Question about Tiger JCC-2700 15-Cup Rice Cooker
The hinge attached lid to rice cooker is broken how and where can I find that or replace?
dutchman05
  • 487 Answers
SOURCE: farberware 10 cup rice cooker blows fuse after replacement
yeah it has a short in it or just a wire lose from the heater.
open up and check. If you have an ohm meter check the heater. It should not be infinit
Posted on Jun 24, 2008
  • 54 Answers
SOURCE: Need instructions for National Rice-O-Mat Rice Cooker SR 10GHN
You can just go to a web site and look search for Rice Cooker Steamer. And find some important information.
Posted on Jan 11, 2009
SOURCE: Rice cooker power cord
Thank you. I resolved the problem myself. I found a power cord from my slow cooker and it works.
Posted on May 05, 2009
  • 114 Answers
SOURCE: Rice cooker lid replacement?
if you still have the reciept the best thing that i would suggest is to take it back to the store or call the manufacturer and they will send you out another under warranty cause there should be a 1 year warranty on the unit.
Posted on Aug 20, 2009
heatman101
  • 43501 Answers
SOURCE: tiger rice cooker
There is a sensor that regulates how hot the cooker gets and shuts it down to the warm setting when it senses that the heat is too high...meaning that all the water has cooked off....my guess is that the sensor failed and as far as I know it is not replaceable.
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Posted on Jul 27, 2010
Lid hinge is falling apart.
can you send me closeup pics of the hinge ?
May 29, 2015 | Tiger JNP-1800 10-Cup Rice Cooker
I need a replacement part for a Panasonic rice cooker SR-IHZC10N. The part I need is called Keep Warm Cap.
That is a hard piece to find; it actually collects water when you open the lid after rice is cooked and will not affect the keep warm function. Just make sure you pop a cloth under the missing cup before you open the lid. I have been working without this part for a few years now and it has not affected the rice cooking at all.
Jan 16, 2015 | Panasonic Kitchen Appliances - Others
Error E01 appears when power on, can not do anything after that
Open the plastic cover on the back where the lid is attached and expose the wires. One of those might be broken.
Nov 04, 2012 | Zojirushi NS-JCC18 Neuro Fuzzy 10-Cup Rice...
Zojirushi rice cooker do not work
My rice cooker got the same problem of can not be turned on. The LED display still shows the time, but menu and all other keys are not functioning.
I saw someone here mentioned of broken wire in the lid. I opened up mine and did NOT see the same problem. I have two pictures attached here. If someone found a solution, please email me at kc_179@yahoo.com
Thanks,
KC
P.S. Can't attach the picture. It has to be less than 500 kb and mine is 2mb each.
Jul 23, 2012 | Zojirushi Kitchen Appliances - Others
Locking mechanism broke...spring /hings area when closing cooker lid. need that replaced. parts available?
Hi there.
You can locate the nearest authorized parts dealer at http://www.zijorushi.com
Regards.
Jun 21, 2011 | Zojirushi NS-PC10 5-Cup Rice Cooker
WHERE CAN I GET THE WIRING DIAGRAM FOR MY TAYAMA RICE COOKER TRC-10? IT LIGHTS UP WHEN PLUGGED,BUT IT DOESN'T COOK WHEN PRESSED DOEN
Hi and welcome to FixYa, I am Kelly.
I do not have the wiring diagram but... the 2 wires that go to the top of the unit fray and break at the lid hinge point and cause this problem quite often. The 2 wires in the hinge area are for the upper temp sensor. (The floating plate in the top of the lid) If you fix the wires in the hinge area most of the time the come back to life unless the heating element has failed. The heating element will read about 180 Ohms resistance if it is good. The resistance changes a bit as the unit ages.
Try fixing the wires in the hinge then testing the cook button. I usually have extend the wires in the hinge and do a double splice for the NEW wire strip on each wire with heat shrink tubing over the repair.
If this does not work just respond here and I will assist you further.
Thanks for choosing FixYa,
Kelly
Jan 28, 2011 | Tayama TRC-10 Rice Cooker
Sanyo 5-cup Micom rice cooker, no power
I had the exact same problem with my rice cooker. I took the lid apart. There was a broken wire because of the constant friction of the hinge when open and close the lid. After I soldered it, it started to work again.
Jan 29, 2010 | Sanyo Kitchen Appliances - Others
Was using rice cooked for sometime. My cooker is not starting to cook whne I press cook button. That is there is no blip and light above cook is not coming. Whereas when I press on warm button, warm button...
In the top cover of your rice cooker there is a sensor that controls the cooking circuit. Most of the t\ime what happens is the wire in the hinge area breaks due to the opening and closing of the lid. I even had to repair my own rice cooker by cutting away the damaged wire then soldering a longer new wire in BOTH wires. I also added shrink tubing over the 4 connections on 2 wires.
Jan 09, 2010 | Aroma ARC-838TC 20-Cup Rice Cooker
Broken lid knob
you can try a "home improvememt store" remove the old one and replace with a kitchen cabinet knob that screws on
Jan 30, 2009 | Faberware FRA100A 10-Cup Rice Cooker
National SR-MM10N rice cooker not working
I had similar problems.
There are some wires connecting the lid and the main unit. These wires run behind the hinge area and over time they got clipped from opening/closing the lid.
To fix the problem, you will have to open up the hinge unit and the top lid and reconnect (soldering) the disconnected wires.
I fixed mine more than once. IMO it's a design flow.
Again, don't attempt unless you know electrical wiring and feel comfortable with soldering. Make sure you cover the exposed wires with proper electric tape. You don't want to mix electricity with water and steam as there are much in the lid.
ChauChau
Mar 19, 2008 | Panasonic SR-MM10NW Neuro Fuzzy 5-Cup Rice...
Tiger JCC-2700 15-Cup Rice Cooker Logo
48 people viewed this question
Top Tiger Kitchen Appliances - Others Experts
Irene Tulloch
ray gallant
Bill Boyd
Are you a Tiger Kitchen Appliances - Other Expert? Answer questions, earn points and help others
