Question about Ecoquest Breeze AT Living Air Purifier
All the lights are on and the fan works but I don't get any ozone smell like I used to. The little light inside next to the plate works. Any thoughts?
    Guru:
  • 1,833 Answers
This usually indicates that the plate is cracked or not making proper contact. Take away the purification plates and appraise them for damage. If they are broken through, then they want to be replaced.
Try washing the purification plates with a result of one part tepid water and one part ammonia. Take an aged toothbrush and fall it into the ammonia result and scrub the metallic grids on the purification plate. If there are bank deposits on the grids, scrub them until they gleam and perform both boundaries of the plate. Scrub the metallic acquaintances that contact the plate as well. Rinse off the plate with tap water and sanction it to dry fully completed for 24 hours or use a hair dryer to dry the plate.
Posted on May 23, 2011
I have the Alpine Living Air machine - the green light does not come on just the amber one. I don't smell any ozone odor. Cleaned the plates but not sure if they have to be installed in any special...
How long have you owned machine? Plates need to be replaced periodically to be effective and to generate ozone. Depends on usage but at least every one-two years. They run about $15 a piece. I can get you some.
Jul 07, 2011 | Alpine Air XL-15 Air Purifier
Living Air XL (no smell)
TEST THE CONTINUITY OF THE BULB AND THE WIRING AND THE PARTS INSIDE.
DOES THE UNIT STILL WORKS NORMALLY ASIDE FROM THE BULB?
Sep 25, 2008 | Alpine Air XL-15 Air Purifier
I have an Alpine ZL-3 and we can't smell the ozone any more. Our air doesn't smell fresh any more. My husband has been cleaning the ozone plate with warm water. Does this have anything to do...
OK- The plate needs brushing with a bristle brush to get the oxidized crystals and grime off it. If you don't, it will not create ozone. I never use water any more, it rusts the plate eventually. Rust also stops the process. I use rubbing alcohol. Cheap and safer than ammonia...MUCH safer. Blow dry. The only bulb is the radio wave ionization indicator bulb, attached to the round antenna-looking thing. You should wipe the ionizers off with alcohol every 6 months too. If they are gunked up they don't work nearly as well. Look up the Living Air Classic manual.
May 25, 2011 | Alpine Air XL-15 Air Purifier
My xl-15 air purifier works but it does not blow out air with the purified smell. I think I see people calling it ozone.bthere used to be what looked to be an illuminated orange light behind the fan. It...
Easy. You need new plates in the machine. They cost about $15 a piece. Google 'ozone plates for XL-15' & sources will come up on where to buy them. Remember to clean the plates every 30-45 days w/ 50-50 solution of ammonia & water & a tooth brush on these plates. Dry thoroughly w/ hair dryer before putting back in machine.
Feb 15, 2011 | Alpine Air Purifiers
My Flair stopped working correctly,so I purchased new Ozone plates. It still doesn't provide that clean ozone smell. I took mine apart and cleaned it and noticed a small bulb inside that doesn't light up....
pull the unit out of the enclouser and check the bottom for a circuit board and on the board their is a glass fuse see if it is blown. Also on that same board their is a small round black fuse that is labled f21 it is a 400ma 250 volt fuse on my unit and is soildered in this fuse is just for the ozone
May 23, 2010 | Ecoquest Flair Air Purifier
I just purchased a used Alpine Air XL-15 from ebay.no ozone spell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 10, 2010 | Alpine Air XL-15 Air Purifier
HELLO AND GOOD MORNING I HAVE A FLAIR AIR
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Flair Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Living Air XL 15, no ozone
My XL-15 had the same problem a few years ago. I had a broken wire on the fan, and the Ozone problem turned out to be a problem with the power supply. I had to send it in to have it repaired.
Mar 18, 2008 | Ecoquest Living Air Classic Air Purifier
Ecoquest Breeze AT Living Air Purifier Logo
Top Ecoquest Air Purifiers Experts
fordexpert
Kory Ronning
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
