Question about Dell Inspiron Mini 1012 Netbook (IM1012799OBK)
My inspiron mini 1018 notebook's keyboard is not working properly. The left shift key appears to be stuck and I really having a hard time using the whole keyboard. I remember having spilled a few drops of water to the left side of the keyboard where the left shift key is located. At first some of the keys appears to be jumbled and after a few hours my shift key is stuck. I would really appreciate any suggestions or instructions that might help me. Thank you.
  • 2,567 Answers
When water spills into a notebook, you should fully disassemble the notebook & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the notebook.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you might have to replace the keyboard.
Posted on May 23, 2011
Start menu does not appear when clicked.
what occured for this to happen did move your laptop while it was working ?
scroll to bottom toolbar right click select toolbars at the top of a list select desktop
this will give a desktop icon in the toolbar
select it then select control panel all contol items look for keyboard hardware make sure you have the right keyboard selected
select properties you will see driver and driver details
or
restart your computer press and hold the delete or f2 key to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Nov 12, 2011 | Dell Inspiron Mini 10 Notebook
Keyboard on Inspiron Mini 10 is not working right. Had chocolate spilled on it. How do I clean it.
Because laptops are portable, people tend to eat and drink over them. They lay the laptops on soiled surfaces and stuff them in dirty book bags. With all of the wear, tear and abuse that a laptop sustains, it's no wonder that the keyboard can become quite dirty. When a keyboard becomes dirty, often times the actual keys won't work. It is commonplace to find dirt, debris and food under the keys of a laptop computer. This causes the keys to not engage properly, rendering them useless.
1.Run a duster over the keys of your Dell laptop. This will remove any dust or small bits of debris that are causing your laptop keys to get stuck and not work. Test your keys once you have dusted them.
2.Spray the laptop keyboard with condensed air. Hold the air nozzle (you will often insert a small plastic tube into the nozzle) about 4 inches from the keyboard. Spray liberally, and use a back-and-forth motion while you work. This will remove most pieces of debris that may be stuck under the keys. Test the keys to see if they now work.
3.Place the tip of your flat-head screwdriver underneath the right-hand side of the key that is not working. Lift up gently and the key will pop off.
4.Dip the tip of your Q-tip into the rubbing alcohol and rub around the area where the key meets the keyboard. This will remove any final bits of dirt and debris. Allow the area to air dry. Repeat on as many keys as needed.
5.Place the loose key directly over the space where it belongs. Note the small piece of rubber. Hold the center of the key directly above the rubber piece and press down. When you hear a small clicking sound, the key is secure.
Sep 09, 2011 | Dell Inspiron Mini 10 Notebook
My inspiron 1018 won't boot. i need to reinstall or repair my software. it does not have a cd drive. please advice action.
The Dell Inspiron Mini 10 series of netbooks come with recovery software that can restore your netbook's original factory settings. Dell Inspiron Mini 10 netbooks with Windows XP, Windows Vista and Windows 7 can be recovered to the factory settings using a recovery partition on the hard drive.
Windows Vista or 7
Turn on or restart your Dell Inspiron Mini 10 netbook. Press the "F8" key repeatedly when the "Dell" logo appears on the screen to be redirected to the "Advanced Boot Options" menu.
Highlight "Repair Your Computer," and then press "Enter."
Highlight the language layout you want to use for your keyboard and click "Next." Enter your username and password if prompted. Click "OK."
Click "Dell Factory Image Restore," and then click "Next." The recovery software on some Dell Mini systems may require you to click "Dell Factory Tools" followed by "Dell Factory Image Restore" and "Next."
Click "Next" if you understand the netbook will be restored to its original factory settings. The recovery process will begin.
Click "Finish" when a message appears saying the recovery is complete. The netbook will restart and boot up to the Windows Vista or Windows 7 set-up screen, where you can begin personalizing your netbook.
Windows XP Recovery
Turn on the computer. Press the "Ctrl" and "F11" keys at the same time while the computer is booting up to access the recovery software.
Click "Restore."
Click "Confirm" to begin the recovery process, which shouldn't take longer than 10 minutes.
Click "Finish" to restart the computer and finalize the installation. Click "Yes" to restart the netbook again. The computer will boot up to the Windows XP setup screen
Here is a link which will take you to the site which will allow you to download a ZIP file with a WEB PAGE type service manual for your 1018, after a 45 second wait. (They want you to sign up for premium service but NOT NEEDED) Click again after wait?
After download, open the ZIP file and copy all contents to a new folder. Double click the Contents.html file to open in a web browser, then use the built in shortcuts to navigate the manual.
http://www.laptopmanual.net/manual/Download_Dell_Inspiron_Mini10_1018_Service_Manual/2846/1
If you like this - Please vote.
Jul 25, 2011 | Computers & Internet
Dell mini 1018, upgraded memory to 2gb, worked fine except ribbon cable connector broken. Where can I get another 1 cent piece of plastic, or should I just use a usb keyboard?
I encountered a novel way to resolve that issue on an Inspiron 1110, where the person working on it had also broken the Keyboard cable connector clip. They used clear packing tape to hold the ribbon cable in the connection. It may take some diligence, but you may be able to get a decent cable connection that way.
Jul 12, 2011 | Dell Mini 1018 Notebook
My laptop is password locked, and this morning I tried logging on with my password and it says that it's not correct. I tried all the capslock and capitalization errors and it still isn't...
Are you sure a keyboard key isn't stuck? Try checking whether the shift or capslock keys have become stuck, also consider the possibility that someone could have changed your password. If that doesn't help, you should try this software. Use another windows PC capable of burning CDs.
Jul 05, 2011 | Dell Inspiron Mini 10 Notebook
The shift doesn't work. with caps-lock i can make the capitals, but not with the shift. either left or right. an external keyboard on the laptop did work.
Kindly run Dell Diagnostics.
Boot to F12.
Select Dell Diagnostics.
Custom test for Keyboard.
If shift key failed you need to have your keyboard replaced.
May 18, 2011 | Dell Inspiron 1525 Notebook
My Dell inspiron mini 10 is just over 1 year old not used very much at all, last week for no reason there is no display on the screen, I tried to reboot on battery power and ac no luck. Thanks Frank.
There are 3 mini 10 models sold by Dell. The Inspiron 1010 (Mini 10), Insprion 1012 (Mini 10) and the Insprion 1018 (Mini 10v). Depending on which model you have, you can try to connect an external monitor and see if you get a display. The 1012 and the 1018 have a 15 pin VGA plug on the left side of the laptop and the 1010 has an HDMI jack for video. If you get a display then your LCD display is bad and needs to be replaced.
Feb 07, 2011 | Dell Inspiron Mini 10 Notebook
Fomating dell inspiron mini 10
You can make a bootable USB stick with everything you want and boot from it.
Stelios.
Feb 21, 2010 | Dell Inspiron Mini 10 Notebook
Dell Inspiron Mini 1012 Netbook (IM1012799OBK) Logo
1,404 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
