Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Check TEL line.......what does that mean? My phones are not working and that is what it says on the phone
  • 7993 Answers
SOURCE: What is wrong when the phone says Check tel line?
The telephone cord may not be connected correctly.
  1. Unplug both ends of the cord connecting the wall jack to the telephone base.
  2. Insert one end of the cord to the TEL LINE jack on the base.
  3. Make sure that the cord is inserted correctly in the TEL LINE jack on the phone.
  4. When you insert the cord you should hear a click.
  5. Insert the other end of the cord to the wall jack.
  6. Make sure cord is inserted correctly.
  7. You should hear a click.
Posted on Feb 03, 2010
  • 25 Answers
SOURCE: My phone screen says check
First be sure you have dial tone at the jack. Use a corded phone to do this with. If you do have dial tone then be sure you have ac at the outlet that the transformer is plugged in to. If there is no dial tone at the jack...go to your interface box outside and check for dial tone there....if none call the phone company. If you do have dial tone then you need to check your wires to the jack...or have the phone company do it for you. If you don't have ac at the outlet....check your breaker box or have an electrician check for you.
Posted on Nov 07, 2010
SOURCE: No dial tone on Uniden Dect 6.0 land line and portable phone
We've had the same problem with our new Uniden phone. Sounds like someone's on the other line - no dial tone and answering machine doesn't work. The telephone line works though because we plugged our old phone in and it works fine. Any solutions anyone?
Posted on Feb 05, 2011
SOURCE: "check tel line" message?
have you paid you bill? Seriously ring your provider and get them to check your line out.
Posted on Feb 12, 2010
consultel1
  • 860 Answers
SOURCE: My phone says check Tel Line
Sounds like your telephone line might be dead. If you have a gray or tan telephone box on the outside of your house you can plug your phone in there to test the line. If you get dialtone then thrers a problem in your house wiring, if you don't get dial tone then the line is dead and you need to conact your telco provider.
Posted on Apr 14, 2010
All phones are plugged in and operating but i get a busy signal on all in talk mode
I assumed when you say all phones are operating means there's power and are charging.
1. There could be some phones that are loading the Tel line. Disconnect all phones and plug it one by one while checking the dial tone. If all phones gives busy tone, there coulb be a problem in the Trunk line or the Tel Company line.
2. There could be a short or resistance in the line. Check the connection in junction box between your house and the Tel Company cable.
3. If you have an analog Tel set, you can check the dial tone directly from Tel Company cable that comes in to your house.
I hope this helps.
Best Regards.
Sep 01, 2015 | Panasonic KX-TGEA20 Additional Digital...
What does Check TEL line mean. I can'y find any physical issues with the connectivity.
The message means some kind of problem has been detected in the line. It could be hum or static, possibly caused by a technician fixing someone else's problem.
Apr 10, 2015 | Uniden DECT 6.0 Cordless Phone
My land lines are working but all my handsets say check tel line...no dial tone or response. Batteries are good according to tester. Anything I can do??
ck the red and green wire that goes to the system those 2 make the phones work just do the main main phone first , , it does not sound like the phones are broke you are not getting a dial tone due to no connection to the line itself
Dec 10, 2014 | Panasonic Kx-tga641m/kx-tga641 Cordless...
"Check Tel Line": Do I need a new phone?
theres some thing wrong with the base unit, try unplugging it and plugging the whole setup at a friends or something, also if youhave a DSL line you my have to install a filter to seperate the data line and voice line. Its ole school but this might work.
Feb 16, 2014 | Uniden DECT 6.0 Cordless Telephone...
Check TEL line
Is that what appears on the screen?
If so it means that it's not seeing the phone line.
1. Plug in a basic phone to make sure the line really is working.
2. Check the phone cord is connected to the correct socket (probably marked line)
3. If still no line change the cord and make sure that it suits the pin-out of your country. Most of the world uses pins 3 and 4 but the UK uses 2 and 5 on it's wacky BT flat plug. Israel uses this BT plug but uses pins 3 and 4 !!
Oct 27, 2013 | Uniden Cordless Phone
Panasonic phone says check tel line
Check cable conections from phone box on wall to base unit, make sure that the conectors are fully inserted. If possible plug a different phone into box to make sure that line is working. Hope this helps
Jun 08, 2017 | Lands Phones
Landline displays screen message Check Tel Line. Can't phone out or receive calls. Lights on the black box are out. I checked outlets, etc. E mail is weiner_@live.ca, land line 250-590-5196. Thank
I had to reboot our Shaw box three times last night before the phone started working again. Not sure what triggered the "check tel line" in the first place. My husband had just finished a phone call, I was going to make one right after him. The msg appeared as soon as he hung up. Interesting about your having a Uniden phone; it's the same brand as ours. This is the second time in a year that we've run into this problem. As for your old phone, is it analog? Reason I ask is, our rotary analog phone will work when the digital one doesn't.
Jan 05, 2013 | Lands Phones
Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Feb 16, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
Feb 12, 2010 | Lands Phones
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
1,772 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
