Question about Cell Phones
My nokia e7 gets hanged since yesterday...i cannot open the battery coz its under warrantee... so what do i do...
Nokia e7 mobile is hang.do not switch off& any not function.plz give soulation what i do?
Posted on Sep 14, 2011
    Guru:
  • 825 Answers
If the phone hangs then please take it to a service center and get it serviced there... even after the service if it hangs, then fight for a replacement.... Because Nokia N8 and E7 series comes with replacement warranty if you are not satisfied with it...
Posted on May 23, 2011
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock?
Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above.
What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code?
If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7.
How to Restore Clean Setting at Nokia E7 Reinstall the Operating System?
Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted.
Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster?
It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7.
How to Fix Forgot Nokia E7 Pin or Password ?
If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above
The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
Mar 23, 2014 | Nokia E7 (16 GB) Smartphone
Reset password
  5. The process will do format to factory default Nokia E7.
Source: http://www.hard-reset.org/factory-default/how-to-easy-master-format-nokia-e7-with-safe-hard-reset/
Jan 15, 2014 | Nokia E7 (16 GB) Smartphone
Phone power on only when connected to charger
You need to replace the battery. Your battery is not holding charge.
Dec 20, 2013 | Cell Phones
My nokia e7 screen has gone to a black and green glitch back ground
Have you tried a reset by holding the power key down for 10 seconds?If that doesn't work you can try removing the battery for a few seconds.
I had a similar problem with my E7, it was dead and wouldn't respond even when I plugged it into my PC. But once I had removed and replaced the battery it was working fine and its not gone wrong since. Here's a good guide on removing and replacing the battery
Dec 28, 2011 | Nokia E7 (16 GB) Smartphone
How to reboot e7
When I hit my contacts key and it opened up to my my contacts page my phone just froze up and went dark after I hit the hang up key and now it won't even light up. I know the battery isn't dead. Does anyone have any idea what has happened and how to fix this problem. Thanks
Nov 13, 2011 | Nokia E71 Smartphone
My E7 get hanged ,its not starting now.
I had the same problem with my E7, it just wouldn't switch on, if you've already tried holding the power button down for 10 seconds then you'll need to remove and replace the battery, that fixed mine straight away. Just follow the guide below
Aug 29, 2011 | Nokia E7 (16 GB) Smartphone
Hanging problem
hi! you better 2 change your mobile software in cell servicing station! check is their any virus in your phone!
Good Luck
Jul 18, 2008 | Nokia N70 Cellular Phone
Reset
When your phone hangs, remove the battery, wait for 10 secs, again replace the battery & switch on the phone.In some cases after switching on the phone, you may have to reset date & time.
Jun 09, 2008 | Nokia 6708 Cellular Phone
Cell Phones Logo
705 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
