Don't have the pass key for my metal gear solid 4 blue tooth. can't register it for my ps3.
  • 72 Answers
The default passcode for the Metal Gear Solid 4 Bluetooth is: 0000
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
Posted on May 23, 2011
Register my ear piece to a new ps3
go to accesory settings and go to manage your blue tooth then put in your pass key
Feb 27, 2013 | Mad Catz PS3 Bluetooth® Headset Wireless...
How do I get my bluetooth on my cell to pair with my playstation 3?
1st option: Here's what you'll need to do.
On the XMB on the PS3, go to Settings, then go to Accessory Settings, then Register Bluetooth Device.
Select Register Headset/Microphone/Headphones.
Press X to accept the 'Start Scanning' mode for the PS3. Then....
With the Motorola pairing can be clumsy. It involves pressing and holding the call button while the
microphone is folded closed, then quickly opening it up once the blue LED comes on.
2nd option: Hold down the answer call button on the bluetooth headset until the light is solid (not flashing). When the PS3 detects your headset, it'll ask for a pass. The pass should be "0000" (four zeros).
Aug 20, 2011 | Motorola Cell Phones
Kindly help me connect my samsung HM1100 bluetooth headset to my playstation 3
1) Go to "Settings" on your PS3.
2) Scroll down and select "Accessory Settings."
3) Select "Manage Bluetooth Devices."
4) Select "Yes" when the message "The Bluetooth device has not been registered. Do you want to register?" is displayed.
5)
Turn on your Bluetooth headset when asked by the message "To register (pair), you will need to prepare the Bluetooth device. For information on preparing the device, check the instructions supplied with the Bluetooth device." While each Bluetooth headset is different, for most this means to hold down the power button until the blue light on the device remains solidly lit.
6)
Select "Start Scanning" once your Bluetooth headset is in "pair" mode. Wait for the PS3 to scan for your Bluetooth headset. If the scan was successful, your Bluetooth headset will be listed on-screen. Select your headset from the list
7) Refer to the Bluetooth headset's instruction manual to find the pass key for your device (Usually the pass key is something simple like "0000" or "1234". Press "X" to bring up the on-screen keyboard and enter the pass key. Select "Enter" then "OK." "Register Completed" will display to confirm a successful connection.
NOTE: If the headset does not display after a scan, it may not be compatible with the PS3, or it is not properly set to "pair" mode. Refer to your Bluetooth headset instruction manual for directions to properly set your device to "pair mode."
If you want to check the User Manual for your Bluetooth, simply click on the following link:
http://www.samsung.com/us/support/downloads/BHM1100NBACSTA Click on the Icon below "File" Thank you.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
What is the pass key for 9xxPlantronics bluetooth to register to PS3?
most blue tooth manufactures of blue tooth devices use a factory 4 digit pin pairing code now the most common one is as follows but there is a possibility that i could be one of the others i will put them in order from most common to least commmon try them in that order they are 0000,1234,9999,or 1111 i hope this helps
Feb 26, 2011 | Plantronics - Bluetooth Headset Plus Base...
9xxPlantronics pass key to register bluetooth for PS3
to use the pass code for your blue tooth device you must first put the device into discovery mode then most blue tooth manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999. i hope this helps
I lost the instructions to my Metal Gear Solid 4 Blue Tooth for my PS3. I dont know the Passcode. I nead the passcode.
i looked around the web and i would try the default setting which is 0000
i hope i helped let me know how it works
Dec 30, 2009 | Video Game Consoles & Games
Blue tooth is not installing for the ps3
Registering
1) Go to accessory settings
2) Click on Register blue-tooth device
3) Click on Headset
4) Scan, while holding down the main power button on the headset
5) Enter your 4-digit password. The default is normally 0000
6) Done
Using
1) Go to Audio Options (under accessories)
2) Click "Connect Blue-Tooth device"
3) Change everything from "Do Not Use" to your headset name
4) Done..
Mar 31, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
For got pass key for my blue tooth trying to regster to new ps3
pass keys 4 headsets are normally 0000 or 1234 unless you've manually changed it. If so then you will have to go thru each number cycle from 0000, 0001, 0002, up to 9999. (",)
Jan 25, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
My ps3 won't play GTA 4 and Metal Gear Solid 4
This is what used to happen to me on my ps3 slim 160 GB when I put the disc in the screen goes black and int he top left corner I have a flashing disc, i updated the system to FW 4.00 and now the game works fine, i was previously running FW 3.73.
Oct 30, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
