I have an acer aspire one netbook . just this day it started to not work when i turned it on up to where it asks me if i want to start windows normally after i press enter it hits a blue screen then restarts all over again i tried everything i can do to fix but I"m not good with computers and i have don't have the box and all the instructions that come with it anymore what do i do I need help!!!!
  • 639 Answers
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After restart Login and Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
Now restart windows again
Just do the following steps and your issue will be resolved.
1) Delete all unwanted data from Drive C.
2) Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on View Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you see inside Temp Folder
5) Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin and restart the PC and your issue will be resolved.
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Posted on May 23, 2011
    Sergeant:
  • 281 Answers
When you turn your laptop on start taping f8 at the same time.The screen will come to a screen that gives you some different options.Use the the up arrow button And highlight safe mode.Hit the enter key.The next screen will give you the option to go into safe mode by choosing yes or doing a system restore if you chose no.Once your in safe mode You need to go to start >control panel >system> advanced>start up and recovery>Settings >and clear automatically restart.Come out of safe mode with the start button.After your PC shuts down reboot it and preform a system restore.Start> All programs > Accessories > System Tools > System Restore. It's pretty straight forward from there,you can reverse any thing you do here.If you want I can give you some free utilities that will help you keep your PC running smooth .Thank You for choosing FixYa.com
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
Master password
Try removing the main battery and unplug the power, then hold the power on button down for 30 seconds, if this does not work, remove the cmos battery for 30 seconds to reset the bios
Sep 21, 2013 | Acer Aspire One AOA150-1784 Netbook
Restore Acer Aspire ONE D150-1165 Netbook
On help and support menu, type restore system. You will get an option to what date your OS will restored. Make sure you decide the correct date ( when the OS is still working fine). Key in the date ( or choose the preset date) the enter. Wait for process done completely. Your OS should be restored now.
Jun 28, 2011 | Acer Aspire One D150-1587 Netbook
I HAVE AN ACER D150 NETBOOK IS THERE A SPEECH TO TEXT PROGRAM THAT WILL WORK ON THE ACER
If you have windows vista or windows 7 installed, you have it already built in to the operating system. Click start > control panel > ease of access > start narrator
Apr 12, 2011 | Acer Aspire One D150-1587 Netbook
Hi, my acer aspire one netbook can't open XP and it says netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can...
The Acer Aspire One Netbook has a hidden partition containing the files required for restoration to the original factory condition. The restoration clears all user data from the C: drive and requires that you have the netbook plugged into its AC adapter as the process takes significant time during which it should not be interrupted at the risk of hard disk corruption. To begun the process....
1. power on the netbook while it is plugged into its AC adapter
2. during power-on, while the Acer Logo is showing, press Alt and F10 together several times
3. Acer eRecovery loads showing the Windows screen momentarily
4. follow the on-screen directions and make the selection to recover the factory default image
Apr 10, 2011 | Acer Computers & Internet
How to reset myacer to manufact setting
  1. Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
  2. Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
  3. Press the "Alt" and "F10" keys at the same time to bring up the recovery menu. Press "Enter."
  4. Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
  5. Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
  6. Connect the external USB device to your Acer Aspire One and transfer the data you saved earlier back to the netbook.
Nov 12, 2010 | Acer Aspire One Netbook 8.9" Notebook
Have a acer aspire one d250 with virus
Hi Thanks for your question.
Please click on Start then All programs then Acer Empowering Technology and chose Acer eRecovery Management. This will guide you through the process of recovering your netbook. Please do not hesitate to ask more questions. Good Luck
May 05, 2010 | Acer Aspire One D250 (99802378332) Netbook
Computer will not start up
Acer Aspire One netbook stays loading windows xp and goes nowhere went to last known config..... nothing.......went on safe mode with networking ......nothing...samething....starts up loading windows xp and stays there.
Jan 02, 2010 | Acer Aspire One Netbook 8.9" Notebook
Hi there, I bought an Acer Aspire One netbook two days ago. That evening I installed AVG anti virus and Online Armor. Everything seemed to be working fine. I shut the netbook down. Yesterday evening I...
yeah I'll give you the best suggesstion since you have just bought your acer notebook take it back to the store and have them re-installl windows for you,since its just been two days they will do anything for you
Oct 11, 2009 | Computers & Internet
I have acer aspire trying reinstall windows xp?
Put the disk in,restart computer and tap F12 while it is starting up.
May 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
