My spacebar on my Dell Inspiron E5015 stopped working, so I pried up the cover to see what was wrong. There are three 'keys' inside the keyboard, but only one is raised the other two are flat. The raised key is currently the only one that is responsive.It appears that there is some robber-type ball inside the raised key which I imagine makes it work, which the other two are lacking. (Picture of my spacebar http://tinypic.com/r/2njhf7l/7 )I cannot find any trace of these rubber balls around my bedroom, or lodged somewhere inside my keyboard. How would they have gotten out, and is there anything around an average house that I could use as a replacement? Thank you very much.
  • 56 Answers
Not 100% on your model laptop, but on some leptop keyboards only the middle unit acts as a spring to return the spacebar to its resting position. As far as replacement with house hold items, the only thing that comes to mind is trying a fat rubberband. Cut it so its a strip and double over a few bits to make a pad of sorts.
Best of luck.
Posted on May 23, 2011
Touchpad and buttons do not work
Press and hold the Fn key and then hit F3 key.
Press and hold the Fn key and then hit F6 key.
Install touchpad drivers from dell website.
Jul 10, 2013 | Dell Inspiron N4010 Notebook
I have a Dell Inspiron 1545 and one day the three keys 'i', 'o' and 'p' randomly stopped working. What can be the problem? Can I fix it myself?
Try checking the keys in Command Prompt
Go to Start
type CMD in RUN
and type the keys and check if they work
If not go to device Manager
Steps
Click on Start
Type device Manager in Search Program and Files.
There will be a List and find Keyboard
Expand the Option
You will get the driver of Keyboard.
Right Click on it and click on uninstall.
Once uninstalled the driver will go away
Restart the PC once you reach the desktop it will automatically install the driver.
You will get the notification of driver installed.
It it installs successfully try using the keys that are not working.
Hope it helps
Jun 22, 2012 | Dell Inspiron 1545 Notebook
How to remove a cmos battery is a dell inspiron
The CMOS battery is located underneath the keyboard of your Dell i5100.
If you're up to it, then try these simple steps:
- Open the lid to a 180 degree angle and using a very small Flat Screwdriver, pry the hinge cover on the right side. There's a small notch where you can pry it out.
- Check if the keyboard is being held by 2 screws. To loosen them, remove the battery and unscrew them from inside the battery bay.
- Carefully lift the keyboard in an angled position and check the ribbon or contact tape that connects the keyboard to the motherboard. Flip the keyboard towards you and see if you can reach the CMOS battery (usually covered by a blue plastic shield or protective cover. There's a pair of wire coming from it and the end is a small connector. You may remove the connector attached to the motherboard carefully to get the CMOS battery.
Jun 10, 2010 | Dell Inspiron 5100 Laptop
Dell inspiron 6400 faulty spacebar?
You need to have the keyboard replaced. If you can't get it fixed locally, contact me for shipping information, I fix these kinds of problems a lot.
Jan 05, 2010 | Dell Inspiron 6400 Notebook
Spacebar is super sensitive. You barely touch it and it goes two,three or more spaces between words.
the spacebar key is misaligned. you may try removing the cap but putting it back is a pain the @ss, and usually does not work. if this is within warranty, call dell and have it replaced for a reason that the key popped out
Apr 30, 2009 | Dell Inspiron 6000 Notebook
Dell notebook keyboard malfunction
I suspect just as you suggested something was spilled on it. Other than loose keys laptop keyboards are generally not repairable. They are not that difficult to replace, but check the Service Manual before deciding to do it yourself.
Dec 17, 2008 | Dell Inspiron 1525 Notebook
Spacebar on keyboard not working
turn the keyboard over and tap the bottom. You may have a piece of fodder under it.
Jan 04, 2008 | Dell Inspiron 2650 Notebook
Keyboard space bar
only two possibilities, first is the rocker springs at each end or the bar are causingit to not make contact. or the bubble switches under the keyboard. I had a similar problem on an inspiron 6400 and I had to VERY CAREFULLY remove the keyboard,then the button to reach the bubble switch which had lost the plastic bushing that covered the shorting contact, good luck given the insane price that dell wanted for a new keyboard fixing it myself was the option.
Jan 04, 2008 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
