Question about Haier HDP18PA Stainless Steel Free-Standing Dishwasher
HDW101SS does not heat water. Heater element mearures 28 Ohms. Temp Limiter is N.C. Temp controllers TS50 & TS60 not found. On economy wash timer moves as normal then stops when red heater light should come on. If the timer is assisted one click it will progress as normal but no hot water.
  • 1 more comment
  • Alf Licciardello May 23, 2011
    Hello Daniel,
    Is the HDP18PA the same as HDW101SS?
    Can the Temp.controllers TS50 & TS60 be tested without removing the side panels?
    Is the front panel you mentioned in the door or under the tub assembly?
    The timer progresses through the full cycle after it is assisted indicating that a signal is not reaching the timer at heating stage and allowing it to continue the sequence.
    Cheers Alf
  • Alf Licciardello May 25, 2011
    I am now confused as my query was for a HDW101SS and the reply was for a HDP18PA.
    What is the difference between the HDW101SS and the Haier HDP18PA?
    Where exactly are the Temp controllers TS50 & TS60 ?
    I have checked the Temp. Limiter as N.C. It is the self resetting device which replaced the manual reset version that was constantly tripping off.
  • Don T. Neetano Oct 15, 2013
    You say the temp limiter is N.C., that sounds like a relay. Temp limiters are usually ptc or ntc and can be read in ohmes (isolated) by touching.
  • Haier Master
  • 19,396 Answers
Hi.
If the temp limiter shows no continuity, there will be no voltage reaching the element contacts. The high limit is connected in series with the heating element. If the hi limit is open the element will not get power. Any technician will tell you the same. Unless the temp limiter blows again you do not even need testing the other two thermostats. Temp limit may blow because of occasional overheating. If it blows more than once there is either a shorted thermostat, a defective CCU(control module), or an heating element that stays always on because of a short.
Here how it works- CCU is control module powering the element in the mid part of the cycle:
C-------------Temp limit---TS---TS-----\
C ELEMENT
U-----------------------------------------------/
Replace the defective high limiter. That will do the job. If it doesn't, test and replace the other two thermostats located at the bottom side of the appliance. A shorted thermostat will read zero Ohms or very low impedance (
Regards.
Ginko
Posted on May 24, 2011
  • 1 more comment
  • Ginko
    Ginko May 25, 2011
    Hi.
    I checked service manual and I found a more extensive explanation. F9 is not necessarily the controller, but there may also be a problem with the motor. Since you have had a code indicated rotation problem, then the motor may also cause the issue. F9 may also be a temporary fault, as explained in previous comment.
    If F9 goes away disconnecting power, then the fault was temporary. While power is OFF, check that there is no lose wiring harness. A disconnected wiring harness may result in F9. If F9 comes back, then the appliance needs a major repair.
    F9 :Power Supply/Controller fault.
    Isolation relay disabled,
    disconnect then reconnect power enable relay.
    Action
    - If previous fault was F3, F8 or F9 then this F9 is a consequential fault.
    - If fault was displayed after power on, check solenoid coils and
    motor stator.
    - Check lid actuators.
    - Check electronic controller for signs of damage, overheating or blown components.
    - Test solenoid coils and motor winding resistances before eventually replacing a controller.
    - Check top
    controller chassis and power harness are properly connected and no wires are loose. If controller is not receiving power from
    bottom tub F9 will be displayed.
    - Replace controller only after testing all the parts listed above.
  • Ginko
    Ginko May 25, 2011
    Hi.
    I am sorry. I just posted an answer for a Fischer Paykel with an F9 on your thread BY MISTAKE. I was working on the other problem at the same time.
    Please disregard my last comment about F9.
    About your problem, your dishwasher is not the same as HDP18PA. I am NOT Daniel, and I do not work in team with him. My answers have nothing to do with Daniel's ones. We do not even see each other questions. Please use one expert only. The last expert you answer will be rewarded even if there is no reply or even if the info provided was not correct.
    HDP18PA is not the same as your model and has not the same part location.
    Please choose an expert and keep working with the same expert. Read my previous comment and start replacing the high limiter. The cycling thermostats should be OK. The cycling thermostat is located near to the element at the bottom side of the appliance. Unfortunately I do not have schematics because the appliance is Australian.
    Replace the high limiter, if it reads n.c. it is faulty.
    Regards.
    Ginko
  • Ginko
    Ginko May 25, 2011
    About the reply from the other expert being for HDP18PA, that is due to the fact that when you have chosen the model you have selected HDP18PA in the auto compiling Fixya form. The title of your question says that the question is for HDP18PA.
    The difference between
    HDW101SS and HDP18PA is model and year. HDW101SS is a more recent model. They are both Haier and the structure is similar. Both appliances use a thermal limit, an element and one of two cycling thermostats in the heater assembly. The thermostats are located at the base of the appliance, watching from front side of the appliance they should be at the left of heating element. The Haier dishwashers that I have seen used only one thermostat. If the thermal limiter is open, then replacing the thermal limiter should do the job.
  • 4,323 Answers
Hi
The heating element is to maintain the heat. If you have already tested the thermostat(s) located at the bottom front panel of the unit and the issue is still not resolved then the issue is with the timer/control that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 23, 2011
No heating on Zanussi Washer
There is usually a heat override switch or setting in the washing machine. Check this. If it is not giving power to the heater, means that the control relay or SSR is not functioning. Check this by tracing the wires back to the board. You would be able to locate the proper relay by tracing it backwards.
Jan 15, 2014 | Zanussi Washing Machines
What does fault code f03 mean in miele g7881 washer?
Wash water
temperature T3 in
wash block CHDESIN
not reached
within 60 minutes
Temperature limiter F2 has
cut out
Reset temperature limiter F2. See
Resetting Temperature Limiter F2
(Thermostat), 030 4.2. If necessary,
replace the temperature limiter. See
Replacing Temperature Limiter F2
(Thermostat), 030 4.3.
Heater elements do not heat
up
Check heater elements. If necessary,
replace a faulty heater element; see
Heater Element Replacement, 030 4.5..
Heater level switch does not
switch
See Heating Level Switch Does Not
Switch On, 050 3.1
Voltage (6VDC) from the
electronic not present. The
heating level switch controls
the heating relay voltage.
Check plug connections.
Check electronic module output voltage;
see 070 Fig. 5, Pos. 9.
Nov 08, 2013 | Washing Machines
Off peak hot water not heating!!! :(
The Economy 7 can control different types heater. Some heaters do not have off-peak ... but you can solve problem..
Copy following link:
http://waterheatertimer.org/pdf/QE7-INSTRUCTION.pdf
If timer is wired to two different elements, then the night rate element or off-peak element might be burned out. Test element with multimeter.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Also this timer is wired so either Off-peak is getting power or Boost is getting power, but not both at same time.
If heater has off-peak element, then there will be a wire connected to terminal 5, going to heating unit.
If there is no wire on terminal 5, then there is no off-peak element, or wiring has not been connected. However you can change the timer function by moving wire on terminal 4 to terminal 5. Then only the off-peak timer function will operate, and not the boost.
You can also fool the timer, by setting time clock differently. Instead of setting timer for current time, rotate the dial and fudge current time by 10-12 hours so water heater thinks it's time for boost, but the actual time is during off-peak hours.
If terminals 4 and 5 both have wires, then either the element is burned out, or the timer has malfunctioned. Again, you can fool the timer by setting current time differently, and solve problem.
Apr 26, 2013 | Water Heaters
Kitchenaid KUDS02FRSS0 dishwasher. Stops mid-cycle, sometimes wash, sometimes rinse, sometimes dry. Must restart 4-5-6 times to get it to finish. When finally done dishes are clean, hot & dry....
Hi Dennis.
If the dishwasher is hanging on in the middle of the cycle it is usually the heating system. If the temperature of the water is going up after filling, then the element may be working. The element is tested using a multi meter set on Ohms to read impedance across the heater element contacts. If impedance is infinity (open-off limit), then the element is gone. If the element is OK, then the bi-metal thermostat or the fuse must be replaced. The heating assembly is located at the base of the appliance, behind the kick panel.
Behind the kick panel you should also find the tech sheet illustrating how to run the diagnostic cycle for this model. Run a diagnostic cycle to confirm that the problem is with the heating system. Drain, water sensor and inlet problems sometimes may also result in cycle not finishing.
You can find parts and diagrams for your dishwasher in this page.
Regards.
Ginko
Dec 08, 2011 | Dishwashers
Dishwasher keeps getting stuck on wash programme
Hi, it's most likely pausing in wash cycle because it is not heating, most d/w timers will loose power to the timer motor until the wash tub has reached a desired temperature, if its not heating the water it will not advance, although it still could be the timer it self but most likely a faulty heater element or thermostat, does the timer advance at all?
If so where timer dial pauses (gets stuck) open door and check water temp (just feel) and close door give it 10Min's or a bit more and water should get alot hotter (anywhere from 45°c to 75°c) note if it is hot fill water may be hot but not hot enough to trigger temp thermostat to activate timer, if your handy and can see its not heating try to check the Resistance of thermos and heater
Jun 27, 2011 | Dishwashers
The water will not heat up. I found the heating element in the back of the tub, removed it and applied power to it and it heated up. What is the next thing that needs to be checked
I had same problem,checked heater element was good (27 ohms).I then removed
top cover and inspected connections all look good. then I lifted control circuit board and found soldered connection for heater relay was melted.I need a new control board.
Jun 03, 2011 | Asko W6221 Front Load Washer
How much for the repair manual and trouble shooting guide for my W6021 asko asea front loader, it will not heat, but the heater is good!
Hi.
The thermistor is located near to the heating element(pt.40) and motor(pt.6). The thermistor/holder assembly is part 31/31in picture below:
To get the full part manual click here. The assembly is at pages 4/5.
Here the part.
To test the thermistor remove it from circuit and read Ohms at its terminals. If the thermistor is good it must read zero or very low impedance. If it reads open, then it is broken.
If this solution was helpful, then please do not forget to accept the solution. Your feedback is important to us.
Regards.
Sep 14, 2010 | Asko W6021 Front Load Washer
Dish washer stck in wash cycle
The reason for your dishwasher to be pausing in wash cycle because it is not heating, most d/w timers will lose power to the timer motor until the wash tub has reached a desired temperature, if it’s not heating the water it will not advance, although it still could be the timer itself but most likely a faulty heater element or thermostat, does the timer advance at all? If so where timer dial pauses (gets stuck) open door and check water temp (just feel) and close door give it 10Min's or a bit more and water should get a lot hotter (anywhere from 45°c to 75°c) note if it is hot fill water may be hot but not hot enough to trigger temp thermostat to activate timer, if your handy and can see its not heating try to check the Resistance of thermos and heater.
Thank You for contacting Fixya.com
Aug 09, 2009 | Electrolux Dishwashers
Kenmore 84152 /94152
probably the heater
Jan 15, 2009 | Kenmore 63942 Dryer
Hot Water Heater Trouble
(1)Have the unit check for electric voltage to the element
If voltage going to the element and no heating
(2)Your heating element may be defective.
(3) Have it replace by qualified personel
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Haier HDP18PA Stainless Steel Free-Standing Dishwasher Logo
231 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
