Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Kdf- we655 works for awhile then no sound or picture - standby light flashes for awhile then turns to red and flashes in sequences of 5 - 35 then after a short bit tv comes up and works for awhile again. tv is 6 years old and the lamp was never replaced. Does all this mean my lamp is going bad or something else. thanks for the help!
    Problem Solver:
  • 10 Answers
Check the power suply or the eprom and see if it help
Posted on May 23, 2011
Sony KDF-42 WE655 TV. Replaced lamp and it now works; however sometimes when it is first turned on the audio and video quit for about a minute and the green light flashes. Then both sound and video...
You may have a bad ballast. Check to see if your lamp is lighting up through the back of your T.V. prior to the picture coming on. If it has done this since you bought it, it's probably the just the way the T.V. was designed. If it still comes on every time, it could also be a power supply issue, but nothing to stress about.
Jun 17, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
HELLO MY kdf-e55a20 tV IS NOT WORKING. THE GREEN LIGHT FLASHES 6 TIMES THEN IT FLASHES RED 6 TIMES
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The Lamp light blinks when the Lamp requires replacement.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the power light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
This indicates that there is some kind of audio problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 11, 2011 | Sony KDF-E55A20 55 in. LCD Television
Kdf42-we655 works for awhile then no sound or picture - standby light flashes for awhile then turns to red and flashes in sequences of 5 - then after a short bit tv comes up and works for awhile again. tv...
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 21, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Power/standby led beeps red light 6 times
crazyford359
Your Thermal fuse is out. I just replaced mine, the part is only $4.85 on Sonyparts.com. Ordered (2)
Feb 16, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Standby light flashes 50 times then lamp light flashes, no picture or sound
standby light flashes 7 times then lamp light flashes, no picture or sound
Nov 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Sony KDF-50WE655 will not power up. Red blight blinks 4 times
4 blinks shows problem either one or all 4 fans are not working AND internal temperature high error.
If you are familiar with TV repair and know basic electronics then unplug TV from AC outlet an take off back cover and check fans are running?
Jan 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
108 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
