Question about HP DesignJet 1050c plus InkJet Printer
Receiving low memeory and taking long time to print
    Genius:
  • 1,089 Answers
You are going to have to add more memory to the printer.
Go out to www.hp.com
If the link above works it will take you to the page you need.
Otherwise, go to hp.com and follow the steps below.
Select "support and drivers" on the upper part of the page
Enter the "product support and troubleshooting"
Type in the printer model
Select your printer
You can now select "troubleshoot a problem" or go lower to get more info.
Posted on May 24, 2011
Kodak espc310 prints blank pages, replaced cartridges, printhead. Seems like the ink is going somewhere but not on the paper. Cartridges are already low.
Take it outside and run over it several times, pack the trash in a box with Kodak as the sender and receiver. drop it off at any PO and let them dispose of their junk.
Jul 19, 2012 | Kodak ESP C310 AllInOne InkJet Printer
Multiple printing
go to the main menu and go to the printing settings.adjust it to single printing...
May 20, 2010 | Panasonic KX-FM131 Fax
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Paper has run out
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
My Design Jet 1050c does not like to print PDF's. It says receiving low memory right now and is taking an extremely long time
Two questions:
1. How large is the PDF file and is saved on your local hard drive?
2. How is the plotter connected to your computer? Network or directly connected via parallel or USB?
Try changing how the printer processes the print job.
On the driver properties / preferences, select the Advanced tab and change the Process Document to "in computer" and then try printing again.
Aug 06, 2009 | HP DesignJet 1050c plus InkJet Printer
No plug. making my own plug. I need to know which wire terminal does what?
depends on car ,take black wire and one of the rest and touch the two to 2 seperte terminals on a 12v light bulb tie one that lights will be your memeory repeat process w/o the last wire not the black and the one that comes on is your hot black is almost always neg
Jun 07, 2009 | Car Audio & Video
Memory card error shows on screen.
meory card error can be cleared by for4mating the card ocne in the camera itself. use a low level format
Dec 16, 2008 | Canon PowerShot A410 Digital Camera
Document in ADF error when faxing
  1. This problem is caused by refilling your ink cartridge but there is a solution
  2. When the ink is low or the computer thinks the ink is low the sheet feeder will not work
  3. You will notice that the in use/memory light is on
  4. The memory has a report it needs to print but does not want to print it without ink
  5. To print the report anyway do the following:
  6. Press the <FAX> button to enter the Fax menu.
  7. Press the <Menu> button. [FAX SETTINGS] is displayed
  8. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  9. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK. Select Yes. make sure there is paper in the printer.
  10. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
Aug 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Erase memory from fax
unplug the unit and take any battery's out. then plug back in
Mar 17, 2008 | Brother MFC 420CN All-In-One InkJet...
HP DesignJet 1050c plus InkJet Printer Logo
269 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
