Question about Nikon COOLPIX P100 Digital Camera
My problem is.. when I insert my memory card a message goes "this card cannot be used" please help me to solve my problem in nikon s210. thanks
  • 102 Answers
I'd recommend that you use asoftech photo recovery which is one of the best card recovery tool.
Posted on Feb 17, 2013
    Guru:
  • 223 Answers
Yeal, and you can try Card Data Recovery. Very nice photo recovery program specialized in recovering photos in memory card.
Posted on May 24, 2011
    Master:
  • 346 Answers
Greetings - The message indicates that the file system of the card has been damaged. If you reformat the card from the camera's menu it will be fine to use again.
The problem, of course, is if there are photos on the card you need to recover. There are many tools that will help you try to recover your data (no guarantees). HERE is a list of such software, some free some not, with user ratings.
If you need to recover photos (DO NOT REFORMAT) the SD card!
Good Luck,
Mikeywaf
Posted on May 23, 2011
I got message "system error
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
  1. Use the memory card that originally came with the camera (or a Nikon approved card) [/*]
  2. Remove and replace the battery [/*]
Mar 05, 2011 | Nikon Coolpix 8800 Digital Camera
When memory card is inserted a message apears on the screen saying this card cannot be used. the card is formated, unlocked and is working fine in my other nikon camera, please help. i cant even acess...
Hi , when you insert other memory card the error is still remains? If your answer is yes ,the camera needs to inicialize try to do this in camera menu without a card. Err remains after initialize contact Nikon service.
Greethings
Feb 17, 2011 | Nikon COOLPIX P100 Digital Camera
Can nikon colpix S210 be used for webcam.
You can't. The S210 was designed as a camera, storing high-resolution pictures (and videos) to a memory card. It was not designed to stream low-resolution videos live to another device.
Jun 20, 2010 | Nikon Coolpix S210 Digital Camera
The camera keeps showing the same message '' memory card is write protected'' I can not use the camera because of this, also when I go to reformat card it passes over that so I can't reformat the card :-( ...
Remove the SD or SDHC memory card from the camera. Look at the front of the card, on the left there should be a little slide with an arrow pointing down that says "Lock". The slide should be in the "up" position.
Nov 27, 2009 | Nikon COOLPIX S200 Digital Camera
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
Formatting the Internal Memory
To format the internal memory, remove the memory
The Format memory option appears in the setup
menu.
Formatting a Memory Card
When the memory card is inserted in the camera, the
Format card option appears in the setup menu.
Hope this helps
Ian
Aug 09, 2009 | Nikon Coolpix S210 Digital Camera
Memory card works in PC but not in my Nikon camera.
you have to set the setting on the camera to write to card and not to camera internal memory, look at the manual about that, if not post again
Aug 08, 2009 | Nikon Coolpix S210 Digital Camera
I cannot download from the S210 onto my laptop
Capture beautiful memories perfectly with a high quality battery for your Nikon Coolpix S210 digital camera. Rechargeable Li-ion 3.7V 660mAh Nikon Coolpix S210 battery for sale,20% Off! Full one year warranty! Website: http://www.nikon-coolpix-replacement-battery.com/coolpix-s210.htm
Jul 26, 2009 | Nikon Coolpix S210 Digital Camera
Cannot transfer pictures from camera to computer
Try formatting the memory card before inserting it into the slot. also try using the memory card that you were using before you got all these problems
Jan 09, 2009 | Nikon Coolpix S210 Digital Camera
Nikon COOLPIX P100 Digital Camera Logo
67 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
