Question about Echo Rapid Loader, Trimmer Head
Both lines broke off in a my echo srm 225 u turn trimmer head. can't seem to open up the head?? suggestions
5 Suggested Answers
  • 1126 Answers
SOURCE: i need an instruction manual for echo srm 225 weed
http://www.echo-usa.com/documentation.asp?Model=SRM-225&lang=E
Hope this link helps.
Posted on Sep 08, 2009
SOURCE: How can I remove Echo 230 SRM trimmer head?
Remove the top off the string housing and remove the nut in the center.
Replace the top, as if you have finished loading string, Lock it in place as you normally do and the turn the entire housing pulling up at the same time. Spring and the white mechanism will pop out and then all you have to do is lift the string housing base off the trimmer head. Note it will take you a few tries but once it comes off you will see how easy it is to remove. I was amazed. Got my info from a sales person at Home Depot.
Posted on Aug 01, 2009
  • 87 Answers
SOURCE: need to replace the trimmer head cutting line.
Did you try pushing down hard and turning @ the same time? that should do it.
Posted on Oct 05, 2009
SOURCE: Need Help Installing U-Turn Trimmer Head on Echo SRM-210
It is ridiculous, there are a bunch of bolts, and then a multi-fit brochure showing a grid of nonsense.
There are instructions on the inside of the package, however that is how to string the line.
Posted on Feb 06, 2011
My echo srm 225 string trimmer line will not advance. Have rewound line and clear out grass from inside head.
Sometimes the spring may need extending as over time the bumping makes the spring lose its push tension causing no line advance
May 07, 2017 | Echo Garden
How do you take off the nylonhead off a srm 225 straight shaft trimmer to put on a new one
The nylon head should pop off by clicking on two pins holding it to the main body. Once it pops off you should be able to reload it and push back to those clips again
Aug 14, 2014 | Echo Garden
I have an Echo SRM 225 and the trimmer head just throws the line . After bumping it it will not cut the line with the knife on the guard -it just keeps slapping the guard and the knife until all of the...
You are winding the line in the wrong direction. It should be wound on the spool in the opposite direction of the spin of the head during operation.
Good Luck!
Aug 07, 2011 | Echo Rapid Loader, Trimmer Head
Echo SRM 200 series trimmer is great. I noticed though this summer once I reel in the new string, a short time of trimming later, only 1 side of the string appears. When I open up the reel, the string is...
For your machine, make sure you are using the Manufacturer's recommended trimmer line. For your model, they recommend using Echo brand .080" Cross Fire diameter line. You also need to insure that when you load the spool with the line, that it is loaded (in the right direction) so it can feed properly.
Jul 02, 2011 | Echo Rapid Loader, Trimmer Head
Echo srm-225 string broke off inside of the spool. How to get it out?
I solved the problem myself. I found the manual online and followed the directions that were given. Having the manual helped because it allowed me to know how to open up the spool without damaging it.
Sep 30, 2009 | Echo Garden
Sep 19, 2009 | Echo Rapid Loader, Trimmer Head
Don't know for sure, but I found manual on amazon, Amazon com echo srm manual so take a look if you want. have a nice day
Jul 21, 2009 | Echo Rapid Loader, Trimmer Head
Echo Rapid Loader, Trimmer Head Logo
390 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
