Question about Kitchen Ranges
The knob on my lincat oven won't move. Its completely stuck. I can't get the oven on pilot or anything.
Try contacting Lincat (01522 875555) and ask for the Service Department.
Posted on Aug 15, 2008
I have got lincat fryer j10 the pilot won't stay
Hi there.
Make sure that the thermopile is receiving enough heat from the pilot and if it does, check if the hi limit is good, check and tighten also all of the wiring connections, before replacing the gas valve.
Regards.
Jun 11, 2013 | Kitchen Appliances - Others
Pilot light won't stay on
What is the model number of the unit?
Nov 27, 2012 | Tappan Kitchen Ranges
Burner won't light, pilot is burning just fine.
Once you get the pilot to light and stay lit did yall move the burner knob to the ON position? Is the temp knob all the way up?
Nov 27, 2011 | Procom Heating & Cooling
Hello i have a J5 lincat fryer and the pilot stays alight but the burners won't connect (light) have replaced the thermostat and the thermo couple but still no joy any ideas on this not sure what to do...
Check if there is 500 to 750 millivolts across the thermopile wires; thermopile generates 500 to 750 millivolts if properly heated to energize pilot and main valve solenoids of the gas valve for pilot and main burner operation. If the voltage across the thermopile is good and all wiring connections are ok, I think you have to replace the gas valve.
Regards.
Jun 15, 2011 | Imperial IFS40 Deep Fryer
Dont know how to light oven with pilot light
So-- your oven DOES have a pilot light?
Most ovens today, use ignitors-- not pilots--
However, if yours does have a pilot, Here is how we used to light ours back home many years ago.
We pushed in on the oven's thermostatic (Temperature control) knob.
(Note-- that knob connected directly to the main gas valve-- so by pushing in on the knob, we were by-passing the safety's---
There was a little hole in the center of the oven-- bottom pan...
We had to have a match lit, and ready to go when we pushed in on the knob--
We inserted the burning (Wooden) match into the hole, and 'WHOOSH'!-- the pilot lit with a rush of gas and air-- It used to scare us kids!-- But Mom was brave!
I hope this helps--
But if you need more help, let us know--
Mack B
Jan 19, 2011 | Ovens
I have a suburban propane oven in my RV. The stove works great but the oven after being on for 5 to 10 minutes starts to puf out. The flames dies then puffs back on. this happens over and over like it is...
My suburban oven pilot comes on but when I release the oven knob to turn on oven, pilot goes out and doesnt lite oven. I replaced safety valve but still the same problem.
Aug 31, 2009 | Ovens
Pilot light knob stuck
You have to push in on it to move to 'pilot'
Jun 29, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
My knob on my oven is frozen
Did you try WD40(in the UK) or Q20(in South Africa)? You can buy it at hardware shops. It is a penatration flued which is a bit oily.
Dec 20, 2008 | Whirlpool GS563LXSS - stainless Steel Gas...
Pilot wont light.
Firstly make sure the gas knob is exactly in the pilot mode some are finiky and won't light unless in exactly the right postion. Make sure once lit when pushing down on the pilot knob that you hold it down long enough for the thermocouple to sense the pilot. Barring both of those the most likley culprit is the thermocouple itself is faulty and can easily be removed usally with a couple of screws and a small adjustable wrench.
Dec 29, 2007 | Imperial IFS40 Deep Fryer
How do I turn my oven on!
The oven pilot will need to be lit, On the bottom there is the oven safety valve, it has a red button on it, you must depress the button and hold it with the pilot lit for 60 seconds, when you release the button the pilot should stay lit and the oven will be ready for operation using the thermostat (knob). Please note: if the oven has set unused for some time you may need to hold the red button for a long time to bleed the air out of the lines. The pilots for the top burners are actually right beside each burner. You may need to turn these pilots on, they are controlled by small valves (small brass screws on the gas manifold where the gas valves and knobs are located, look between the knobs). These small screws/valves will open the gas flow to the pilots when turned counter clockwise. If you open these valves and the pilots still do not work, they will need to be replaced. Hope this helps
Nov 15, 2007 | Imperial IR-6-C Elite Gas Kitchen Range
Kitchen Ranges Logo
140 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
