Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
Hello, I have Sandisk Cruzer blade 4 gb pendrive. But now it shows I/O error while copying data to it. please give a solution.
    Brigadier General:
  • 10,406 Answers
Copy all the files from it to your 'C:' drive, and burn the files to one DVD-recordable disk.
Then, responsibly recycle the SanDisk, and spend $10 to buy a new flash-drive.
Copy the files from the 'C:' drive, or the DVD disk onto the new flash-drive.
Keep multiple copies of your files, just in case this "new" flash-drive also "fails".
Posted on May 25, 2011
My pc doesn't show sandisk cruzer blade 4 gb pen drive whereas it shows others
Sometimes, windwos OS, give same drive letter to different devices, and when you connect both, one is not showing. So, you need to go in to Disk Manage (right clic on "My PC", clic on Manage") and verify if you can assign a different driver letter to your pen drive.
Oct 01, 2012 | SanDisk SDCZ50-004G-P95 4GB Cruzer Blade...
My pendrive is not formated in aNY COmputer my pendrive is sundisk cruzer blade 4 gb
if you can access it, try to format it into fat's file systerm and it denies the format but still accessible, try a different OS like Macintosh or Linux.
Nov 09, 2011 | SanDisk Electronics - Others
MY 8GB SANDISK CRUZER BLADE PENDRIVE NOW SHOWS WRITE PROTECTED...PLEASE HELP IF U CAN........
My 8 Gb pen drive now right protected how can i remove the write protection pls.....................Pls..............say the solution
Sep 13, 2011 | SanDisk Sansa e270 MP3 Player
When I insert sandisk cruzer blade 8gb pendrive, it is showing as removable disk but not opening and shows as 0 bytes. All other pendrives are working in my system and this pendrive is working in other...
Since it works with other systems there is a system incompatibility issue. Are you using the same OS in this machine as in the others where it works? Could it be that?
Using XP? It has some issues with some usb devices.
Sep 23, 2017 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My sandisk cruzer 4 GB pendrive ws working fine but now whenever i try to format\copy\cut it shows location 0 with used space 0 free space 0 what should i do
Your flashdrive usually shows 2 drives when inserted to your computer, one is the U3 drive and the other one is the removable disk drives. U3 drive is your separate partition for the U3 system and in order for you to store, copy, format your flashdrive, you should be selecting the removable disk drive, not the U3 drive. U3 is a read only memory drive that is responsible for your U3 to work (just like portable applications). Hope this helps.
Jul 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
4 GB sandisk pendrive can't open
1. continue without solving
2. If you didn't remove the drive with the safe removal tool in the task bar ( lower right hand corner) the drive will lose it's ability to be mounted or seen by Windows and will not format. You will lose data.
Apr 20, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk 4gb pendrive not working
Best thing to do is format the drive. Dont go for a quick format
Jun 14, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
178 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
