Question about Dell Inspiron 530 Desktop Computer
Pc wont start when turned on and the fan runs at high and it beeps 4 times
    Guru:
  • 825 Answers
The RAM in the motherboard is not seated properly, it might have slightly moved out of the slot or the physical contacts is not proper.It can happen while moving the cpu or may be due to any other shocks. Open the CPU tower. Remove the RAM and place it back in the same slot after dusting the slot. It will work for sure 100%
Please rate the solution and Write a testimonial, if my solution helped for u.
Posted on May 23, 2011
Turns on No display Lights flash 3 times
is it making a beeping sound?
if so check ram.
check the fan is running,if not clean it out.
try and start with the battery out,some laptops will run with out battery,if it does replace battery.
if it still wont start please get back in touch.
Apr 07, 2015 | Computers & Internet
My computer is beeping and wont start
try checking the ram,check the fan is running,check hdd,
give all a good clean up.
Apr 27, 2014 | Gateway GM5472 PC Desktop
Two beep sound with no display
- First of check is your RAM inserted in ports correctly?
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Start PC in safe mode.
- Download program PCFresher.
- Run its all tools.
Your problem will be solved.
Sep 02, 2013 | Lenovo ThinkPad Edge E430 Laptop Computer
Continues two beeps and wont boot
From the time it start beep it means either your ram or video card is not good. My recommendation would be checking to connections of the ram and the any other card you have installed on the motherboards or simply just dis connect them wait a couple seconds and connect them back properly and firmly.
KJR
Jan 10, 2013 | Foxconn Computers & Internet
Computer won't start up ,makes beeping for 4/5 times then fan kicks at super high speed . worked just fine in the morning and then moved to another room and this started..HELP
check that all your plugs are in the correct sockets 4 or 5 beeps indicates startup hardware error usually the keyboard. hope that helps. let me kmow how you go.
Dec 27, 2010 | Dell OptiPlex GX280 PC Desktop
WHEN I TURN IT ON, THE COPUTER STARTS BEEPING
that sounds. are memory problem related :
Beeps Meaning 1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU
May 10, 2010 | Computers & Internet
Acer Travelmate beeps 4 times & wont boot
Sounds like a RAM problem. Best bet is to purchase a stick of RAM from a store that will let you try it and return it if the problem is not solved. The beeping is a BIOS error code that signifies that something is wrong with your hardware.
If you have 2 sticks of RAM installed try removing one of them and then if the beep code happens again try to swap them out.
Sep 26, 2009 | Acer TravelMate 240 Notebook
Beeping then shuts down.
Hi Speedport!
This isn't something as simple as a dead / broken / malfuctioning battery is it ? Try removing your battery, plugging the laptop into the mains and running it idle. The Bios update you found may have been a coincedence...
David
Nov 19, 2008 | Toshiba Satellite A205-S4617 Notebook
Dell Inspiron 530 Desktop Computer   Logo
90 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
