Question about Ovens
Cant set time on Franke TR3 60MF8 X thankyou - Ovens
I cant get the auto setting off my oven and so the oven wont go on. my little girl is getting upset( tantrums) cos we cant make a pie. any advice would be so gratefully received and appreciated. thankyou...
Turn the oven to ON. Play around with the buttons on the electronic timer/clock. Try all different combinations. It could take 5 minutes or more. Be patient. When the oven indicator light comes on you are in business. If this helps you please vote for me.
Mar 05, 2011 | Ovens
Moved to a new place... I don't know how to work the Franke oven.
There are some links to pdf's at the lower portion of this page.
If they aren't helpful, try the "dealer locator" on the left upper side of the page for some help.
http://www.franke.com/kitchensystems/uk/en/home/support/view_brochures.html
Feb 11, 2011 | Ovens
How to operate a franke electric oven
hi i just need to know how to operate the oven for general purposes such as baking. I need to know which symbol stands for what. thanks
Feb 07, 2010 | Ovens
Help!!!!!!!!
Sounds like the oven element is faulty.
This is usually located at the rear of the oven compartment behind a remov eable cover.
Please rate my solution.
Thankyou
Jan 25, 2010 | Ovens
Cant reset the clock
Press the cook time & ready time buttons simultaneously and keep the buttons depressed. use the plus and minus buttons to set the time of day. A (Auto) symbol goes out, cookpot symbol comes on.
Jan 06, 2010 | Tecnik TKC8522 Electric Double Oven
How to set the clock on Westinghouse Virtuoso 70 oven
hello im not sure how to set the clock on my oven move in my houe 4 mnths ago and i cant bake in it unless i turn the grill on so would u please tell me how to set the time thankyou Sylvana
Nov 30, 2009 | Ovens
Oven-part of Franke Stove not working.
I have a Franke gas stove top and under one burner knob the spring is broken. Model #AD 72 M WQ
Jul 10, 2009 | Ovens
Hardwiring in cooker
6mm is the norm for wiring in the majority of electric ovens, you could fit 10mm, but it is is not really needed, unless you want to do it that way.
Please rate my fixya solution.
Thankyou.
Jan 30, 2009 | Belling Ovens
Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Plz rate my solution.
Thankyou.
Jan 05, 2009 | Bosch HBL 745 Stainless Steel Electric...
Ovens Logo
63 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
