Question about Senco Tools & Hardware - Others
I have a Omar nail gun model number 14.63 and Ineed a new bumper part number 32.72 where can I buy one in Western Australia ?
  • 23 Answers
SOURCE: My nail gun hitachi nr83a2 only fires a nail half way
the blade assemblies for the A and A2 are the same.
the pison bumper should not be attached to the driver, if the bumper is moving around inside the gun i suggest checking to make sure it was properly seated when the gun was reassembled. if it was, i suggest ordering a new bumper.
a cracked bumper will usually cause a broken driver.
Posted on Nov 17, 2008
jj505
  • 195 Answers
SOURCE: Cannot find 3.5 inch galv framing nails for Model IFN2190
http://www.jackssmallengines.com/campbell_hausfeld_parts_index.cfm
Try this site. It si home for your nail needs
Posted on Mar 16, 2009
  • 99 Answers
SOURCE: how do i clear a nail jammed in the gun?
I may need more information but you ,should be able to take it apart like any other nail gun.
Posted on Aug 03, 2009
rcalorisian
  • 313 Answers
SOURCE: carraige in dewalt nailer
just goto:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
download the support manual. You should be on your way
Posted on Sep 08, 2009
  • 108 Answers
SOURCE: nail gun- double feed
Nail guns either have a switch or a seperate trigger assembly for two options - automatic, or 'bump' fire, and sequential fire. Sequential firing may be best for you since the nose must be fully depressed and the trigger pulled for each nail.
If you're stuck with bump firing, practice your technique. Double fires often occur when the workpiece bounces back into the nose of the gun; learn to 'bounce' the gun off the material to avoid this second contact.
If you're getting double fires in sequential mode, the problem could be more serious. I keep a can of aerosol silicone lubricant on hand to clean and lubricate the feed mechanism and magazine. Make sure your tool is clean and lubricated before each use, including the 3-5 drops on the air coupling.
Check that your air pressure is not set too high. Overdriving nails reduces their effectiveness and can cause tool malfunction.
This problem could also be caused by worn out O-rings or other parts within the tool. If you're not comfortable servicing the tool yourself, take it in for repair/maintenance work.
Another important thing to remember: With tools like this, you get what you pay for. A cheap nailgun will never function as well as a quality nailgun.
Posted on Oct 14, 2009
Can the cylinder inside the nail gun wear to where the piston will not hold its self up after fireing
What brand / model? They can certainly wear, I've had this happen even with a high end nail gun. If used all day, more than one application of oil may be needed to prevent wear. Or invest in a gun mounted self-oiler..
Oct 18, 2014 | Air Tools & Compressors
Nailer drives nails too deep
n80 coil nailer is a very powerful nailer used for hard wood. If the driver is setting nails too deep, adjust safety foot to the lowest level. Install safety foot no-mar boot to lift the gun even higher. If still too deep, most likely the lower bumper inside the gun is worn-out or cracked. Easy test. Remove nails and connect air supply. With trigger depressed, push and hold the gun against work (I use an old rubber hose tightly coiled up). This will fire the gun but keep the driver down allowing you to examine the tip of the driver. The driver should extend out past the nose less than quarter inch. If the driver is extending too far, most likely bumper is worn out. If a large quantity of air is leaking out the nose of gun during the test, indication that lower bumper is cracked. Good luck.
Apr 06, 2013 | Stanley Bostitch N80CB Coil Framing Nailer
Where to find non-marring bumper for arrow et 200 nail brad gun part number 2815
The non-marring bumper for the ET200 nail gun is Part #2815. Send a note together with a check for $1.50 plus $1.00 S&H to Parts/Service Dept., Arrow Fastener Co., 271 Mayhill St., Saddle Brook, NJ 07663.
Mar 26, 2013 | Arrow Heavy Duty Nail Master Electric Brad...
I got air leaking out the barrel where the nail shoots from.
Without model number I cannot be more exact, however, air leaking from nose as soon as you connect the airline indicates that the cylinder spacer orings are leaking. The cylinder is usually sealed by a plastic or metal ring with an oring at the outer edge and seals against an oring installed at the cylinder. Broken oring or grit entering the gun will cause the orings to leak. A quantity of air leaking from the nose when you fire a nail indicates that the lower bumper is cracked or missing pieces. Air leaking from nose with driver being pushed to bottom of cylinder when you connect the airline indicates that the cylinder seal at top of cylinder is leaking. Parts are available at www.toolpartsdirect.com Good luck with your repair and post again with model number if you need more help.
Apr 19, 2011 | Stanley Bostitch Nail Gun
Our Bostitch RN46 coil nailer was bought new last July and has only put on around five squares of shingles. We used it today for the first time since last summer and at first it was mis-firing, only...
Going strickly by what you said above, it sounds like you put it away 'dry'. If you are not going to use a nail gun for an extended period of time you should lube it well with pneumatic gun oil and fire a couple nails to distribute it throughout the gun. When you take it out of storage, put a little more pneumatic gun oil in it and fire some nails to get it well lubed again and blow out any excess oil. WD-40 is OK on the exterior of the gun as long as you blow off any excess after spraying it on; never use it inside the gun. The problems you are experiencing now are indicative of broken or damaged o-rings inside the head. Some of the o-rings act as seals and some act as valves. There is also a rubber bumper at the bottom of the cylinder. When the driver hits the bumper it is pushed back up by the rebound off the bumper and assisted by air pressure. If one or more of the o-rings are damaged the air isn't directed to the proper place to make these things happen. Bostitch makes a rebuild kit for your gun. It's part number RN-46RK. You can find them on several on-line after market sites and should cost around $30 to $35. Use all of the parts in the kit and you'll have a gun as good as new.
Mar 18, 2011 | Stanley Factory Reconditioned Bostitch...
Nail gun shoots 1st nail fine then second is a blank. The gun is clean, there is no jam, they are the right nails. PSI is at 100. Person using gun has used this gun and others for a very long time. ...
Miss fire usually occurs when piston/driver is bent, piston oring worn, lower bumper cracked or missing pieces or upper bumper is cracked. Easy to check. Remove head and pull piston. If bent try to adjust, but be careful, blade breaks easily. Piston should fit snugly in cylinder, if loose, replace piston oring. If oring/plastic ring ok examine lower bumper for cracks and replace as needed. If lower bumper ok, pull out headvalve and examine upper bumper for cracks. If upper bumper ok, pull cylinder and look for loose check band around cylinder. Check band is black rubber and should be placed around cylinder fitting snuggly covering series of holes. Replace parts as needed and lube with silicone paste sold at Lowes in the plumbing department (or white grease). Good luck
Jan 11, 2011 | Porter Cable FactoryReconditioned DA250BR...
I have a SCN40R gun that doesn't advance the nails in the coil part. What could be the problem. The part that is suppose to advance the next nail doesn't move.
The feed pawl is moved by a piston that extends from a cylinder on the lower side of the guide body. There are a couple seals inside the cylinder that if damaged will not hold enough air to activate the piston and advance the next nail. The two seals are Senco part number LB0828 & LB0845. Better yet get a Senco YK0369 repair kit and replace all of your o-rings, you'll have a like new gun for around $60.
Jan 06, 2011 | Senco Air Tools & Compressors
I have a craftsman 16 gauge finish nailer, model 918441. it is not advancing the nails. not certain how to adjust. cannot find the manual. is the manual available on line?
Assuming that the nails are correct for gun (16g nails measure .055) and feeder is actually applying pressure to nails (feel spring pressure as you close clip), most likely problem is driver is not returning to top of cylinder. This is caused by low pressure to gun, bent driver, lower bumper missing pieces/cracked, worn oring on piston or lack of lubrication. Remove cylinder and examine condition of lower bumper, replace if broken/cracked; check outer cylinder for check valve in place (usually small band or oring covering series of ventholes) ; replace piston oring as needed, make sure driver not bent. Parts available at sears web site. Good luck
Sep 08, 2010 | Craftsman Tools & Hardware - Others
MY NAIL NOTIS SHOOTING AND BENDING THE NAIL INSIDE THE GUN
you have a problem with the nose or the driver. I would also check for a jammed nail in the nose assembly. let me know what the model number is and I will try and find a breakdown for you.
Sep 18, 2009 | Stanley Bostitch Coil Framing Nailer
Oct 25, 2008 | Hitachi NR83A2 2" To 3 1/4" Full Head...
Tools & Hardware - Others Logo
Top Senco Tools & Hardware - Others Experts
John Trevino
yoopertech
John Bowen
Are you a Senco Tool and Hardware - Other Expert? Answer questions, earn points and help others
