Question about LG WT5101H Top Load Washer
My 6.5kg LG Fuzzy logic toploader stops spinning when it has 3 minutes left to the spin cycle and then goes back to the rinse cycle filling up the washer with water. It repeats this. At three minutes left of spinning goes back to rinse. It continues this indefinitely until manually stopped. I've been told it is because of uneven weight distribution but the machine worked fine for a month. I never do big loads.
  • veronique_ps May 23, 2011
    There are no error messages. There is some unusual clicking when it changes from the rinse to spin cycle.
    Top Expert:
  • LG Master
  • 78,308 Answers
The washer control panel is defective.
Posted on Jul 13, 2017
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
ginko
  • 19396 Answers
SOURCE: my toploader "fuzzy logic" 6.5kg
Hi.
If there is no spin, c licking noise before spin may come from a relay in control module, from lid switch motor, or from the fuzzy logic control unable to start drain pump. This last problem may occur because of residual water inside the machine tub.
You should run a diagnostic cycle. The procedure is explained in user manual. LG should use the following:
Press Spin and Temp. and Power buttons simultaneously to enter diag. mode.
At the end of the process you should get an error code that will tell you what the problem is. If there is a code already, then please let us know the code.
Posted on Feb 01, 2011
My toploader machine is not rinsing or spinning the model is a LG Fuzzy logic WF-T7014pp
if it does not rinse its a different case,,,,,nd if it does not spin is another ,,,check on the door lid,its a magnet,,,,,,,,,,,,,,,,,attached the washer pic ,,,so i can tell u what to do............
if u have a magnet tryputting it between the door and its main program board,,,centre nd try
Jan 23, 2015 | LG Washing Machines
LG Fuzzy logic 5.5 WFT552 goes to spin and then bangs around horribly before going back to the rinse cycle??? WHY?? Can anyone help please?
Could be broken spring unplug...remove top cover if front loader /inspect check drum.....make sure its level on the floor
Jun 27, 2012 | Washing Machines
Lg Fuzzy Logic 5.5kg Turbo Drum with I-sensor, Model WF-T552TH Washing machine goes through initial fill up, when changing to spin/wash works for 2 seconds, then stops spinning back and forth and shows dE...
There is a small magnet at the front of the lid that triggers the door error, mine was corroded and the lg people wanted $80 for a service fee.. Ha I went to my local hobby shop and got a small earth magnet and some super glue $1.50 later and she's fixed.. tadAaa.
May 11, 2011 | Washing Machines
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
heatman101
Apr 27, 2010 | LG WFT1071TP Top Load Washer
LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Apr 16, 2010 | Washing Machines
Smeg s750 washing machine -how to rinse only?
Advance the timer to rinse/spin part of cycle.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
LG WT5101H Top Load Washer Logo
101 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
