Question about TP-LINK 300Mbps Wireless N ADSL2+ Modem Router TD-W8960N
We don't know how to connect the router - TP-LINK 300Mbps Wireless N ADSL2+ Modem Router TD-W8960N
  • TP-LINK Master
  • 32,281 Answers
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Posted on May 23, 2011
How to get a connection of WI fi when we don't have a password for it?
Why don't you have a password for it? If it's coming from your router you should know the password. If it is not coming from your router, then you are out of luck.
Apr 24, 2012 | Dell Computers & Internet
How do i reset the password to my 2wire router an connect a wireless laptop
Is your 2Wire Router by AT&T, if so the password is on the side or bottom of the router. Look for Network Key or Network Password on the router.
Once you have that, you simply go to your laptop, and try connecting to your wireless router. It will be the one with the strongest signal if you don't know your SSID. Once you click connect, it will ask you for the password/passphrase or key, type in what you found on the router.
There is really no need to reset the password unless you have some other reason. But there are 2 ways to reset the router's password, you will need to have a computer that is connected to the router with a network cable (most times this is a desktop already connected). Then you will need to know the router's IP Address to type into a internet browser. It will be a set of numbers such as 192.168.1.1 that you would type into the address bar where you normally type www to get to a web page. Once you have the right ip address you will need the router's login id and password. Most times this is set to the default unless whoever set it up changed it. Once you are in the router then you go to the wireless and wireless security area to change the password. If you don't know the ip address or the userid and password for the router, then you can google it on the internet.
If your internet provider is AT&T you might be better off calling them to reset your router's password. They can walk you through it.
Mar 20, 2012 | HP Computers & Internet
How do I find my WEP key?
ITS THE SERIAL NUMBER ON YOUR ROUTER, NOT SURE THE MAKER OF YOUR ROUTER, HAVE YOU TRIED OPENING YOUR BROWSER AND IN THE ADDRESS BAR JUST TYPE 192.168.1.1 AND IT SHOULD BRING UP YOUR ROUTER MENU, YOU CAN ALWAYS CHANGE THE CODE OR DISABLE IT, THERE SHOULD ALSO BE ALL THE INFO ON YOUR ROUTER SOMEWHERE IN THE MENU, WHOEVER SET THE ROUTER UP INITIALLY SHOULD HAVE BEEN IN THE MENU TO SET OR CHANGE THINGS. IF YOUR SETTING UP THE CONNECTION ON YOUR COMPUTER JUST CHOOSE YOU ARE CONNECTING TO A DSL THAT IS ALWAYS CONNECTED, AND IT SHOULD JUST AUTO CONNECT WITHOUT THE WEP KEY, BUT AS I SAID YOU CAN GO INTO THE MENU BY TYPING 192.168.1.1 IT SHOULD GIVE YOU ANY INFO YOU NEED.
Dec 31, 2011 | Computers & Internet
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
I can't connect wlan security incorrect.
Sorry to said but you have to use the correct WLan password. If you don't know this password you have to connect at the router's settings page using an ethernet connection, locate the Wi-Fi (or Wlan) section and at the security section find the requested password.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer. Also clarify me the brand/model for your router.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 04, 2011 | Computers & Internet
Hey, I bought the Wireless n adapter for my xbox 360 and I don't understand how to connect it please help
hello my brother i'm don't have xbox and too I'm dont know lot about xbox . But youtube know how to slove your broblem from here
thank you
Jul 23, 2011 | Computers & Internet
What is error code 51330
Hi there.
Unable to connect to your wireless network
Likely cause: It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings. Security keys are case sensitive.
Don't know how to find your router's password?
Look for a sticker on the bottom of your router. Many routers provided by Internet service providers have their default password located on a sticker on the bottom of the router.
If you don't know the router's brand, click this link.
Thank you for using Fixya!
Jul 07, 2011 | Nintendo Wii Console
Hi, so there was a lightning storm last night and after a big crash of thunder the internet went down. It came back on but died on me again. My belkin router will blink green and stay solid for a few sec...
Hold down the power button for approximantly 45 seconds it should turn orange then back to solid green.then Get on your computer and see if there is any way you can connect. I hope that i could help. If not, please let me know.
May 28, 2011 | Belkin Computers & Internet
I don't know how to connect belkin with internet
Hi, Let's see if I can help you.
Begin by turning on your computer and your router
  • Open Internet Explorer;
  • Click on 'Tools';
  • Click on 'Internet Options';
  • Click on 'Connections';
  • Click on 'Setup'
  • Click on 'I want to set up my Internet connections manually . . .';
  • Click on 'Next';
  • Click on 'I connect through a local area network (LAN);
  • Clock on 'Next'
  • Click on 'Next' [This is not an error];
  • Click on 'No';
  • Clcik on 'Next';
  • Click on 'To connect to the Internet immediately . . .; and,
  • Click on 'Finish'.
That should have you online
May 21, 2011 | Belkin Basic Wireless Router
TP-LINK 300Mbps Wireless N ADSL2+ Modem Router TD-W8960N Logo
251 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
alex metro
alex metro
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
