Question about Seville Classics MSC10166 Tower Fan
My fan is one to two years old and never had a problem. The other day it was running and i turned it off unplugged it and carried to another room (never dropped or hit it) plugged it in and it wouldn't turn on, the outlet is fine. So is there a way to take it apart to fix it?
thanks
  • telibra Aug 28, 2008
    Fan has been used very little. It won't start when start button is pressed on both the unit and the remote.
  • Anonymous Dec 24, 2008
    I had a very similar problem. I unplugged my fan and later plugged it in. All the functions still work except for the fan itself. It rotates, but air wont blow. I intend on taking it apart and seeing what I can do about it.
To take apart: see solution #1 (not a complete disassemble but helps)
Posted on Dec 23, 2008
My seville classics tower fan no longer oscillates - how can that be fixed?
Throw it away and buy a new one for 20 box at Wal-Mart. It's as simple as that cause to fix it, it'll take a new machine which cost twice the price. I think they made it to last one summer max. Friendly yours
Jul 01, 2014 | Seville Classics MSC10166 Tower Fan
Why blades are not rotating or throwing air?
some of these have a expansion pin that holds the fan blade assembly onto the shaft, this may have fallen out or ? broke,,,
May 13, 2014 | Seville Classics MSC10166 Tower Fan
My remote quit working.
could always be the battery, there is a curcit board in the remote in the fan the diod on this board proble went out if you take it out of the fan to check it there will be a burn color by the diod this does happen a lot you just need to go to a hardware store and replace it they run about 40 bucks to replace good luck
Aug 01, 2011 | Seville Classics MSC10166 Tower Fan
How do you clean it? It shoots out dust!!
You need to change the air filter, make sure you clean out the air filter chamber before installing a new one. it should be fine then, Good Luck
Feb 07, 2010 | Seville Classics MSC10166 Tower Fan
The fan fuse 1.5A/250V is keep blown up as soon as
Unplug the fan.
Open it up carefully.
Look at the the wiring for damage or shorts.
Check that the fan impeller is free to turn.
If all of the above is OK then possibly the motor has gone? If so then it will probably be cheeper to buy a new one.
Jul 02, 2009 | Seville Classics MSC10166 Tower Fan
Dust inside the fan
you can remove the topcover and can be cleaned using the brush and or vaccum cleaner/ even blower
Jun 01, 2009 | Seville Classics MSC10166 Tower Fan
Possible Solution :
Taken From :
http://www.fixya.com/support/t193631-am_trying_fix_oscillating_tower_fan
"Most fan motors for fan over running have an internal overload. once it trips, it will not reset. it is a solid state device. it looks like a flat device or a small bullet device. if you've figured out how to take the fan apart, you could just remove the device and connect the two wires together and the fan will run. you won't have any protection on the motor however. the windings run warm, but if the bearings run dry the motor will slow down and the windings will get hot. this is the reason for the overlaod device - protection. its your call what you want to have."
Aug 14, 2008 | Seville Classics MSC10166 Tower Fan
Seville classics model 10166
bottom stand was broken. how to get new bottom part.
Dec 06, 2007 | Seville Classics MSC10166 Tower Fan
Seville Classics MSC10166 Tower Fan Logo
1,028 people viewed this question
Top Seville Classics Dryers Experts
Are you a Seville Classics Dryer Expert? Answer questions, earn points and help others
