Question about Convair Heating & Cooling
Mackay super convair briquette heater..there are 2 control knobs on the front of the heater,the words have rubbed off and dont know what they are for can you help?
2 Suggested Answers
  • 659 Answers
SOURCE: Looking for a manual for solid fuel heater
Since the unit is only a few years older than I, I'm going to give you the contact info for the states. They might be able to pull up a manual on some micro fisch somewhere. I wish you all the luck on this one. This is the name of the Convair brand company here in the states.
Seeley International (Americas) Corporation Head Office and Pacific Coast/
Southern/Central American Sales
1202 North 54th Avenue,
Building 2, Suite 117
Phoenix AZ 85043
USA
Ph: (602) 353 8066
Fax: (602) 353 8070
E: americasales@seeleyinternational.com
Posted on Mar 22, 2009
Heater controll switch
Hello, I want to tell you about some of the knobs for the temperature control switch, if that is the switch you are referring to.
The way some of the knobs are made, they have a 1/2 moon shape with a metal clip inside them on the backside of the knob. The 1/2 moon shape is also present on the control shaft the knob fits onto. When the knob breaks and splits, the knob rotates around the temperature control shaft without moving anything. From the driver's view, the knob is normal.
You would need to pry off the knob and inspect it, then rotate the temperature control shaft with your fingers or lightly grab it with pliers.
Jan 30, 2014 | 2004 Ford E-350 Super
Heater not hot temperature gauge moves ,shows it is hot but air flow and air temperature not hot
Hello, What you need to do is let the truck warm up and then feel the heater hoses. If the heater hoses are hot, the problem is under the dash in the ductwork doors or the heater knob is cracked.
If you have a nonDigital heater control with just a knob, they are prone to break. They run about $9 at a Dealer and many Salvage yards won't let go of them without selling the whole heater control. Since the shaft of the heater is plastic, you can gently grab the heater knob shaft after you remove the knob and turn it with a pair of pliers.
Your heat should work. If the heater does not work and you have water flow in the heater hoses under the hood; the remaining problem is with a ductwork door. Either the actuator (sometimes callled a motor,solenoid,dashpot,) is broken or a plenum door has jumped its mount and is stuck.
If you do not have hot hoses at the heater you need to check your heater water control valve. Some models use them, some models just rely on the ductwork to reroute the heat in the Summer. This valve would be where one of the heater hoses goes to under the hood by the Firewall. It may be controlled by Vacuum or Electric or a cable.
That pretty much covers it. I hope my solution is very helpful to you. I had to replace the knob on my 99 F150 and learned how common this defect is and what the Salvage yards are doing.
Jan 07, 2011 | 2001 Ford F250 Super Duty Super Cab
My 2003 mitsubishi lancer es's heat control knob has snapped off.!!! I used plyers to turn it over last winter and now it seems stripped and wint go back to heat.. Is there a way i can just flip a...
Hello jeffgranstro
Sorry to say there's no easy button in the automotive world yet. You're heater controls are cable
operated and a cable problem most likely caused the knob problem. If you just want a temporary
fix, remove the control assy. from the dash. The front trim cover is held by 8 clips 2 top 2 bottom
and 2 on each side, with a small thin screwdriver, gently pry around the cover till it pops off.
At this point you should be able to see if there are screws or clips that hold the assy. in place.
The objective is to remove the problem cable from the assy. and pull it down from under the dash
where you can operate it with a pair of baby vise grips. Next, put the rest of the heater control assy. and trim plate back in place, and use those controls normaly. Thats one way to get by what is a stupid design to start with. Hope this helps.
Dec 16, 2010 | 2003 Mitsubishi Lancer
Hi, Where can I get a thermal switch for convair 33mj wall heater
Hi.
If you are referring to the thermocouple, then part number is 880310. If you are looking for a different part, please refer to the part list below:
Convair Wall Furnaces
Part for this A/C can only be ordered contacting Convair, there are no third party online distributors. See: Convair Service
Sep 21, 2010 | Convair Heating & Cooling
How do i get the front cover off of a convair finesse 3300
undo small screws between the two panels just above the bottom door
open out and pull the top hinge wire down in a u shape it will come out
easy
Apr 28, 2009 | Heating & Cooling
I have a 2000 ford E350 van with front and rear air. the front blower motor runs at low speed, The front blower still runs on low even when the knob is set on medium or high. I do not know where the...
it's either the blower motor switch or blower motor resister. Resistor ?Heater Blower Motor Switch Removal Remove the battery (10655) ; refer to Section 414-01 . Remove the battery tray. Remove the screws. Remove the battery tray. Disconnect the heater blower motor switch resistor connector. Remove the heater blower motor switch resistor (18591). Remove the two screws. Remove the heater blower motor switch resistor. ----------------------------------- Switches Removal Disconnect the battery ground cable. Remove the center trim panel; refer to Section 501-12 . Remove the control assembly. Remove the screws. Remove the control assembly. Remove the A/C-heater function selector switch knob. Disconnect the vacuum harness connector. Disconnect the A/C-heater function selector switch connector. Remove the A/C-heater function selector switch. Remove the screw. Remove the A/C-heater function selector switch. Remove the temperature control switch knob. Disconnect the temperature control switch connector. Remove the temperature control switch. Remove the screw. Remove the temperature control switch. Remove the heater blower motor switch knob. Disconnect the heater blower motor switch connector. Remove the heater blower motor switch (18578). Remove the screw. Remove the heater blower motor switch. ----------------------------
Mar 31, 2009 | 2007 Ford E-350 Super Duty Length XLT
Phoenix AZ 85043
USA
Ph: (602) 353 8066
Fax: (602) 353 8070
Mar 22, 2009 | Convair Arctic Breeze 1500 Air Conditioner
Lights are out on shifter and heater control knobs in 05 sentra
I'm posting a video on youtube now, search "micah rodby". You can get a new light bulb from the auto part store for the shifter and radio shack for the heater lights. good luck.
Nov 16, 2008 | 2004 Nissan Sentra
Lack of heat
The plates protect the burners and help disperse the flame more evenly across the grill surface. Make sure the tank is completely open (knob on top of tank) and that when the burner is turned up to high, the flames out of the burners are about 1 1/2 to 2" long, mostly blue in color. If they are smaller, and the tank is open all the way, the regulator hose may be defective.
Jun 19, 2008 | Uniflame 200209 Open Flame Patio Heater
Heating & Cooling Logo
63 people viewed this question
Top Convair Heating & Cooling Experts
Donni Steen
richie46
ray gallant
Are you a Convair Heating and Cooling Expert? Answer questions, earn points and help others
