Question about Jandy Laars Lx 400,000 Btu Heater
Our Jandy LX400N does not show any error messages but the water that comes out of the jets is intermittently hot, then cold. I have never heard of a hot tub problem like this. Is there a way to just have the hot water only coming from the jets? We don't see any settings on the display. Thanks!
    Top Expert:
  • Jandy Master
  • 4,262 Answers
Check gas pressure maybe running out of gas then it goes out then relites check to see if heater is running continuously bad manual bypass replace it by the plumbing in and outs
Posted on Mar 05, 2016
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: I'm installing a used jandy lx400n pool
Yep...tie it to the line side.
John
Posted on Jun 29, 2011
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
AGS error code
check gas pressure if ok then see if runs 7 sec if shuts off then check flame sensor if blower doesn't start check safety circuit
Nov 24, 2012 | Jandy Lx Pool & Spa Heater - Electronic...
Jandy lx250 won't keep water hot
what size pump motor slow the water down put a bypass in
Feb 27, 2012 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
How do i replace the ignitor in a Jandy lx400n-l, the manual does not show how to remove covers to get to the ignitor? thanks mike
shut off power remove the burn rack pull out ignitor wire goes under rack replace and put back together make sure no gas leak
Jul 13, 2011 | Jandy Lx Pool & Spa Heater - Electronic...
Message says hi lim sw
replace hi limits ther are 2 of them
Jul 07, 2011 | Jandy Lx Pool & Spa Heater - Electronic...
My Bristan Meridian Show start ok with hot water then after a few minutes the water runs cold. Even if you try and increase the temp it still remains cold. You can switch of the shower and start again...
It sounds like 1 of 2 things to me. I will start wit hot water heater. The first test for the water heater is to have someone run the hot water while you hold the hot and cold pipes and see if the water is coming out of the water heater cold when the shower goes cold. Of the water heater is cold coming out then the problem is in the heater. ether a lower element is bad or the dip tube is broken at the top of the tank. if the hot water heater continues to put out hot water when the shower goes cold then it has to be the mixing valve for the hot and cold mix at the shower and that valve will have to be repaired or replaced. hope this gives you a good start. let me know if I can help further.
Dec 24, 2010 | Home
The message flo is showing on the display
THATS WHAT THESE DO IT WILL CYCLE AND KEEP THE WATER MOVING SO THERE ARE NO COLD SURPRISES WHEN YOU TURN THE JETS ON.. REMEMBER TO VOTE .. THANKS
Feb 14, 2010 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Fan for the heater will not come on showing service HI LIM SW on screen
That would mean the high limit switch. Check it and see if you can reset it. It may have gone bad. Check first and if needed find a replacement part. Good luck...Lee
Nov 25, 2009 | Jandy Lx Pool & Spa Heater - Electronic...
No Cold Water Wash; Only Hot
When doing a hot wash the machine is designed to take both hot and cold water. This is because it can heat the water to your selected temperature but if the water coming in is too hot it needs to cool it down to avoid heat damage to your laundry.
Hope this helps & thanks for using Fixya.
Dec 18, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Jandy Laars Lx 400,000 Btu Heater Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
