Question about Century "Bob" Body Opponent Bag
The plastics tabs inside the top piece of the Bob dummy has been broken off. It will not stay at its adjusted height. It will kept on sliding down to its lowest position after contact.
Binding adjustment
There is (should be) a screw visible on each of the toe and heel pieces when looking down from directly above. That screw will adjust the height of the piece that clamps down on the top of the tabs on the heel and toe of your ski boots. For proper height measurement, use a credit card (or similar thickness card) and make sure you can somewhat freely slide the card side-to-side under your boot when it is in the binding and clamped down as when you are skiing. Too much play, and you will feel a sloppyness while skiing. Too little and you risk the binding not releasing properly caused by stiction. You can find demonstrations on YouTube also.
Apr 04, 2014 | Fischer Skis Fischer RC4 Z 17 Freeflex...
Gas is going in to the air filter the bike will not idle something is causing gas to go into air filter took carburetor apart everything was clean dim. height how to check flow height
do you mean the floats? if so then take the carb apart again and inside the bottom half you will see 2 pieces of plastic on a spring number 22 on pic when you blow through the petrol intake pipe air will escape from near the floats when you lift them up the air will shut of which is what will happen when the carb is full of petrol if the air dosnt shut of the floats need adjusting bend the spring carefully upwards ( I DO MEAN CAREFULLY) then try again you may have to do this a few times untill you get it right
i would check the needle height first unscrew the throttle cable fromt the top of the carb watch out for the spring and you will see the needle inside the sleeve number 8 on the pic
the needle is number 7 remove the plastic washer from the bottom and pull the needle up a bit you willl see notches on the side of the needle just slide the washer down the side untill it clips into the one you want that will reduce the amount of petrol going into the carb
1stdcarb.jpg hope this helps
John
Apr 09, 2011 | Suzuki Boulevard S50 Motorcycles
Moen M5350 toilet piece. I loosen yellow ring at bottom. How to adjust water height
Take off the things screwed on the bottom, unlock and remove the yellow thing, hold the main plastic part and the threaded part and twist, the bottom part should move about half a cm. Then pull down. There is a shaft inside the main plastic part and it's got ridges inside.
Jan 08, 2011 | Home
I can not get my tailgate to unlatch and open. what do i need to do to get it to open?
i had the same problem with my 2002 1500, the problem lies with a clip or both clips being broke under the tail gate latch that you pull on to open it. you can check this by getting a flash light and look up under the latch as you have it pulled up, you will then see if you have a broken clip. chevy dealer has these. to replace the clips you have to remove the square plastic piece around your latch handle, this square piece has 4 plastic tabs 2 on the upper piece of the square in the corners and the low portion of the square has 2 in the corners also, get 2 putty knives and slide one under the bottom half of the square plastic piece 3 quarters of an inch from the corner, then slide another putty knife under the very corner, note cover this knife with tape as it will scratch your paint if not careful. you will hit a plastic tab shove in carefully to disengage the tab, do this on the other side,then you can remove bottom half of plastic trim, then proceed to do the same step on the top of the plastic trim, once this is done then take it off carefully these plastic tabs are fragile! then proceed to look in the area to see which clip is to be replaced, use needle nose pliers to install new clip, just put clip on shaft that has dropped down, this would be the one that has the broke clip. then after installing new clip try your tailgate if it opens, if it does all is well. install your square plastic piece top first, then the bottom until it snaps into place.
Dec 11, 2010 | 2002 Chevrolet Silverado 1500
How to change the faceplate of a samsung s7330
  • Locate the small plastic tab on the top of your Samsung phone, located in the groove between the faceplate the main phone body. This tab is very tiny, only about one-sixteenth of an inch wide.
  • 2
    Press on the plastic tab with your fingernail.
  • 3
    Continue holding down the plastic piece while sliding the faceplate off the top of the phone. The faceplate only slides off from the top, so don't try to force it in a different direction.
  • 4
    Release the plastic tab.
  • 5
    Line up the new faceplate with the top portion of your phone then slide it downward until it latches into place. You'll typically hear a soft click when the faceplate is secure. When properly placed, the new faceplate should not be able to wiggle or slide unless you press down the plastic tab once again
    Read more: How to Change a Samsung Phone Faceplate ' eHow.com http://www.ehow.com/how_5146822_change-samsung-phone-faceplate.html#ixzz17o6dpgG0
  • Dec 11, 2010 | Samsung S7330 Cell Phone
    Paper keeps jamming
    I had this problem and it was a plastic piece that kept getting in the way. Turn the printer around, open the "duplex" addition piece and see if there is a white plastic piece that is on the left just inside the black paper guide. Mine was sticking out. It looks like it may have a broken tab that clicks on a rotating bar on the outside of the black paper guide. I used a dime to hold the white plastic piece in place. Now I only jam on occasion and everything else works perfectly!
    Jul 29, 2010 | HP Officejet Pro L7680 All-In-One Printer
    Front window regulator
    Remove inside panel, start by removing electric switchs from panel, and disconecting the female end. Inside panel can be removed by pulling tabs, a screw driver will do. You must then loosen bolts on window slide to free window. adjust regulator tab to approprate height to shut window, then assemble reverse directions.
    Jul 29, 2008 | 1989 Cadillac Sedan DeVille
    Wand
    Do you have a telescopic/height adjustable wand or just two tubes which have to be stuck together? If they are made of plastic well, it may well be broken. If its metal check that the tops aren't corroded or the handle itself isn't broken. If the tubes/wand isn't sliding up and down (i.e. if its height adjustable) then something has got stuck. Sadly for this kind of repair you'd be better off to buy replacement wands or consider something aftermarket on EBAY. Check the diameter of the tubes with a ruler. If it is 3.2cm (32mm) or 3.5cm (35mm) you can buy replacement tubes. If you can't afford that then try furniture polish on a J cloth or similar and with a stick wedge it inside the tube/wand so that it adds a little lubrication or simply a clog - it sounds like there is dirt clogged in the part that slides. Dont forget to rate, thanks.
    Jul 26, 2008 | Vacuums
    HP f1905e tilt and Height adjustment
    I figured it out! Just takes a phillips screwdriver and a 5/16" open end wrench to tighten up some nuts inside the plastic housing. The plastic housing doesn't come off with the screws, but has to be slightly pryed up to release the little plastic catches. Be careful though, you don't want to break the plastic tabs. It's ok to break maybe 1 because there are several to take up the slack. At first I thought it was the nuts that are 1/2" (there are two that are close to 2 springs. But that was just for the tilt forward and backward. Actually there are 4 nuts (5/16") that need to be tightened. Don't over tighten or it will not tilt at all. I took photos of the disassembled base. If you have skype, then skype me at "golfbob" chino hills, and I can send the pics or talk you through it. Good luck.
    Jan 11, 2008 | HP f1905 19" Flat Panel LCD Monitor
    Century "Bob" Body Opponent Bag Logo
    61 people viewed this question
    Top Century Sport & Outdoor - Others Experts
    Are you a Century Sport and Outdoor - Other Expert? Answer questions, earn points and help others
