Question about Panasonic DMR-ES35VS
DVD Recorder DMR-ES35V is showing a U99 on the display panel. Cannot operate it. It has had very little use although we have had it for two years.
  • 1 more comment
  • stanglyn May 23, 2011
    Tried that. No result.
    Thanks. Will try. What exactly are supply contact plugs and where would we find them?
  • stanglyn May 26, 2011
    Thank you for your detailed instructions. However we are going to pursue this under the Consumers Guarantee Act so have been advised now not to attempt to fix it ourselves. Appreciate your fast response - please go ahead and charge for your services.
    Top Expert:
  • Panasonic Master
  • 75,404 Answers
Hello
[U99], on display indicates that the unit fails to operate properly. Press [POWER] button on the main unit to switch the unit to standby. Now press [POWER] button on the main unit again to turn ON the unit. OK.
Posted on May 23, 2011
  • 2 more comments
  • The Knight
    The Knight May 23, 2011
    If so, fault is with its power supply regulator board inside. Panasonic fault messege page of your DMR sates this, that I've quoted above. Due to long time non-use the plug in connections from the power supply reguator board to main board, will have insufficiant contacts or loose of fungus infected problems may arise. If you can, and able, open your DMR after disconnecing it from AC mains supply and pull out each supply contact plugs in the power supply board, and reset it to ths same, one at a time. If this also does not help you, the device need service, and contact the nearest panasonic service center.
  • The Knight
    moreover, disconnect the unit from AC mains wall power socket, wait for some time, say 15 minutes or so, and try again.
  • The Knight
    Hello --- Locate the power regulator board inside. It can be easly located as main power goes diretly to it. From that board, several low DC voltages are derived and given to different circuit boards of your device. They are all not diretly soldered to the power board. Instead, are conneted with pull-out and plug-in sockets; can be seen at the edge of that board. You can pull the wiring connections from the socket by pulling it out, and then replug it into the same socket. If there is some loose or fungus infected connections, that we cannot detect by ordinary or meter mesurements, will clean out and the contacts will be clear. There may be two or more such socket connections, whcih will look alike, that is why i adviced you to pull-out and plug-in one by one at a time, so that there will be no possibility of interchanging them. Thinks you got me. OK.
  • The Knight
    The Knight May 26, 2011
    Hello ---- Thanks for your timely response.
U99 error code on dmr-es35v panasonic recorder what is this?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Error code details to many popular devices are given.
Feb 12, 2015 | Panasonic DMR-ES35V Multisystem Code free...
DVD Recorder MODEL no.DMR-EZ27EB has U99 on screen unable to operate it
Hi.
U99 is a general communication failure between processor and timer, and there may be different causes. Common cause is a defective disk. Removing disk from the drive sometimes may fix the problem.
The first reset that you can attempt is disconnecting power for two minutes.
I quote below a post that was originally published in the MyCe forum (here):
"According to the service manual the U99 error is specifically a "hang up" displayed when there is a communication error that has occured between the main microprocessor and the timer microprocessor.
With more than twenty Panasonics (including four DMR-ES15 models) I'll offer my own observations:
There can be any number of causes for the U99 error, including a culmination of reading, writing, finalizing errors--sometimes appearing after U61 or U88 reading errors. The U99 error might also be associated with unusual DVD Drive noises, "grinding" indicating a dirty rubber hub and spindle; "clunking," "chugging" or "errrp" noises indicating a dirty lens or a failed laser assembly (the "optical pick-up").
Initial remedial measures include the routine DVD Drive lens, rubber hub and spindle area cleaning described in other CDFreaks/MyCE and AVS Forum threads. If that does not correct the problem(s) laser assembly or DVD Drive swapping with a direct replacement may be indicated. Also check for a disturbance to a ribbon cable or ribbon cable contact, correct or repair as necessary.
If the Digital PCB has become problematic, model-specific replacement is indicated. If the DVD Drive on-board contoller (if so equipped) has become problematic, model-specific replacement is indicated. In most cases "model-specific" means the same model year DVD Drive and, with problematic Digital PCBs or DVD Drive controller boards, replacements should be from the same model year and the same or very similar model recorder. Laser assemblies should only be replaced with the same model, i.e., 3331A and 3332A "optical pick-ups" might not interchange satisfactorily.
The U99 error may also be displayed when inferior media is in use. (Beginning in 2008 I've used nothing but Taiyo Yuden 8x Premium Line DVD-R media in my Panasonic, Philips and Magnavox DVD Recorders and HDD/DVD Recorders.)
The U99 error may also be displayed when there is an operating system "time out" occasioned when the user attempts to move too quickly between digital and analog channels (in 2007 and newer EZ series models)."
Apr 26, 2011 | Music
DMR-ES35V Switched on this morning and it said hello then put U99 on the display.I followed the instructions and switched off then on again but it went into the same display. It did open the dvd so i...
To initialize ALL parameters to factory defaults: With the unit OFF, press "Skip Rev" ({<< ) and "Time Slip" and "Open/Close" for 5 seconds.After this wait 1 minute and press on/off buton...thats all..
Apr 13, 2010 | Panasonic DMR-ES35VS
I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic Video/dvd player DMR ES30v Fault code U99
Hi,press the power button on the dvd so it goes to standby,then press the power button again to turn the unit on.I hope this helps.Jamie
Mar 12, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
U99
A U99 error code signifies a general communications failure and is not associated with any specific problem. It could even be related to the firmware version of your DVD recorder.
Try turning off the power and unplugging off-unplug for at least five minutes before reconnecting.
If U99 reoccurs, you should contact the Global Service Center Network for assistance.
Jan 27, 2009 | Panasonic DMR-ES10 DVD Recorder
DMR-ES35V shows u99 error, have pressed the on button waited for "HELLO" then pressed on button again as suggested in the Troubleshooting part of the operating manual but it will not startup it...
Hello, I found a receipt for my VHS and it is still under warranty until the end of december 08.
It is now in the electronic workshop being repaired.
Thanks for your follow up
Gary
Nov 05, 2008 | Panasonic Televison & Video
Panasonic DMR-E30 with U99 fault
Saludos : Yo tenia el mismo problema. Mi dvd DMR-E30 tenia el
mismo problema . Codigo U99 . Y no funsionaba nada.
Entre a la pagina de soportes de Panasonic y baje el Firmware.
Luego lo grabe en un cd ,el cd lo coloque en la dvd y la dvd se actualiso automaticamente. La dvd funciona perfectamente tanto
con DVD-RAM como con DVD-R. Esta solucion la saque de esta
misma pagina fixya . Gracias Fixya. Att. LACF
Jun 29, 2008 | Panasonic DMR-E30 DVD Recorder
Dvd would not work displays u99
Dvd recorder doesn't not work. Displays error code U99. Any suggestion please?
Jun 21, 2008 | Panasonic DMR-E85H DVD Recorder
NO FUNCTIONS
Replace the Digital board
Feb 26, 2008 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-ES35VS Logo
241 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
