Question about Electrolux E23CS78HSS Side by Side Refrigerator
Electrolux refrigerator power failure light will not turn off, and the filter lights won't turn off and I have changed the filters and reset them, but the lights remain on. What do I do?
I'm encountering the same problem. Also, my ice and water lights are now both on. Any ideas?
Posted on Jun 02, 2011
Why the sign "replace" air filter keep appear even there is a new filter just installed?
Hello Michele,
From what you have described the replace air filter light on your Electrolux refrigerator continues to stay lit. I see that you disconnected power from it for a minute and the light was still lit. I would recommend performing a power reset on it and you can do that by unplugging for at least ten minutes. That will allow all of the power to drain out of the refrigerator for a full restart. If that does not work there may be an issue with the control panel of your refrigerator and a technician may need to be contacted for proper disassembly of your refrigerator. This will help you avoid any future issues within your refrigerator. -Matt
Dec 29, 2015 | Electrolux EI23BC56IS (226 cu ft) Bottom...
Filter stuck
It could be frozen, allow it to heat up some and try again. If not remove the filter cover and the filter will be easily removed.
Jun 30, 2013 | Electrolux Refrigerators
Samsung refrigerator filter light won't go off after new filter installed
Press and hold "Alarm" touch pad for 3 seconds and it should reset the filter light to blue.
Feb 02, 2013 | Samsung RF4287HARS French Door...
Filter light will not turn off
Resetting your Refrigerator filter indicator light after changing your water filter
Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
Nov 11, 2012 | GE PFSS9PKy Refrirator
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
Oct 20, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Change filter light won't go off
The Change Filter indicator light is controlled by a timer, rather than detecting the condition of the filter. After changing the filter, hold down the timer and speed buttons for about 5 seconds. This turns off the indicator light and resets the timer.
Jul 22, 2011 | Vornado AQS35 Air Purifier
Filter replace light won't go out after you replace the filter
It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
Rate if helpful, Sea Breeze
Jul 08, 2011 | Maytag Refrigerators
Change filter light
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Sea Breeze
Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
Maytag msd2454gr refrigerator how turn filter light off after replacing filter?
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER
indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place.
Nov 23, 2009 | Maytag MSD2454G Side by Side Refrigerator
Electrolux E23CS78HSS Side by Side Refrigerator Logo
949 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
