Question about Singer Sewing Machines
Thread from bobbin is not coming up and stitch is not proper
  • Singer Master
  • 1,133 Answers
Visit this website http://www.singerco.com/accessories/manuals.html
enter in your model number and download the manual for your machine, threading issues usually either bobbin not in correctly, thread not in tension or machine incorrectly threaded, so review the manual threading instructions and follow them to trouble shoot your machine.
Posted on May 23, 2011
SewExpress
  • 41 Answers
SOURCE: Picking up the bobbin thread
A few suggestions:
  1. Rethread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Hope this helps narrow down your stitching problems.
Happy sewing,
Kim & Linnette
Posted on Jun 27, 2008
  • 749 Answers
SOURCE: won't stitch properly
ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Posted on Nov 01, 2008
SOURCE: Thread is not coming up
YOUR PROBLEM IS THE TIMMING IN YOUR MACHINE. THIS HAPPENDS WHEN YOU FORCE YOUR MACHINE TO SEW SOMETHING OR WHEN YOUR NEEDLE BRAKES. nOT SURE HOW TO FIX IT. I HAVE THE SAME PROBLEM. USUALLY A TUNE-UP WOULD DO IT. IT'S ABOUT $99 TO $130.00 TO DO A TUNE UP. i WISH I KNEW HOW TO FIX IT MYSELF.
Posted on Mar 08, 2009
SOURCE: janome straight stitch loose
I don't know if this is the right answer for any of you, but thought I'd put my 2 cents worth in. Often this can be the bobbin in backwards. It needs to unwind a certain way depending on the machine. I've heard a phrase for this: Mind your p's and q's which means some wind off to the right like a q, others to the left like a p. Mine has to unwind one way then be slipped backwards into a little slot or it does that loose bottom thread looping and bunching someone here mentioned. It seems everytime I get that problem I rethread the top thread 100 times before it clicks again and I remember it could be the bobbin thread. Either your manual will tell you the correct way, or you could experiment and try one or the other. Once you figure out whether you're a p or a q, mark it on your machien somewhere to remind yourself.
Good Luck and Happy Sewing!
Posted on Apr 04, 2009
  • 1116 Answers
SOURCE: Bobbin thread will not stitch.
Have you had the machine serviced since you purchased it? This is something that should be done at least once a year.
Take the machine to a certified Singer dealer and explain what is happening. There may or may not be something that needs to be adjusted.
Your warranty is still in effect, but is now limited. Attempting to repair it yourself or having someone who is not a Singer dealer repair it will invalidate the remaining warranty.
Posted on Apr 16, 2010
Machine is not making stitches. Properly threaded and the thread advances, but no stitches.
Install a brand new needle.
ALWAYS RAISE the presser foot and rethread from the beginning.
Make sure the thread path for the top thread is correct and that the bobbin case is threaded properly and the bobbin turns the correct direction in the bobbin case--install the bobbin case.
If the machine still will not stitch, it is likely it has been knocked out of time.
Search for sewing machine timing or take it for service.
Nov 16, 2017 | Sewing Machines
Skipping right side stitch on a zigzag stitch, so when i am running a zigzag stitch when the needle goes through the fabric and comes back up it pulls the stitch back with it ??
check your bobbin and is the needle good and sharp and the proper length.make sure its not bentthe tiniest defectt n a needle can mess up any stitch.
how does it work on regular stitching.
most problems with machines involve.bad needles incorrect threading of bobbin or spool,dirty bobbin,incorrect needle.
it sounds like the needle isnt catching the bobbin thread.
hope this helps
Apr 05, 2017 | Sewing Machines
Purchased singer 6233. Filled bobbin and thought it was installed properly, but stitching just comes out by pulling on thread.
Most likely a tension problem. Tighten the upper thread tension. If the top and bobbin threads are not interlocking, then the machine is out of time. Search for sewing machine timing or take it for service.
Feb 27, 2017 | Singer Sewing Machines
I have a Brother PR-650. When machine starts to sew the first stitch, Thread comes out at the top usuall sticking up about a half an inch. What can I do to avoid this
When threading the top thread, ALWAYS RAISE the presser foot. This releases the tension disk so the thread will seat properly. Be sure the thread path is correct and that you have pulled at least 4-6" of thread tail through the needle before taking the first stitch. Begin the first stitch with the take-up lever at it's highest point. Begin sewing slowly--even hand-rotating the handwheel through the first stitch may help. Gently hold the top and bobbin thread tails in your left hand while taking the first stitch to prevent the thread from pulling backward.
Pulling the bobbin thread to the top of the fabric is also beneficial.
How and Why to Bring up the Bobbin Thread
Feb 23, 2017 | Brother Sewing Machines
Machine won't stitch
If by "won't stitch" you mean that the top thread will not pick up the bottom thread, make sure you have the needle threaded properly. If the machine is a top loading bobbin, the thread goes in the needle from front to back. Same if it's a side loading bobbin (bobbin faces you as you sew). If it's a front loading bobbin (bobbin faces left of machine), the thread goes in the needle from left to right.
Oct 12, 2014 | Sewing Machines
Thread keeps breaking and i can't get the stitch setting to go from stretch stitches to normal stitching
Be sure to check that the machine is threaded properly into the needle. Also look at the instruction book to be sure you have the bobbin inserted corectly and that the thread is place properly (threaded correctly) in the bobbin area. Some machines have a diagram on the machine, but if you do not sew frequently; it's easy to mis-thread the bobbin. Did your bobbin thread wind properly onto the bobbin (not loose or loopy). That too, can be a problem. Best of luck. Susan
Aug 04, 2009 | Kenmore 756A-30BH Mechanical Sewing...
Underneath stitch bad
Sometimes even though the tension is at recommeded placement, you may find with various fabrics or threads, you have to adjust it. I would try to raise the tension just a bit. Try it a little at a time until you achieve a stitch you are happy with. If adjusting the tension does not correct the problem, double check your threading. If sure it is threaded properly, especially going through the tension assembly...check your thread. I have found that the thread you use can and often does create tension problems. Try changing the thread and see if the stitch quality improves.
Mar 21, 2009 | Bernina Virtuosa 150
Won't stitch properly
it sounds like you might need a new bobbin case to me try that and see if the issues you are having stop hope this helps
Sep 20, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Jun 25, 2008 | Janome D'cor Excel 5018
Stitch pattern not proper
be sure that the thread is routed properly. Then check on the bobbin holder, it may be defective.
Sep 05, 2017 | Sewing Machines
Sewing Machines Logo
116 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
