Question about HP LaserJet 3390 Printer
Hi, I am trying to print with my HP LaserJet 3390 and it says 'No paper pickup'. Can you help? Regards, Peter G.
  • 225 Answers
Try to print from the manual input tray just to finish your job.
Possible reasons are:
Blocked paper tray
Worn out pick up roller
Broken pick up roller shaft
Broken pickup assy driver shaft
Unhinged solenoid anchor
Separated double pickup gear
Try to print again from the first tray and listen if the solenoid is clicking and the roller is rotating. If yes, look for pieces of paper blocking the paper path where the paper goes up after the pickup. Also inspect the pickup roller. It tends to wear and needs replacement. You can easily remove the roller and inspect it (rotate the white plastic bearings). If worn out, you can turn the rubber with a thin screwdriver inserted between the rubber and the plastic to unworn area, as it is D-shaped and part of it never wears. It's temporary solution while waiting for the new roller delivery. Sometimes it breaks the connecting side after hard removal of a paper jam. Also inspect the black connecting rod that drives the roller. It can also easily break the same way. If none of these is relevant, probably the driving mechanism is bad and needs deeper dismantling. It consist of a solenoid and a double gear. Solenoid anchor tends to go out of the hinges. Just put it on place. The double gear tends to separate and a spring inside gets out of its way. Pull the spring to make it stronger, put it on place and close the gear. Make sure the gear will not separate by itself and assemble everything.
Posted on Oct 30, 2017
  • 2,567 Answers
Try to perform the following steps in the mentioned order:
1. Verify that the media was inserted far enough into the input tray. In tray 2 (HP LaserJet 3390/3392 all-in-one), verify that the paper-length guide is in the correct position for the media size that you are using.
2. Reload the media in the input tray and press Hi, I am trying to - c00597632.gif to continue the job.
Posted on May 23, 2011
Hp laserjet 1132 mfp paper pickup issue E1 error
Shabbir,
First I would try a "heaver" weight paper in place of your current paper.
Second I would look for something blocking the paper path...maybe a piece of paper got stuck.
Hope this helps...
Here is the link to the manual from HP:
http://support.hp.com/us-en/product/HP-LaserJet-M1130-Multifunction-Printer-series/3965842/model/3965843/manuals
Topbarhive
Jan 12, 2016 | HP Office Equipment & Supplies
My hp laserjet 1320 takes in more than one paper while printing, which get stuck.
Cleaning the pickup roller will only temporarily delay problem. The pickup roller and separation pad needs to be replaced to correct the multiple paper pickup problem. The roller and separation pad is easy to replace. These parts come in a kit caller RK-1320 the parts kit is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=71
Mar 28, 2013 | HP LaserJet 1320 Printer
HP P3005DN Tray 2 pickup roller does not turn. Hear clicking sound but roller doesn't turn to pickup and feed paper.
Hi
This is a problem with the Pickup roller.
Try to inspect the paper pickup roller, on the right side of the roller you can find a small notch which gets coupled with the shaft it will be broken. You have to replace the roller.
Regards
Jul 15, 2011 | HP LaserJet P3005n Printer
I have a HP LaserJet 1320tn, after I changed the cartridge I keep getting paper jams just about where the paper meets the cartridge
Hi if you says that the paper gets jam at the fuser meeting point than i m sure that registration assembly which register the paper with toner cartridge is not working properly this is internal hardware fault.
It may caused due to faulty pickup assembly too.
There is a small **** manual feed tray try to print using manual feed and check if the problem persists then registration assembly is faulty if the it print fine from manual feed than Tray 2 pickup assembly or pickup roller is faulty.
Jun 29, 2009 | HP LaserJet 1320 Printer
Manual feed pickup
replaced the manual feed tray separation pad (it is right under the pick-up roller). The HP part # is RG5-2703. First remove the pickup roller then you can pops it out with a small straight slot screw driver.
Jan 23, 2009 | HP LaserJet 8150n Printer
No paper pickup
Hi damodarbk:
it sounds like you need to replace the paper feed rollers.
pdouglasss
Jan 03, 2009 | HP LaserJet 3050 All-In-One Printer
** Paper Pickup
Check the paper pickup tray & roller may be its not working. If possible contact the local vendor for printer servicing.
Mar 09, 2008 | HP LaserJet 3390 All-in-One Multifunction...
HP color LaserJet 2550n
Look at your printer properties and check that you are using the correct tray settings.
Jun 12, 2006 | HP Color LaserJet 2550n printer + HP Color...
HP LaserJet 3390 Printer Logo
229 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
