Question about Video Game Consoles & Games
My delta force starts but then tells that height map is of incorrect size and it stops
    Sniper:
  • 79 Answers
Have you installed custom maps? This happens sometimes when custom maps aren't installed correctly.
Posted on May 23, 2011
When i hooked up a delta faucet for a handicap tub i had to put it on the right side of the wall so that the older guy could reach the handle to turn the water on and he wanted the shower head closer
Not usually, but there should be an inverter or other unit to activate the shower. Often it is in the tub outlet and blocks the tub outlet to force water up the shower pipes. If there is no such or if it is just not working you may need to run the piping up to a sufficient height and then back down to the shower head to create enough pressure resistance if it is as you say, requiring a specific height of pipe to get a specific back pressure. But there also needs to be a mechanism to force the water up the shower pipe. Look up Delta on the web and get a phone number as there will be someone at Delta that can fully advise you about this.
Oct 04, 2014 | Delta Home
Tip
How To Remove and Install a MAP Sensor for Your 1988 Dodge Aries
REMOVAL & INSTALLATION
Chrysler Electronic Fuel Injection (EFI), Multi-point Fuel Injection (MFI) and Eagle Throttle Body Fuel Injection (TBI) Systems
  1. Disconnect the negative battery cable.
  2. Unplug the electrical connector from the sensor.
  3. If so equipped, disconnect the vacuum hose from the sensor.
  4. Remove the MAP sensor mounting fasteners.
  5. Remove the sensor from the vehicle.
To install:
  1. Install the MAP sensor into its position and secure in place with the mounting screws. Tighten the screws until snug.
  2. Connect the vacuum hose, if so equipped.
  3. Plug the electrical connector back into the sensor. Make certain that the connector is clean and snug fitting.
  4. Connect the battery cable.
on Nov 22, 2011 | 1988 Dodge Aries
Unable to find height map
Try looking under topology or elevation.
Aug 15, 2013 | NovaLogic Delta Force 2 for Windows
Cant run Delta Force :Black Hawk Down: polytrn color map not specified messasge
Hello
Could be a courupt install.
Try uninstalling and reinstalling the game.
Before you do.... check that your pc video device or graphics card will handle the game.
If so,dowload and install newest drivers for your video device or card.
Then reinstall game.
Jan 24, 2011 | NovaLogic Delta Force: Black Hawk Down...
When I play Irene in Delta Force Black Hawk Down it does not starts and one error comes '!polytrn color map not specified
I get the same error when i play Delta Force: Black Hawk Down:
First stage i.e., Marka Breakdown, i get this !polytrn color map not specified.
I tried to download the Dirext X 9.1 during the insallation of the game but it wouldn't and its a stand still.....
Any sggestion would be great.....:(
Jan 08, 2011 | NovaLogic Delta Force V: Black Hawk Down...
What is the use of wye delta?
I don't know why your question is bound to this special breaker.
If your question is common, the wye/delta is a way to reduce the starting current of a large three phase asinchronous motor.
When a three phase motor is first connected in wye (star), the starting (peak) current is about 3 times less than this in delta. When already in motion the electromotive force will make the peak current when turned in delta much less, than that with a stopped motor.
Aug 08, 2010 | RTO Telemecanique Gv2 Ls22 Magnetic...
Delta force not loading mission
it is a common problem,just reinstall the game,before this update Ur direct x.thank u
Mar 29, 2010 | NovaLogic Delta Force for Windows
My magnum delta force blows the higest amp fuse!!! (shorting out)
yes it sounds as if the diode has gone short curcuit. this is at the back or near the in put socket. the diode is black with a silver end. replace with same size this should sort it out.
May 14, 2009 | Magnum DeltaForce CB Radio
Video Game Consoles & Games Logo
101 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
