What is the make and model of the web camera? And what is the operating system you are running?What is the make and model of the web camera? And what is the operating system you are running?
You can't post conmments that contain an email address.
Have you set the mic you wish to use with your webcam as Default ?
XP Plug in your webcam or headset or mic you wish to use with your webcam Control Panel (Classic View) Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end. Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window' Open 'Volume' below the window to ensure the mic is not muted Click 'Apply' and 'OK' Restart your computer Configure the webcam / mic to your chat program
VISTA Plug in your webcam or headset or mic you wish to use with your webcam TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices' To set your preferred mic as default - click the mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click 'OK' Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
You do not say what sort of mic you have - if its a built in laptop mic, a standalone mic or one built into the webcam. It would also be useful to know what your OS is and what chat program you want to use the mic in However we can generalise and hopefully put you on the right track
You need to set the mic you wish to use with the webcam as the 'Default' mic
XP Plug in your webcam or headset or mic you wish to use with your webcam Control Panel (Classic View) Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your preferred mic the default device in the 'Sound recording window' Open 'Volume' below the window to ensure the mic is not muted Click 'Apply' and 'OK' Restart your computer Configure the webcam / mic to your chat program
If your webcam has a built in mic make it the default mic
XP Control Panel (Classic View)
Plug in your webcam
Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your webcam mic the default device in the 'Sound recording window' Open 'Volume' below the window to ensure the mic is not muted Click 'Apply' and 'OK' Restart your computer
Vista
Plug in the webcam
SET DEFAULT & TEST MIC Click "Recording" tab. Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices' To set required (webcam) mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click 'OK' Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
I assume your webcam has a built-in mic, otherwise lack of mic is the issue. Assuming you have a built-in mic try the step-by-step procedures in this webcam technical support article to get your webcam mic working. It has screen shots and guides you through the process.
You may be using a laptop with a mic as well as having a webcam with a mic. Try setting the webcam mic as default. Vista TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. To set required (webcam) mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click 'OK' Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
