Question about Rinnai Heating & Cooling
Natural gas rinnai symmetry won't start and although infared light is on there is no pilot light
  • 124 Answers
SOURCE: natural gas fireplace, pilot lights
thermocouple is bad . replace it.
Posted on Oct 19, 2008
CRTN
  • 716 Answers
SOURCE: pilot light wont lit up
Change The Thermostat Cause If Your Getting Gas But The Water Heater Doesn't Detect The Heat It Will Close The Valve. When Lighting You Hold The Button Down For About 30 seconds so the thermostat will detect flame and stay lit. Check To Make Sure The Thermostat Is Where It Should Be. Heres A Picture Of What It Will Look Like.
You Can Replace Them If Need Be Will Be Available At Sears Or Home Depot. Also They May Sell Them At other Local Hard Ware Stores.
Happy Fixing And Thanks For Using Fixya.com
Sincerely,
Michael Scott
Posted on Jan 19, 2009
  • 4 Answers
SOURCE: rinnai natural gas log fire heater
12 is a fault code, look in the book if you have if, i think 12 is no or low gas pressure, cheers
Posted on Feb 05, 2009
  • 30 Answers
SOURCE: Hello! My rheem natural gas-powered
make sure the pilot light stays on. look for a reset button which could be an overheat stat tripped. check to see if the thermostat is set up above the pool temperature.
Posted on Mar 26, 2009
  • 53 Answers
SOURCE: Rinnai Convector 404 Natural Gas
No conversion parts available since 2005.
Posted on Jul 16, 2009
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Heat and Glo pilot light works but Burner won't go on. I messed with it and it started up but won't turn off. next day won't start but the pilot light is still on
light your pilot and take a light to the termopile (right beside your pilot it sticks out to get heat from your pilot. hold lighter for 5 seconds and turn gas on
Dec 08, 2012 | Napoleon 36" Zero Clearance Top/Rear Vent...
Pilot won't light
check gas pressure check safety circuit if ignitor lites check gas line to it maybe plugged
May 21, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
We have a Rinnai REH-15F-2A natural gas heater (approx 15 yrs old). it has just started going out, it doesn't leak gas. is this something repairable or beyond repair? thanks tameka
Tameka, what you described sounds like the Thermocouple or Thermopile is failing. If your heater is a Flue-less heater, the Oxygen Depletion Sensor (ODS) which is part of the Pilot assembly, may simply need cleaning. Any of the causes I listed are repairable and would require a service technician to do it.
Hope this helped you. Please let me know.
Jul 06, 2011 | Rinnai Heating & Cooling
Need pilot light assembly for Rinnai gas heater model #REH-25-P
Unfortunately, Rinnai only sells repair parts through their authorized dealers. Contact the dealer you purchased it from. If you are not the original owner of the home/heater, you can go to Rinnai's website and search for a dealer near you. http://www.rinnai.us/direct-vent-wall-furnaces/
Feb 28, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I want to convert to propane. Rinnai dont carry kkts for these anymore . . . . are there any way to convert these?
i want to convert one to natural gas from LPG would u like to swap the pilot assy and jets i cant find a conversian kit anywhere...
Apr 23, 2009 | Kitchen Ranges
Infared heater
When was the last time you cleaned the pilot? In your owners manual there is a cleaning procedure. If you can't find the manual, go to www.rinnai.us. You may be able to download one from their site.
Dec 18, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
61 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
