Question about AudioCodes MediaPack MP-114-FXS Analog VoIP Gateway 4FXS SIP Router
Update firmware h323 for MP-114 FXS - AudioCodes MediaPack MP-114-FXS Analog VoIP Gateway 4FXS SIP Router
2 Suggested Answers
Mustgo
  • 2359 Answers
SOURCE: Hi, Here's my issue: a) I have
THIS is my recommendation. THIS IS FOR USA only.
THINK outside of the box!
1) Used Ethernet over power line boxes like Netgear.
http://www.netgear.com/Products/PowerlineNetworking/PowerlineEthernetAdapters.aspx
2) Find a working OLD PIII or P4 pc and set the ip to the same subnet.
3) Buy a MagicJack for $39.99
magicjack.com
4) Do the standard setup
5) connect Polycom 301 phone and use it.
Magicjack is SIP and it's $39.99 for package with 1 year service and $20 for the following year....
Posted on Jul 23, 2009
Cannot reset to factory default
Are you unplugging ethernet cable from MP? make sure you do otherwise factory reset will not work.
May 22, 2012 | AudioCodes MP-114-FXO - 0 FXS Ports, 4 FXO...
The LED Uplink do not work when i connect lan cable. Therefore i cant acces interface
Attempted to do a firmware upgrade previous to failure? that can cause a bricked MP. Use wireshark to see if there is any sign of life when connecting ethernet cable to the interface, if there is life on earth you may still have a chance to recover it.
May 27, 2011 | AudioCodes MediaPack MP-114 FXS
How configure proxy on mp114 fxs
Download your INI config file and search for ISPROXYUSED under [SIP Params] block, if is not there add the line as follows:
ISPROXYUSED = 1
Then search for ProxyIp 0 under [ProxyIp] block and if there is no line add it as follows:
ProxyIp 0 = your.proxy.ip.address, -1, 0;
This will set a unique proxy IP address for all the SIP outgoing traffic of your MP, if you wish to use more than one SIP Proxy you may want to consider setting IP address on Routing menu.
Feb 15, 2011 | AudioCodes MediaPack MP-114 FXS
I would like to connect an audiocodes mp 114 fxs to an Avaya Communications manager. The problem is Call sets up but no audio is heard. I also can not get the gateway to register with the avaya aura Ses...
Are you able to get a Wireshark trace from a mirror port of incoming/outgoing traffic for that MP? that way SIP session and RTP (audio) session can be analyzed and issue pinpointed. If no audio is arriving into MP no audio is expected to go out, if audio IS being delivered from the MP to the network, MP is doing its job. If audio IS getting into MP from network but no audio goes out further debug should be made, also if no audio is being delivered from MP to the network.
Jul 29, 2010 | AudioCodes MediaPack MP-114 FXS
I have a MP 202 can you tell me how to reset?
Unplug everything
Hold reset button down
plug power back in (with reset still pressed), wait 10-15 seconds and release
You should be able to log in as admin / admin now
May 25, 2010 | AudioCodes MediaPack MP-114 FXS
Need to reset to factory settings due to assigned IP address is no longer working
Unplug the network cable and hold in the RESET button (small hole on back of unit) with a paperclip for 6 - 10 seconds. The default IP is 10.1.10.10.
Feb 16, 2010 | AudioCodes MediaPack MP-114 FXS
My mp-114 dials 5252 when I access a line. Do you
You may have enabled the "auto dialing" feature and may have that destination configured. Please post your INI config file and I will be able to assist you further.
Aug 07, 2009 | AudioCodes MediaPack MP-114 FXS and FXO...
Way to reset mp-114 audio code to factory settings and configure
Unplug the network cable and hold in the RESET button (small hole on back of unit) with a paperclip for 6 - 10 seconds. The default IP is 10.1.10.10 sm 255.255.0.0 if it is an FXS
10.1.10.11 sm 255.255.0.0 if it is an FXO
May 16, 2009 | AudioCodes MediaPack MP-114 FXS
AudioCodes MediaPack MP-114-FXS Analog VoIP Gateway 4FXS SIP Router Logo
531 people viewed this question
Top AudioCodes Computers & Internet Experts
Are you an AudioCodes Computer and Internet Expert? Answer questions, earn points and help others
