Question about Epson LX-300 Matrix Printer
On command to print with my epson lx-300+, message reads, "No Printer". When searched on fax and printer and double-clicked "Add Printer", a message came out saying, "It can't work because the printer spooler service is not running". How can I bring back the printer and make the spooler run? I have plenty to print. Thanks!
    Genius:
  • 1,447 Answers
Hi Basti here,
Try this...
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
Posted on May 23, 2011
I want printer driver for Epson lq-300+ for windows xp sevice Pack 3
windows xp already has driver for that
go to start, setting-printer and faxes- click add a printer
add wizard printer box will apear
click next
set yo local printer uncheck automativaly detect
click next the use following port lpt1
next again
then search epson and the printer model
then click next and next set print test page then next and finnish..
the driver will install..
Aug 22, 2011 | Epson Dot Matrix LQ-300+ Printer
How do i install an epson lx 300 printer to a vista machine using a parallel to usb converter? i can't locate nor create usb 001 port with the driver cd of the said printer.
1. Start
2. Settings
3. Printer and Faxes
4. Add a printer
5. then Next
6. then Next
7. then Next
8. then Next
9. select Manufacturer name : Epson
10. select Printer name : Epson LX-300
11. Next
12. Windows will automatically install the driver for your Printer
Jun 21, 2009 | Epson LX-300+II Matrix Printer
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
No print out
The printer driver maybe corrupted, go to Printers and Faxes and delete the printer then go Add printer and install the printer again.
Apr 01, 2009 | Epson LX-300+ II Matrix Printer
Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
I tried the solution pposted but...
How is it connected with a paralel cable? ..set to print from LPT1 (ports) and ensure you use epson lx 300 driver (downloadable)
Aug 02, 2008 | Epson LX-300 Matrix Printer
Problems installing a printer
what is your operating system? If you have windows XP or Vista, you dont need to download anything from Epson. Just go to your start menu and look for control panel. In control panel, open "printers and faxes" or "printers and other hardware" then "printers and faxes". Once you are in "printers and faxes" click Add Printer...
An "add printer wizard" will appear in a new window, click next...
On the next screen, choose local printer. And make sure that the option "Automatically detect and install..." is selected. It will start searching... If the wizard did not find the printer, it will come up with a list of manufacturers... From this list choose EPSON and a list on the right side will show you the model names. Look for the LX-300 on the list, it should be there! Install it and you're done... The driver is already included in the windows operating system. You dont need the disc if you have Windows Xp or Vista....
Jun 27, 2008 | Epson LX-300 Matrix Printer
Printing shows doubling
alguien por favor envieme los drivers de la impresora EPSON LX300 les agradesco
May 26, 2008 | Epson LX-300 Matrix Printer
You can follow the steps below to install a resident printer driver which is part of your operating system.
NOTE: Windows should detect and automatically install devices attached via the Parallel or USB ports on the computer. You should be able to attach the printer, and the "Plug and Play" feature will install the appropriate driver.
If the driver does not automatically install, please contact your Computer vendor. The "Plug and Play" feature may be disabled within your computer.
The resident driver installation should only be used if the printer is not detected and installed.
1. Start by opening the "Printers and Faxes" window. Click on "Add Printer" on the left hand side of the screen.
2. The "Add Printer Wizard" screen will come up. Click on "Next".
3. At the "Local or Network Printer" screen, select "Local Printer" and place a check on "Automatically Detect and Install my Plug and Play Printer". Click on "Next".
4. Windows should report it will check for Plug and Play hardware. It should also detect and install the appropriate resident printer driver.
5. A window will appear and tell you when the process is completed.
*NOTE: If Windows does not detect your printer automatically, you can manually install the printer. Simply select EPSON under manufacturer and select your appropriate model under PRINTERS.
6. When the printer is installed, it will ask you if you would like to print a test page. Check "Yes", then click on "Next".
7. The next screen will display the settings for the printer. Click on "Finish" to complete the installation and print the test page.
May 27, 2006 | Epson LX-300 Matrix Printer
Epson LX-300 Matrix Printer Logo
499 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
