Question about Dryers
Where can I find the thermal fuse in my admiral capacity plus dryer model # LNC7764A71?
5 Suggested Answers
Excellency
  • 20 Answers
SOURCE: Dryer won't start
Thermal fuse is your most likely suspect LA 1053
Posted on Dec 10, 2008
svpsastry
  • 81 Answers
SOURCE: admiral capacity plus stopped working mid cycle no power
When u press the knob to start the dryer is there a buzzing noise ???
If so i guess u nee to order a new moter ...
u can do it at..www.appliancepartspros.com
Posted on Jan 07, 2010
heatman101
  • 43501 Answers
SOURCE: Admiral Dryer Model LNC7764A71 - Loud Vibration
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Jul 11, 2010
heatman101
  • 43501 Answers
SOURCE: MAYTAG ADMIRAL DRYER MODEL LNC7764A71 STOPPED
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
Why do i have no heat on my dryer after cord was replaced after it caught on fire?
I would check the heating element for continuity. If you don't have a multimeter, you could buy a cheap one or borrow one maybe? I found a video on youtube in case you need to know how to do it. Good luck
Aug 06, 2014 | Admiral Dryers
How do you replace the thermal fuse on a admiral capacity plus tumble dryer
The thermal fuse is number 5 on this diagram. http://www.appliancepartspros.com/05-heater-parts-for-admiral-aye2200agw.htmlHere is a link to the thermostat kit.
I would replace all of them. If one goes, the rest will follow soon!
Oct 17, 2012 | Dryers
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Admiral Capacity Plus LNC8764A71 stopped heating up, Otherswise fine. Cleaned lint out of front and back. What next?
If this is a gas dryer, you might want to check your thermal fuse. If it's not glowing on start up, replcae it.
Feb 06, 2011 | Admiral AAV7000A
MAYTAG ADMIRAL DRYER MODEL LNC7764A71 STOPPED RUNNING ABRUPTLY DURING A CYCLE AND WILL NOT START IT HAS POWER AND THE THERMAL FUSE HAS BEEN REPLACED STILL NOTHING
heatman101
Jan 01, 2011 | Whirlpool LER5636P Electric Dryer
Admiral Dryer Model LNC7764A71 - Loud Vibration, everything else is fine
heatman101
Jul 08, 2010 | Maytag Dryers
Admiral capacity plus stopped working mid cycle no power
Jan 07, 2010 | Dryers
Admiral dryer LNC7764A71 stopped running tryin to figure out how to take it apart to see if its the belt or motor. We are beginners at trying to fix things. I thought I had left the oven on when I noticed...
The front comes off. There are clips on the bottom and flat pegs on the top of the panel. Take a putty knife and slide it between the top and front. Pry down and the top of the panel will pull out. Make sure you don't pull wires loose from door switch when you get it un-clipped. Once you are into the unit, you will most likely find that the thermal fuse is blown. If so you will also need to replace the cycling thermostat. When it goes bad, it puts the thermal fuse out. What you smelt was the dryer getting to hot because the thermostat went bad so it by passed the thermostat and got so hot that the thermal fuse was blown. This is the way the unit is designed to work when the thermostat goes bad. The thermal fuse is a safety.
Oct 16, 2009 | Whirlpool LER5636P Electric Dryer
Dryer won't start
Dec 10, 2008 | Dryers
Admiral Capacity Plus Dryer won't start. No light when door open. Plugged in, Circuit Breaker Reset, socket live, (tested). Internal fuse or circuit breaker?
hi yes there is a thermal fuse in the dryer at the back on the air duct a small plastic piece with 2 small blue wires check that also door switch thanks the appliance doc
Sep 22, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
