Question about Garden
I need a diagram for the timing belt on my castel garden 20/122
  • 252 Answers
I need a diagram for - pauly46_0.gifpauly46_1.gif hi there winger1886
pauly46 here
with 20/122 the blade timming must with one blade vertical and one blade horizontal
doesnt matter which one but as long as there is 90 degrees between blade as the rotate
in the picture the r/h blade rotates anticlockwise and the l/h blade rotates clockwise
the picture for belt / blade timming is straight forward - loosen tensioner rod and back it off completely , loosen 2 x bolts under the two toothed pulleys and remove the 2 belt guide/ stoppers from the l/h side - place both blades in the rqd position ( you may need someone to hold other blade in rqd position - fit the belt onto pulleys as in the diagram- continually check while fitting that timming has not moved from where you placed them ( they have to be 90 degrees from each other ) and then tighten the tensioner rod to hold position - rotate by hand recheck timming - if good loosly fit guide the 2 guide stoppers to l/h side and place 3.5 kg of tension at the middle point of the longest run of timmed belt ( belt should only deflect 10 mm with 3.5 kg of tension )
once tensioned tighten the 2 bolts under the toothed pulleys and tighten loc nut on adjuster
tighten the 2 stopper / guide nuts
in the picture the left hand blade is a l/h thread undo it right and tighten it left
the blade on the right is a normal thread left loose - righty -tighty
cheers hope it helps
Posted on May 23, 2011
Need a diagram of pattern to put belt back on a 2014 gtx 52 inch cut riding garden tractor
Kerri, Check the attached links,instruction and guides deck belt diagram, Good luck pg. 49 in link manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Mower Deck Belt Diagram DIY
Riding Mower and Garden Tractor Belt Routing Diagrams
http://www.husqvarna.com/ddoc/HUSO/HUSO2014_AAenAAfr/HUSO2014_AAenAAfr_GT52XLS_588018326.pdf
Jul 12, 2016 | Husqvarna Garden
Belt change 1972 craftman rider mower
Dan, Mower deck belt diagram /replacement links below. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
deck belt diagram craftsman riding mower Google Search
Apr 10, 2016 | Craftsman Garden
My mower starts easily, has NO motion forwards or reverse. s a drive belt slipping or what?
unset the brake push pedal all the way down and release it
Apr 10, 2015 | Garden
Belt diagram
some times they put a diagram under the foot rest of the tractor this might save you some time. Good luck
Aug 24, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need diagram for replacing belt on sears garden tractor model 917 287480
the bottom of the foot rest there is a picture of the belt routing
May 02, 2012 | Craftsman 26 Hp 54" Deck Yard Tractor
I need timing belt routing diagram for a 2000 honda accord 2.3L
Diagrams are not available on the web sorry to say remove the upper timing-belt cover and valve cover and double check the timing .. make sure you got the t-belt routed properly, put car on top dead , and check the alignment marks on the camshaft , make sure that the up mark in the pulley is up and you are not 180 degree off,
Jul 09, 2011 | Garden
Need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
May 10, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Lawn Mower Repair
if the mower is a castel garden the blade boss above the blade may be sheared and needs replacing otherwise top cover over deck has to be taken off to adjust timming belt
Oct 19, 2008 | Garden
Garden Logo
2,536 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
