Question about Panasonic Televison & Video
How do I connect my wireless headset to my Panasonic TC-L42U22 TV? It only has a optical digital audio output, but no place for me to plug in my headset.
skotkolr
  • 558 Answers
SOURCE: Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
Posted on Apr 27, 2008
JollyRoger00
  • 59 Answers
SOURCE: Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
Posted on Sep 24, 2009
SOURCE: how do i get audio output from a LG 47LD520 with
Either use the white/red analogue audio outputs on the TV.
Or, you can get a Toslink optical to coaxial audio converter for $10 - $15 off ebay. http://cgi.ebay.com/TOSlink-Optical-COAX-Coaxial-Digital-Audio-Converter-/220657947104?pt=LH_DefaultDomain_0&hash=item33603d11e0#ht_1128wt_1139
Posted on Nov 09, 2010
SOURCE: i have a panasonic 50 inch tc-50px24 plasma tv. i
blinkin de red led tv panasonic plasma
Posted on Feb 13, 2011
  • 26 Answers
SOURCE: PS3 will not pick up
Just use the HDMI (HDMI is Audio + Video) also swap to the Channel before turning on the playstation.
See if that is any better.
Posted on Feb 28, 2011
How can attach external speakers with RCA plugs or a mini-plug? Is the digital audio output the only connection for audio output? (The model is TC-P50G25)
Well isn't this just a find how do you do!!
It appears that on this set there is no headset or other audio connection other then the optical?
It appears the only way to a traditional RCA audio jack is via a special adapter. See image. Inexpensive not sure of the quality of audio.
The best way would be to purchase a sourround sound speaker amp system with 5 speakers plus base woofer. These surround sound systems are usually have optical connected and for best results this would be my first choice.
Some have wireless back speakers to allow for easier installation.
RCA RT2781BE 1000W Home Theater System with Bluetooth This unit has two optical inputs and one digital input.
This is an inexpensive surround sound speaker system that should connect to your Panasonic TV optical output. Very available and I wanted to give you at least one option. Wires etc are a mess but the surround sound can be amazing. I would check all the reviews if you decide to go with this type of audio system. They can be confusing and in your case you need to have input control of volume with optical.
The following link is the manual for this particular Home theater System.
http://rcaav.com/wp-content/uploads/2014/11/RT2781BE_IB_0708.pdf
These audio systems can be very expensive. Less expenesive sorround can still provide great listening results.
Hope this helps?
Mar 03, 2016 | Panasonic Tc-p50g20 Viera G20 Series 50"...
How to plug my external speakers to my viera tv
This television only outputs digital audio called PCM / Dolby Digital, Fiber Optic so you may need an amplifier that has a digital in port (if the speakers are rca red and white cable plugs then the amplifier needs rca output ports). Then you would need to connect the amplifier to the speakers
. Unless the speakers have a digital in port which I am unsure on ,. The digital out audio port on your tv uses a fibre optic digital audio cable..
page 13 of the user manual shows this digital output port.
http://service.us.panasonic.com/OPERMANPDF/TCL42E50.PDF
Oct 28, 2014 | Panasonic Smart Viera E50 Series Tc-l47e50...
How do I get digital audio out from a panasonic panel to optical in on a yamaha amp
The TC-L55E50 has an optical output located on the rear of the TV. Simply connect the optical cable from the TV to the amplifier.
Mar 23, 2014 | Panasonic 55 inch VIERA 1080p 120hz LED TV...
How can I hook a vizio soundbar 2.0 to a Panasonic t.v. Model number tc-p42c1
TV's generally have optical / toslink connections for their digital audio output. I'm assuming the sound bar has a coax digital input, in which case you will need an adapter module. I have seen these on eBay for around $15.
Try searching: Optical Toslink Audio Converter to Digital S/PDIF Coax
Jan 22, 2014 | Panasonic TCP42C1 Plasma TV
I have a panasonic viera Tc-L42D2 Tv and have a amwT342 5.1 home theater system and has it connected using the opitical cable which i was told by panasonic that the only audio connection is the opitical...
Very sorry to inform you that the digital optical socket at the back of your AMW T342 is not digital in but digital out. In other words you can connect the audio output of the AMW to another device like a AV Receiver or a Digital recorder etc and not vis versa. They have not provided a digital input and unfortunately your Panasonic TV only has an optical digital out for audio .
Mar 21, 2011 | Audio Players & Recorders
Lg 42LH30 tv trying to connect a Sennheiser w/l RS120 wireless headset and I do not see an audio out connection on the back of the tv I looked up the specs of the tv and the only audio out I see is...
This is an optical digital audio output that uses optical fiber with Toslink optical connectors at both ends, from there it comes the name, since your wireless headset has only analog audio input, you'll need an optical digital audio to analog audio converter, to connect your wireless headset to your TV.
Mar 18, 2011 | LG 42LG30 42 in. LCD HDTV
How to hook up headphones to tv panasonic tc-42px24 using RCA cables
Hello, you need to use wireless headphones, which are supposed to be connected into the audio output left and right. Often sell the headset has been with the appropriate connections to all TVs. Anyway you should tell the seller the type of audio output connection on your TV there. I hope that was helpful!
Let me know if you need further guidance
Feb 28, 2011 | Panasonic Tc-42px24 42 in. Plasma TV
HOW TOO CONNECT AUDIO OUT?
hi,
u can connect the digital audio output (optical) to ur av receiver or any amplifier wich have a digital audio input(optica).
ok
Dec 21, 2010 | Panasonic VIERA TC-P54Z1 54 in. Plasma TV
Im trying to connect my boss sound system to my panasonic viera 42 inch plasma tv. my boss has only RCA, but the only sound out on the tv is the digital out! how do i hook up my boss to my tv?
You can purchase a brand "Gefen" optical digital audio to analog(rca output ) converter........they cost $70 to $90 just google that and you will find. If you are usind a cable or Satellite box,you could easily get the analog audio from those audio outputs to circuimvent the problem
Jun 15, 2010 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Want a TV wireless headphone with no headphone jack or audio out
You may have to connect the headset through a VCR or DVD player that does have the output connections.
Sep 05, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
Televison & Video Logo
134 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
