Question about Sony 1GB Memory Stick PRO Duo Memory Card
Im wondering if formatting thr memory card has caused a camera to not pick it up. is there anything that can help with this error i've made
3 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: I have Sony 4GB MS PRO Duo Memory card. When I use
You can try to format it on your computer, but usually when this happens it means that the memory card is not any good and will need to be replaced.
Posted on May 27, 2010
  • 4961 Answers
SOURCE: sxs recycle virus problem
Download this, burn it to a CD, and run it to clean the viruses from your card:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Posted on Jul 24, 2012
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
My camera says the memory card is locked and memory card error appears when I turn on the camera. I've read that I have to format the card, but won't the photos be destroyed? How can I get my pictures
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it. DO NOT format the card until you've BACKED UP your files from it (typically to a PC or USB drive (stick or external hard drive).
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
Memory card is protected. Reset switch on memory card.
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position (but you've checked that already). The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Please note that the C633 is an older camera, and can only use 2GB or less standard SD cards. 4GB or higher SDHC will not work with your camera. Fortunately 2GB cards are relatively inexpensive these days, and may be easily found on Amazon if your local store no longer carries them.
Oct 28, 2011 | Kodak EasyShare C633 Digital Camera
Hi Sir My CANON A470 it shows memory card is locked & memory card error, most of the file are in it how should i retrieve it, i ve tried with new batteries also.My PC also doesn't support it
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Sep 17, 2011 | Canon PowerShot A470 Digital Camera
Why will my camera not format an 8GB memory card?
Some electronic devices, including cameras, come with its maximum manageable memory card. And when you use a memory card that's beyond the allowable size this might cause the device to not function properly or do processes/operations slower than normal. This is due to compatibility issues.
That's based on experience since i've tried to use a memory card thats beyond what my old camera model could handle and it made my camera slower in displaying preview, editing and in saving captured images.
I'm not sure if this is what causes your problem. Try it with a lesser memory card size. Also check your camera's user manual to see the memory card sizes that's compatible with the model.
If this doesn't work, i'm sorry i dont have anything else in mind to solve the problem. :)
Jul 27, 2011 | Kodak EasyShare Z760 Digital Camera
Card locked, have tried the slide on the card...no help. Bought a new card, same results
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link. And finally, if the cards that you've been using are 4GB SDHC, that's your problem.
Jun 13, 2011 | Canon PowerShot A630 Digital Camera
When camera is switched on, the screen show WRITE PROJECT above a KEY image. Camera is E1055W. I've no idea how this has been turned on and cannot find how to turn it off. HELP please. ...
The write protect tab is on the SD memory card itself. Just remove the memory card from the camera, find the little tab on the side of the card, and slide it to the other position. For others experiencing this problem, there are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 12, 2011 | General Electric E1055W Digital Camera
I have a V1003. It is saying memory card is protected (reset switch on memory card).
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card (which you said you've tried), or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
May 30, 2011 | Kodak EasyShare V1003 Digital Camera
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
Sony 1GB Memory Stick PRO Duo Memory Card Logo
63 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
