Question about Health & Beauty
How do I open cd of my exray from omni sv. exe
I lost my installation cd
Here are all of the drivers that you should need...
rockland.com/downloads
Jan 15, 2013 | OMNI Alfa 500mW AWUS036H USB Wireless...
Tip
HP printer UNINSTALL using CD
<p><span><b>Resolution:</b></span><br /> <ol> <li> <span>Run the uninstaller from the SETUP.EXE driver</span> <li> <span>Delete printer from Printers folder</span></li></ol> <p><span><b>Removing printer using the SETUP.EXE driver:</b></span><br /> <ol> <li> <span>Run the uninstaller from either the printer CD-ROM, diskettes, or the downloaded Setup.exe printer driver.</span> <li> <span>Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver as copied to.</span> <li> <span>Follow the on screen instructions.</span></li></ol> <p><span><b>Deleteing Printer:</b></span><br /> <ol> <li> <span>Run the uninstaller from either the printer CD-ROM, diskettes, or the downloaded Setup.exe printer driver.</span> <li> <span>Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver was copied to.</span> <li> <span>Follow the on screen instructions.</span></li></ol> <br />
on Mar 10, 2011 | Office Equipment & Supplies
Cd and omni speaker
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Feb 12, 2012 | Computers & Internet
I have a new pixma mp258 printer but i can't install it using a cd cause my cd drive is busted, so i need another way to install it
try to insert your CD in another PC and open it from my computer by clicking start/my computer/right click CD/DVD drive/click open or explore/copy the files inside of the CD installer including the setup.exe and the driver into USB flash drive.then insert your flash drive on your PC.open it double click the setup.exe or the driver folder.inside the driver folder should have an exe to install the software.
Sep 23, 2011 | Computers & Internet
Can't get into any folder because c:Windows/System 32/rundll32 .exe keep popin up
To resolve this issue, follow these steps:
1.
Put the Windows XP CD ROM disk in the CD ROM drive.
2.
Click Start , and then click Run .
3.
Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4.
Restart the computer
2.
3.
4.
1) Put the Windows XP CD ROM disk in the CD ROM drive.
2) Click Start , and then click Run .
3) Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4) Restart the computer.
Oct 27, 2010 | Computers & Internet
Message on screen SV-DV77, tray lock. Can't open anymore
Solution found on the internet:
Just press the on/off button for about 8 - 10 seconds and the tray will open.
Dec 06, 2009 | Pioneer Audio Players & Recorders
I DON´T HAVE THE CD WITH PANASONIC MEDIA SOFTWARE
Replacement software CD can be obtained from our National Parts Center at 800-833-9626 between the hours of 9am and 7:30pm EST, Monday through Friday.
http://www2.panasonic.com/consumer-electronics/support/Audio/Portable-Audio/MP3-Players/FAQs/model.SV-SD75.F#ts
Oct 04, 2009 | Panasonic SV-SD75 MP3 Player
I want a driver for my Omni 2 digital camera, because i have lost my cd, so i need your help.
download it from :
http://drivers.softpedia.com/get/NETWORK-CARD/OTHER-NETWORK-CARDS/ZyXEL-Omni-56K-II-Driver-10.shtml
Mar 20, 2009 | Cameras
Cant open the install.exe file on the software cd
adobe is generally only for files that end in ".pdf" for a ".exe" file you really should always be able to just double click it with your left mouse button.
and yes, install.exe is the correct file to get things going if they don't start automatically.
Feb 11, 2009 | ION Audio iTTUSB Turntable
No signal
1. Change Wire from Output on SV-22 to TV
2. Change CD-G and try again.
3. Make sure NTSC switch on rear of SV-22 is in NTSC position.
Dec 11, 2008 | JVC XL-SV22 CD Player
Health & Beauty Logo
105 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
