Model#RMC-120MP When lighting i hold button down for 30 sec and release and it goes out in 20 or 30 sec
    Sergeant:
  • 281 Answers
Sounds like your thermocouple is shot.It's that little tube that the pilot light heats up.I am assuming that you have started this heater before.The thermocouple has to stay a certain temperature to keep the gas flowing.You can buy universal thermocouple kits at your local hardware store.Make sure gas is turned off.Loosen the coupling nut on the outside of the tank then remove the tin and remove the heating part.The whole thing is a small 1/8 tube.Bend new one like the old one and put it back in place.If the kit has yellow Teflon tape wrap the threads on the coupling and tighten.Turn the gas back on and test for leaks with soapy water.Thanks for choosing FixYa.com.
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
Posted on May 23, 2011
After firmware upgrade for my netgear prosafe gs724t v3, the smartswitch is not accessible anymore, i can\t even rest to factory defaults
You might have used wrong firm ware..??? Possible bricked unit.
Try 30 - 30 - 30.. With power on, hold down reccessed reset button for 30 seconds, still holding button down, pull out power wait 30 secs. STILL holding button, plug in power, continue holding button for 30 more secs and release. power off then on and pray.
Aug 13, 2013 | NetGear PROSAFE Computers & Internet
I tried to change my password and i closed the page before it finished and when i tried to connect to the internet it wont work help
Perform a reset. Find the hidden reset button, usually close to power line, find a small hole with a little button behind it. Use a toopick or similar to hold down power button for at least 10 seconds. This should restore it to factory setting and default password. Google the model # and brand and "default password" if you don't already know it. If this does not work to reset it, then try this...
Hold down reset button for 30 seconds, still holding button pull the power out, keep holding button for 30 secs, STILL holding button - plug in power then release button after 10 secs.
Yes 30 secs each cycle is overkill, but allows to be sure.
Aug 11, 2013 | Computers & Internet
Error code 5200 - What does it mean and how can I fix it?
It means that yo have a problem in your cartridge here are some steps how to reset your printer cartridge.
  • Power off the printer
  • Hold the stop/reset button then press and hold power (for 5 secs)
  • Hold Power and release the stop/reset button
  • Press the stop/reset button twice
  • Release power button
  • Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
  • On the 3rd press the inicator should be orange.
  • Press the power button to set data
  • To set data remove cartridges then replace.leave for 20 or 30 secs
  • Press the power button again to shut down
  • Then press power button to power up.
  • The printer will feed one piece of paper through then set language and counrty.
Then ink should be reset
Good Luck..
Jul 29, 2011 | Canon PIXMA MP180 All-In-One InkJet...
After replacing the ink cartridge printer still shows cartridge levels at 0%
Hi
You have to reset the cartridge
To Reset the HP Cartridges Works 100%
On the 3rd press the indicator should be orange.
Thanks
Aug 15, 2010 | HP Office Equipment & Supplies
Reset the maintenance over due light
Turn the key off, Hold the trip button down, Turn the key on, continue to hold the trip button until the light goes out, should take about 20-30 sec.
Jun 12, 2010 | 2005 Honda Odyssey
How do I reset printer after putting ink cartridge in
To Reset the Canon Cartridges Works 100%
Relase power button
Please rate my rsponse!!
Jan 29, 2010 | Canon PIXMA MX310 All-In-One Printer
Reset To551 ink cartridges
  • Relase power button
  • leave for 20 or 30 secs
  • then set language and counrty.
  • Then ink should be reset
Please rate my sesponse!!
Thanks, SF
Jan 28, 2010 | Office Equipment & Supplies
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Override alarm for color ink cartridge
Hi Redtail,
Try the following. It will not disable the alarm but will reset the in counter.
  2. Hold the stop/reset button then press and hold power (for 5 secs)
  3. Hold Power and release the stop/reset button
  4. Press the stop/reset button twice
  5. Release power button
  6. Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
  7. On the 3rd press the inicator should be orange.
  8. Press the power button to set data
  9. To set data remove cartridges then replace.
  10. leave for 20 or 30 secs
  11. Press the power button again to shut down
  12. Then press power button to power up.
  13. The printer will feed one piece of paper through
  14. then set language and counrty.
  15. Then ink should be reset
Dec 04, 2008 | Canon MX300 Office All-In-One Printer
2Wire Router will not power up.
If it is not getting any power at all,
only one of three things:
cord is fried/dead;
could be the outlet,
try something else in the same socket; or, the board in the ROUTER is dead.
Disconnect power cable WAIT FOR 20 sec and then reconnect it..Reset your router, ..To reset the router, the best way is to press and hold the reset button for 30 seconds, or to press the reset button for 60 seconds..and for first 20 sec hold the reset with the power cable connected and for the next 20 sec with out releasing the reset button disconnect the power cable and continue holding the restet button , and after 20 sec reconnect power back and then continue holding the reset for another 20 sec.. and then ncheck for the lights status ..
Try another power cord. Take it back to the store and have them exchange it or test it. They'll do that for free.
Dec 07, 2007 | 2wire (1000-400108-001) Router
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
