wrong belt, and its to small? Go to repairclinic.com or google Kelvinator parts. Order the correct belt.
Apr 15, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
343 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
