Question about Sub-Zero 700TCLH Bottom Freezer Refrigerator
The refridgerator portion of the unit quit working. the freezer draws are still fine. the air intakes under the front door were full of cat hair from the prevous owners. what is my best course of action? thank you for your time.
  • Sub-Zero Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 23, 2011
Cleaning house for a friend - ice dispenser in freezer door dispenses ice AND gnats! The ice bin in freezer is clean and free of gnats and the door seal appears loose. Is it possible that the gnats a
Yes, please pull the unit out carefully - once it is unplugged and off - and clean everything you can reach. If there is a toe grille take it off the front and clean it with a vacuum or condensed can air. Also clean the inside and make sure you don't notice any gaps in the door seal. Gnats and bugs can get inside little gaps, or there might be spoiled food that is causing them to appear as well. Check everything and make sure no vents inside the cabinet are blocked by food items.
Sep 18, 2012 | Frigidaire FRS3R5EMB Side by Side...
Kenmore Elite 79577559600 refridgerator warm, seems to be not working but freezer working fine.
the damper-vent door between the refrigerator and freezer is probably frozen shut therefore not letting the cold air from the freezer enter the refrigerator,deice it with a hand held hair dryer,then check if its controlled by a motor or manually and see if these could be your problem
Jan 01, 2011 | Refrigerators
Top portion of ice box really warm
The freezer gets first dibs on chilled air and there is a fan that should circulate a portion of it into the refrigerator cabinet and I suspect this has failed.
Check the fridge carefully for any vents in the back of the cabinet. When the compressor is running, you should have some noticeable (chilled) air movement from these, especially if you wet your fingers and hold them in front of these vents. If you sense no air movement, the fan has stopped.
To locate the fan and the access to it, try entering your make and model on the Sears Parts Dept. page linked below. They maintain many thousands of line drawing illustrations of all makes and models. If you find yours, you should be able to discern whether this is a DIY job or not.
Good luck-
Sears Parts
May 01, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Amana 25 Cu. ft. French door Freezer Fridge quit
IN MOST CASES THERE IS A FAN THAT SENDS COLD AIR FROM THE FREEZER TO KEEP THE FRIDGE COLD. EITHER YOUR FAN MOTOR HAS GONE BAD OR YOUR THERMOSTAT IN YOUR FRIDGE IS BAD.
Feb 20, 2010 | Televison & Video
Kenmore refrigerator with bottom freezer. freezer works,refrig does not. Can you help me find the problem .Also, bar between the upper doors gets real hot.
I had this problem. The Evaporator fan in the freezer was working but no air would be circulated from the freezer into the refridgerator. To test this you open the door of the freezer, and depress the door button(s) of the upper refridgerator doors so that the light extinqueshes in the refridgerator. This will engage the evaporator fan in the freezer. You can check to see if air is venting from the freezer into the refridgerator by feeling the holes at the top most part of the multi-air flow channel in the refridgerator. If air is comming out when the freezer door is open, close the freezer door and feel if air has stopped. If you have kept the upper door buttons pushed in on the refridgerator and now have the freezer door closed, you should still hear the fan running, but may have not air flow with the freezer door closed. The cause of this is the air return channel from the refridgerator to the freezer is either frozen or clogged. My return-air channel was not frozen but clogged by a residue from something that spilled inside of the bottom of the refridgerator. The return-air channel has two vents in the rear-bottom of the refridgerator that exit into the freezer behind the evaporator (cooling coils). You can't see it even if the back interior panel is removed from the freezer compartment.
The bottom line here is that if air is prevented from moving from the refridgerator, back down to the freezer, then your refridgerator will not cool, but your freezer will work just fine. You will not need to replace the fan, unless the fan is not functioning. You may need to check the dampener, to ensure that your multi-air flow channel is open - (allowing air to come into the refridgerator). The multi-air flow channel is easy to remove once all of the shelves are removed from your refridgerator. Only 2 screws holding it in (securing the center rack top and bottom). The top screw is located behind a small plastic cover that can be removed.
That's what worked for me.
Jan 12, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
The refridgerator portion of my side by side fridge is luke warm. The freezer appears to be working fine. What can I do to fix this?
My guess is, your defrost timer has quit running and ice has built up blocking the passage of cold air from the freezer. It could be the defrost thermostat also, or just a stuck vent door. But I don't think so.
The defrost timer is under the refrigerator, accessible from the front. Normally, it turns on three times per day, turning on a heater element in the freezer, melting ice. The melt water runs down to a plastic tray under the refrigerator where it evaporates. When the freezer warms up, a defrost thermostat then turns off the juice to the heater.
Access the timer from in front. Use a screw driver in the manual advance slot to turn the timer till it clicks. Now it is defrosting. With ice buildup sufficient to block the air passage it may take a long time to melt all that ice.
If you dig into it and try to melt ice yourself, use a hair dryer rather than boiling water. That's what I've been told, although I used the boiling water.
Hope this works for you.
Dec 30, 2009 | Refrigerators
Top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
May 08, 2009 | Refrigerators
WATER QUIT RUNNING IN DOOR
Okay. My appliance is around four years old. The first time the water quit working was about a year ago (ice cubes / dispenser was fine). I just let it go and didn't worry about it. One day months later, I found it functional again. That lasted about a month or two, then it recently quit again. Tonight, I located the water supply line coupling under the unit on the left side under the freezer door, about five inches from the hinge. I separated the coupling (push lock type) and pressed the water dispenser lever. After a few seconds, the water flowed out just fine. I re-attached the coupling, turned the freezer coldness selector to 0 (off) opened the freezer door and fetched my wife's blow dryer. I ran the dryer along the inside of the freezer door near the black door seal frrom the hinge up to the water/ice dispencer compartment. I also ran it all along the back of the dispenseer compartment to the handle side of the door as I am unsure of where the water line runs. After about ten minutes of this, I attempted to dispense water with no luck. I continued with the blow dryer until the plastic and even the door seal were very warm to the touch. I closed the door and attempted to dispense water once again, and this time it worked. I turned the coldness selector back on. This time I set the freezer to 3 and the fridge to 7. I ran several cups of water through the dispenser since it's been sitting in the line for a while before drinking any. As for the "reservoir," I don't where or if one exists, but heating up the inside of the door from hinge to dispenser worked perfectly. Hope this helps someone!
Cheers!
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag SidebySide model MZD2766GES Fridge portion not working...
yes probably the a.d.c. but make sure all ice is defrosted from evap. coil. remove the freezer panel and use heat gun or hair dryer.
Aug 05, 2008 | Maytag MZD2766GES Side by Side...
Sub-Zero 700TCLH Bottom Freezer Refrigerator Logo
125 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
